Upgrade starého počítače
Lojza
Příspěvek od Lojza »
mám tuto kofiguraci:
Summary
Operating System
Windows 10 Home 64-bit
CPU
Intel Pentium E5200 @ 2.50GHz 48 °C
Wolfdale 45nm Technology
RAM
8,00GB Dual-Channel DDR2 @ 333MHz (5-5-5-15)
Motherboard
ASUSTeK Computer INC. P5Q SE (LGA775) 30 °C
Graphics
ASUS VP247 (1920x1080@60Hz)
2047MB NVIDIA GeForce GT 710 (ASUStek Computer Inc) 37 °C
Storage
111GB Samsung SSD 850 EVO 120GB ATA Device (SATA (SSD)) 32 °C
465GB Seagate ST3500418AS ATA Device (SATA ) 27 °C
298GB Seagate ST3320620AS ATA Device (SATA ) 28 °C
Optical Drives
ATAPI DVD D DH16D3S ATA Device
HL-DT-ST DVDRAM GH20NS15 ATA Device
Audio
Zvukové zařízení High Definition Audio
Motherboard
Manufacturer ASUSTeK Computer INC.
Model P5Q SE (LGA775)
Version Rev 1.xx
Chipset Vendor Intel
Chipset Model P45/P43/G45/G43
Chipset Revision A3
Southbridge Vendor Intel
Southbridge Model 82801JR (ICH10R)
Southbridge Revision 00
System Temperature 30 °C
BIOS
Brand American Megatrends Inc.
Version 0502
Date 20.8.2008
Voltage
CPU CORE 1.208 V
MEMORY CONTROLLER 1.752 V
+3.3V 3.328 V
+5V 4.944 V
+12V 11.710 V
VIN6 1.200 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Bus Width 32 bit
Slot Designation PCIEX16
Characteristics 3.3V, Shared, PME
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Slot Usage In Use
Bus Width 64 bit
Slot Designation PCIEX1_1
Slot Number 1
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Bus Width 32 bit
Slot Designation PCIEX1_2
Slot Number 2
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI_1
Slot Number 3
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI_2
Slot Number 4
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI_3
Slot Number 5
Graphics
Monitor
Name ASUS VP247 on NVIDIA GeForce GT 710
Current Resolution 1920x1080 pixels
Work Resolution 1920x1040 pixels
State Enabled, Primary
Monitor Width 1920
Monitor Height 1080
Monitor BPP 32 bits per pixel
Monitor Frequency 60 Hz
Device \\.\DISPLAY1\Monitor0
Manufacturer NVIDIA
Model GeForce GT 710
Device ID 10DE-128B
Revision A2
Subvendor ASUStek Computer Inc (1043)
Current Performance Level Level 0
Current GPU Clock 953 MHz
Current Memory Clock 2505 MHz
Current Shader Clock 2505 MHz
Voltage 0.900 V
Technology 28 nm
Bus Interface PCI Express x8
Temperature 37 °C
Driver version 30.0.14.7414
BIOS Version 80.28.b8.00.05
Physical Memory 2047 MB
Virtual Memory 2048 MB
Count of performance levels : 3
Level 1 - "Perf Level 0"
GPU Clock 405 MHz
Shader Clock 405 MHz
Level 2 - "Base"
GPU Clock 954 MHz
Level 3 - "Boost"
GPU Clock 954 MHz
Je nějaká šance z aktuálně dostupných výrobků na trhu upgradovat tento starý stroj? Před pár lety mi vyhořela grafická karta, tak jsem koupil to, co tam teď je. Asi jsem v té době nechtěl moc utrácet za lepší, nebo možná jsem na tuto desku už jinou nesehnal. Grafickou kartu beru jako nejslabší článek. Není něco na trhu, co by bylo lepší?
Děkuji
Zivan
Re: Upgrade starého počítače
Příspěvek od Zivan »
Mě přijde jako zbytečná ztráta peněz tohle jakkoliv částečně upgradovat. SSD tam je, na stáří cca 16 let i dostatek RAM. Pokud nestačí, tak bych udělal kompletní výměnu.
Dyonysos
Příspěvek od Dyonysos »
Ahoj, ten stroj je už vážně historie. Podle mě se to nevyplatí upgradovat. Sestav si něco nového a zase budeš mít na pár roků pokoj.
Je na trhu neco co by bylo lepsi - v podstate cokoliv.
Problem je, ze s grafikou novejsi nez cca rok 2014 nespustis pocitac.
Principialne nema smysl davat zadnou novejsi grafiku, kdyz je tam procesor z roku 2007.
šulda
Příspěvek od šulda »
Lojza píše:Grafickou kartu beru jako nejslabší článek. Není něco na trhu, co by bylo lepší?
Pardon, ale celé téma mi přijde jako vtip. Člověk který chodí na fórum (i byť jen občas) 20let, by už mohl vědět že toto lze upgradovat jedině cestou na sběrný dvůr v luxusním voze.
Člověk se pořád učí.
Tam je jedina komponenta, kompatibilni s hardware z roku 2024 a tou je napajeci kabel.
Upgrade komponent z roku 2007 na dejme tomu komponenty z roku 2012 nema smysl. Je to 17 let stare!
Vzdyt ten pocitac musi mit problem otevrit slozitejsi internetove stranky a prehrat video z Youtube.
Ono "nebo možná jsem na tuto desku už jinou nesehnal." bych videl jako velice pravdepodobne. Nove grafiky
vyzaduji UEFI, ktere tvoje deska mit nemuze, protoze bylo zavedene pred 14 lety.
meda2016
Příspěvek od meda2016 »
@Lojza - Napiš, co na tom počítači spouštíš nebo potom budeš chtít spouštět..? A kolik Kč bys dal do nového? - Toto opravdu nejde nijak upgradovat pro vyšší výkon.
Aspoň tvůj monitor ASUS VP247 má HDMI.
Lojza
Poslední dobou nejvíce k upravě fotek, takze photoshop.
Photoshop na Core Duo z roku 2007 a pouhymi 8GB RAM musi byt nepouzitelny, jakmile otevres RAW, musi dojit pamet.
S Photoshopem zadna graficka karta nepomuze, vubec ji nepouziva.
To co potrebujes na Photoshop je novy procesor (uplne staci APU) a hlavne dostatek RAM, 32 GB by mohlo stacit.
Upgrade by se dal poridit do 5-7 tisic Kc, napriklad:
https://www.alza.cz/amd-ryzen-5-5600g-d6667494.htm
https://www.alza.cz/asus-tuf-gaming-a52 ... 489288.htm
https://www.alza.cz/kingston-fury-32gb- ... 622622.htm
Lojza
Hezky. Dekuji. Ta deska ma nejakou svoji grafickou kartu nebo by se to muselo taky neco dokoupit?
Konektory to ma, takze asi ne nutně, ze?
Dokážeš odhadnout, zda by se mi to veslo do te skrine. Zda ta deska je velikostne stejna, jako ta dosavadni.
Deska ne, procesor.
Deska je dokonce mensi (mATX, ty mas ATX).
Muzes mit i ATX desku, je lepsi i hardwarove kdybys na tom PC chtel hrat hry (a dokoupil grafiku), je ale drazsi:
https://www.alza.cz/msi-mpg-b550-gaming ... 100660.htm
Pocitej s tim, ze vymena zakladni desky zneplatni licenci Windows, pokud je to upgrade z Windows 7 nebo 8,
uz nepujdou znovu aktivovat.
Lojza
No to je škoda s těma windowsama. Ale teď uz je stejne nemuzu upgradovat na 11, kvuli tomu, ze ten procesor nesplnuje tu podminku.
Na tuhle desku uz lepši procesor nesezenu, co?
Jako nejaky starsi hry bych si nekdy zahral. Ale neco, co uz jsem na tohle driv hral, ale bojim se, ze ted s touhle grafarnou je to asi špatny. Když pustim treba nejaky film, ktery ma vic giga, tak se vubec prehravac nechyta.
  • Upgrade starého PC
    od Downylol » » v Rady s výběrem hw a sestavením PC
    9443 Zobrazení
    22 Odpovědi
    53939 Zobrazení
    Poslední příspěvek od Visitor
  • Historické počítače
    od ComputerAsylum » » v Vše ostatní (hw)
    12089 Zobrazení
    Poslední příspěvek od ComputerAsylum
  • Čištění počítače
    od Arnold91 » » v Vše ostatní (hw)
    26902 Zobrazení
  • Výběr počítače pro manžela do 40 tis.
    od Tovy » » v Rady s výběrem hw a sestavením PC
    9089 Zobrazení
    Poslední příspěvek od Tovy
