Problém ze zvukem s ALC1220-VB X470 AORUS ULTRA GAMING
heavyblack1
Příspěvek od heavyblack1 »
Zvuk je pouze ve sluchátkách ne v reproduktorech nemůžu v nastavení vybrat jiný zvukový vystup něž do sluchátek můj zvukový hw je ALC1220-VB pokusil jsem to spravit nainstalováním PipeWire os ubuntu 22.04
$ hwinfo --sound
32: PCI c00.1: 0403 Audio device
[Created at pci.386]
Unique ID: rwaR.b0tOCU4_vDC
Parent ID: IluS.CS5kfnTSviA
SysFS ID: /devices/pci0000:00/0000:00:03.1/0000:0a:00.0/0000:0b:00.0/0000:0c:00.1
SysFS BusID: 0000:0c:00.1
Hardware Class: sound
Model: "ATI Audio device"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0xab28
SubVendor: pci 0x1002 "ATI Technologies Inc"
SubDevice: pci 0xab28
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0xfcb20000-0xfcb23fff (rw,non-prefetchable)
IRQ: 120 (1226 events)
Module Alias: "pci:v00001002d0000AB28sv00001002sd0000AB28bc04sc03i00"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #19 (PCI bridge)
36: PCI e00.4: 0403 Audio device
Unique ID: ocSE.7C7D+k8gsC2
Parent ID: JZZT.YJhZDzGYdS4
SysFS ID: /devices/pci0000:00/0000:00:08.1/0000:0e:00.4
SysFS BusID: 0000:0e:00.4
Model: "AMD Starship/Matisse HD Audio Controller"
Vendor: pci 0x1022 "AMD"
Device: pci 0x1487 "Starship/Matisse HD Audio Controller"
SubVendor: pci 0x1458 "Gigabyte Technology Co., Ltd"
SubDevice: pci 0xa0c3
Memory Range: 0xfc900000-0xfc907fff (rw,non-prefetchable)
IRQ: 122 (5081 events)
Module Alias: "pci:v00001022d00001487sv00001458sd0000A0C3bc04sc03i00"
Driver Info #0:
Attached to: #34 (PCI bridge)
$ lspci -nnk | grep -A2 Audio
0c:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] [1002:ab28]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] [1002:ab28]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
0e:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
Subsystem: Gigabyte Technology Co., Ltd Starship/Matisse HD Audio Controller [1458:a0c3]
$ systemctl --user status pipewire pipewire-session-manager
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2024-04-20 11:37:20 CEST; 1h 31min ago
TriggeredBy: ● pipewire.socket
Main PID: 2162 (pipewire)
Tasks: 2 (limit: 115654)
Memory: 10.3M
CPU: 2.411s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─2162 /usr/bin/pipewire
dub 20 11:37:20 PCMR systemd[2155]: Started PipeWire Multimedia Service.
● wireplumber.service - Multimedia Service Session Manager
Loaded: loaded (/usr/lib/systemd/user/wireplumber.service; enabled; vendor preset: enabled)
Main PID: 2164 (wireplumber)
Tasks: 4 (limit: 115654)
Memory: 6.0M
CPU: 775ms
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/wireplumber.service
└─2164 /usr/bin/wireplumber
dub 20 11:37:20 PCMR systemd[2155]: Started Multimedia Service Session Manager.
dub 20 11:37:20 PCMR wireplumber[2164]: Failed to set scheduler settings: Operace není povolena
$ sudo dmesg | grep codec
[ 12.041667] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[ 12.041672] snd_hda_codec_realtek hdaudioC1D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 12.041674] snd_hda_codec_realtek hdaudioC1D0: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[ 12.041676] snd_hda_codec_realtek hdaudioC1D0: mono: mono_out=0x0
[ 12.041678] snd_hda_codec_realtek hdaudioC1D0: dig-out=0x1e/0x0
[ 12.041680] snd_hda_codec_realtek hdaudioC1D0: inputs:
[ 12.041682] snd_hda_codec_realtek hdaudioC1D0: Front Mic=0x19
[ 12.041684] snd_hda_codec_realtek hdaudioC1D0: Rear Mic=0x18
[ 12.041685] snd_hda_codec_realtek hdaudioC1D0: Line=0x1a
  • Opakovaný problém se zvukem
    od Bambi666 » » v Windows 11, 10, 8...
    4032 Zobrazení
    Poslední příspěvek od kecalek
  • Ultra Wide Monitor
    od TheDoctorWhoCZ » » v Rady s výběrem hw a sestavením PC
    5325 Zobrazení
  • seznam pc her s detaily na ultra s 128 bitovou sběrnici a QHD 1440p
    9025 Zobrazení
  • High-end Gaming PC do 70K
    10989 Zobrazení
  • Klavesnica gaming
    12533 Zobrazení
