Kernel 41 - 2 mesacna nova zostava
Vyhadzuje chybu Adrenaline menu, je tam vsetko nastavene defaultne. Ale teraz zacalo bzucat pocas toho ako som pozeral stream. Bzzzzzzz z reproduktorov a sekol system, uz sa to stalo 3x za vecer. Neviem co to moze byt. Deje sa mi to aj dakedy pocas hry, ze sekne mi obraz a nic...a vyhodi mi potom plochu a napise mi hlasku o tom ze spadol system alebo nieco
Co mam robit?
Ryzen 7 7700 Tray
RX 9070XT
DDR5 32GB RAM
MB: Gigabyte B650 X AX V2
Dodatečně přidáno po 28 minutách 8 vteřinách:
Znovu, 28 minut a znovu to iste
Dodatečně přidáno po 57 minutách 19 vteřinách:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 6/7/2025 11:52:43 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-JLFQDHC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331c3b3a-2005-44c2-ac5e-77220c37d6b4}" />
<EventID>41</EventID>
<Version>10</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2025-06-07T21:52:43.3382703Z" />
<EventRecordID>14739</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-JLFQDHC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">0</Data>
<Data Name="PowerButtonTimestamp">0</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">0</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
<Data Name="BugcheckInfoFromEFI">false</Data>
<Data Name="CheckpointStatus">0</Data>
<Data Name="CsEntryScenarioInstanceIdV2">0</Data>
<Data Name="LongPowerButtonPressDetected">false</Data>
<Data Name="LidReliability">false</Data>
<Data Name="InputSuppressionState">0</Data>
<Data Name="PowerButtonSuppressionState">0</Data>
<Data Name="LidState">3</Data>
<Data Name="WHEABootErrorCount">0</Data>
</EventData>
</Event>
Dodatečně přidáno po 57 minutách 33 vteřinách:
Log Name: System
Source: Microsoft-Windows-TPM-WMI
Date: 6/7/2025 11:57:53 PM
Event ID: 1796
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Description:
The Secure Boot update failed to update a Secure Boot variable with error Secure Boot is not enabled on this machine.. For more information, please see https://go.microsoft.com/fwlink/?linkid=2169931
Event Xml:
<System>
<Provider Name="Microsoft-Windows-TPM-WMI" Guid="{7d5387b0-cbe0-11da-a94d-0800200c9a66}" />
<EventID>1796</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000000</Keywords>
<TimeCreated SystemTime="2025-06-07T21:57:53.1602106Z" />
<EventRecordID>14831</EventRecordID>
<Correlation />
<Execution ProcessID="10064" ThreadID="12356" />
</System>
<EventData>
<Data Name="HResult">-2147020471</Data>
</EventData>
</Event>
Dodatečně přidáno po 57 minutách 43 vteřinách:
Log Name: System
Date: 6/7/2025 11:23:36 PM
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2025-06-07T21:23:36.1194595Z" />
<EventRecordID>14615</EventRecordID>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Dodatečně přidáno po 57 minutách 54 vteřinách:
Log Name: System
Date: 6/7/2025 10:19:55 PM
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2025-06-07T20:19:55.0929743Z" />
<EventRecordID>14499</EventRecordID>
<Correlation />
</System>
<EventData>
<Data Name="Checkpoint">16</Data>
<Data Name="SystemSleepTransitionsToOn">1</Data>
<Data Name="CsEntryScenarioInstanceId">2</Data>
<Data Name="CsEntryScenarioInstanceIdV2">2</Data>
</EventData>
</Event>
Dodatečně přidáno po 1 hodině 13 minutách 35 vteřinách:
Vsetko bezalo fajn. PC ma asi dva mesiace. Hral som aj RDR2 a GPU tahalo 330W, bez erroru a zrazu pri pozerani streamu cez discord to zacalo padat. Vcera na starsej hre to padlo aj predvcerom ked som mal dve okna hier zapnute vo windows mode.
Dodatečně přidáno po 1 hodině 34 minutách 38 vteřinách:
Pozeram cely register Kernel errorov a zacinaju od
10. aprila
17. aprila
28. aprila
1. maja
1. maja
6. maja
7. maja
7. maja
8. maja
22. maja
25. maja
25. maja
26. maja
27. maja
30. maja
31. maja
6. juna
6. juna
a dnes 3x 7. juna
Takze tych errorov tu je dost
Dodatečně přidáno po 1 hodině 35 minutách 9 vteřinách:
Vsetky kernel errory su tie iste s rovnakym kodom: (70368744177664),(2)
Kategoria: 63
Event ID: 41
Dodatečně přidáno po 1 hodině 38 minutách 35 vteřinách:
Log Name: System
Event ID: 1796
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Tychto errorov tu mam: 141
Dodatečně přidáno po 1 hodině 39 minutách 26 vteřinách:
Log Name: Microsoft-Windows-Kernel-EventTracing/Admin
Source: Microsoft-Windows-Kernel-EventTracing
Date: 4/26/2025 3:24:53 PM
Event ID: 3
Task Category: Session
Level: Error
Keywords: Session
User: SYSTEM
Description:
Session "PerfDiag Logger" stopped due to the following error: 0xC0000188
Event Xml:
<System>
<Provider Name="Microsoft-Windows-Kernel-EventTracing" Guid="{b675ec37-bdb6-4648-bc92-f3fdc74d3ca2}" />
<EventID>3</EventID>
<Version>1</Version>
<Level>2</Level>
<Task>2</Task>
<Opcode>14</Opcode>
<Keywords>0x8000000000000010</Keywords>
<TimeCreated SystemTime="2025-04-26T13:24:53.9623279Z" />
<EventRecordID>56</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="15324" />
<Channel>Microsoft-Windows-Kernel-EventTracing/Admin</Channel>
</System>
<EventData>
<Data Name="SessionName">PerfDiag Logger</Data>
<Data Name="FileName">C:\WINDOWS\system32\WDI\LogFiles\ShutdownPerfDiagLogger.etl</Data>
<Data Name="ErrorCode">3221225864</Data>
<Data Name="LoggingMode">41943168</Data>
<Data Name="FailureReason">0</Data>
</EventData>
</Event>
Co mam robit?
Ryzen 7 7700 Tray
RX 9070XT
DDR5 32GB RAM
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Log Name: System
Event ID: 1796
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
10. aprila
17. aprila
28. aprila
1. maja
1. maja
6. maja
7. maja
7. maja
8. maja
22. maja
25. maja
25. maja
26. maja
27. maja
30. maja
31. maja
6. juna
6. juna
a dnes 3x 7. juna
Kategoria: 63
Event ID: 41
Log Name: System
Event ID: 1796
Task Category: None
Level: Error
Keywords:
User: SYSTEM
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Event ID: 3
Level: Error
Keywords: Session
User: SYSTEM
Description:
Event Xml:
<System>
<Level>2</Level>
<Task>2</Task>
<Opcode>14</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Re: Kernel 41 - 2 mesacna nova zostava
Jaké teploty a spotřebu CPU a GPU ukazuje HWinfo? Běží to na default nastavení?
Dodatečně přidáno po 4 minutách 38 vteřinách:
Je potřeba nasimulovat alespoň pár minut trvající zátěž, aby byla vidět maxima dosažených hodnot.
mam OCCT, zapnem to? co tam presne mam dat?
Může být OCCT, ale stačí pustit nějakou náročnější hru a potom třeba cinebench. Aby se postupně ukázala maximální zátěž CPU a GPU.
Takze zapnem hwinfo a pocas toho zapnem nejaku hru ako je RDR2 alebo cinebench spustim?
Jo. Nebo prostě normálně používat počítač a na pozadí to HWinfo nechat běžet.
Dobre, tak necham to bezat
Dodatečně přidáno po 5 hodinách 12 minutách 25 vteřinách:
Hral som asi 30 minut RDR2 na maximalne graficke detaily bez FSR
Tak ako? Je to fajn?
Frekvence a teploty grafiky jsou trochu vysoko, i když ne zase kriticky. Zkus stáhnout nastavení taktů - třeba mínus 300 MHz. Adrenalin > Výkonnost > Ladění > Max. posun frekvence (Max. frequency offet). Viz: https://www.gpureport.cz/recenze/486/im ... v-asae.png (to ostatní nastavení na obrázku neřešit)
Jinak to běží na default, není to nějak výrazněji podvoltované?
Je to default, nie je to podvoltovane. Ale ked idem hrat RDR2 alebo Last of Us, tak davam -60 mV offset a -15% power a nespadlo mi to, potom jak dohram, to davam naspat do default, lebo to setri Watty a teploty nie su vysoke vobec a zerie to malo.
Ale pocas tychto crashov som nemal nastavenu take nieco. Teploty grafiky mozu byt asi preto, lebo to ide na max cize to tahalo 330W-340W, jedine upravit krivky fans ale bude to viac hucat. Mam tam original ventilatory vpredu a tie ventilatory vpredu maju rovnake % a krivky ako ventilator vzadu aby tam nebol podtlak.
Dodatečně přidáno po 1 minutě 5 vteřinách:
Dal som -300Mhz, bude to mat velky vplyv na hry FPS? Lockujem all hry na 85-90FPS, viac netreba
Alebo je lepsie -60mV a -15%power?
- 7571 Zobrazení
- 26 Odpovědi
- 20820 Zobrazení
- 4115 Zobrazení
- 10 Odpovědi
- 9861 Zobrazení
- 4 Odpovědi
- 11609 Zobrazení
