Dochádza k zamŕzaniu obrazu ale len počas sledovania napr. Twitch a Youtube. Hry alebo rôzne stress test programy na GPU, všetko je v poriadku. Vymenil som GPU, použil DDU, ale problém zostava. Iný problém ktorý sa mi občas prejavuje, po zastavení videa na Youtube niekedy dojde k zníženiu jasu, proste obraz stmavne. Po spustení pokračovania videa obraz opäť získa pôvodný jas. V event viewer sa hlási len udalosť zamrznutia obrazu a to ako : The description for Event ID 14 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\0000007c
0000(0000) 00000000 00000000
The message resource is present but the message was not found in the message table
Môj HW v skratke : mobo Apex XI, psu evga 750, old gpu asus 2070 super, new gpu msi 3070
Viete mi poradiť čo s tým ?
Zamŕzanie obrazu
- pcmaker
- Level 4
Re: Zamŕzanie obrazu
Otestuj RAM a Disk(y).
EX-RAPTOR-SR
- nováček
Memtest vysiel v poriadku. SSD mam cez aky soft otestovat?pcmaker píše:Otestuj RAM a Disk(y).
Dodatečně přidáno po 16 minutách 33 vteřinách:
Microsoft (R) Windows Debugger Version 10.0.22549.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
Dump completed successfully, progress percentage: 100
************* Path validation summary **************
Response Time (ms) Location
Deferred srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 22000 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Edition build lab: 22000.1.amd64fre.co_release.210604-1628
Machine Name:
Kernel base = 0xfffff803`39400000 PsLoadedModuleList = 0xfffff803`3a029b90
Debug session time: Sun Mar 13 13:46:41.756 2022 (UTC + 1:00)
System Uptime: 0 days 1:13:16.466
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff803`398164c0 48894c2408 mov qword ptr [rsp+8],rcx ss
3: kd> !analyze -v
* Bugcheck Analysis *
VIDEO_TDR_FAILURE (116)
Attempt to reset the display driver and recover from timeout failed.
Arguments:
Arg1: ffffde8f1fb30460, Optional pointer to internal TDR recovery context (TDR_RECOVERY_CONTEXT).
Arg2: fffff8035531cfe8, The pointer into responsible device driver module (e.g. owner tag).
Arg3: ffffffffc000009a, Optional error code (NTSTATUS) of the last failed operation.
Arg4: 0000000000000004, Optional internal context dependent data.
Debugging Details:
Unable to load image \SystemRoot\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_3b12ac0f95b18b9d\nvlddmkm.sys, Win32 error 0n2
Page 1081c2 not present in the dump file. Type ".hh dbgerr004" for details
tychto PAGE..... tam je asi cez 1000 tie vynecham a takto konci analyza :
Page 1056c7 not present in the dump file. Type ".hh dbgerr004" for details
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 2077
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 4045
Key : Analysis.Init.CPU.mSec
Value: 327
Key : Analysis.Init.Elapsed.mSec
Value: 5621
Key : Analysis.Memory.CommitPeak.Mb
Value: 109
Key : WER.OS.Branch
Value: co_release
Key : WER.OS.Timestamp
Value: 2021-06-04T16:28:00Z
Key : WER.OS.Version
Value: 10.0.22000.1
FILE_IN_CAB: MEMORY.DMP
DUMP_FILE_ATTRIBUTES: 0x1000
BUGCHECK_CODE: 116
BUGCHECK_P1: ffffde8f1fb30460
BUGCHECK_P2: fffff8035531cfe8
BUGCHECK_P3: ffffffffc000009a
BUGCHECK_P4: 4
VIDEO_TDR_CONTEXT: dt dxgkrnl!_TDR_RECOVERY_CONTEXT ffffde8f1fb30460
Symbol dxgkrnl!_TDR_RECOVERY_CONTEXT not found.
PROCESS_OBJECT: 0000000000000004
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
PROCESS_NAME: System
STACK_TEXT:
ffff8483`4d947768 fffff803`4ff4883e : 00000000`00000116 ffffde8f`1fb30460 fffff803`5531cfe8 ffffffff`c000009a : nt!KeBugCheckEx
ffff8483`4d947770 fffff803`4ff05e66 : fffff803`5531cfe8 ffffde8f`15f75010 00000000`01000000 ffffde8f`15f750d0 : dxgkrnl!TdrBugcheckOnTimeout+0xfe
ffff8483`4d9477b0 fffff803`4feff80b : ffffde8f`16ec9000 00000000`00000040 00000000`00000002 00000000`00000002 : dxgkrnl!ADAPTER_RENDER::Reset+0x12a
ffff8483`4d9477e0 fffff803`4ff47f95 : 00000000`1d5901e0 ffffde8f`1cfdb040 00000000`00000000 ffffde8f`1d5989e0 : dxgkrnl!DXGADAPTER::Reset+0x607
ffff8483`4d947890 fffff803`4ff480f2 : 00000000`00000000 00000000`00000000 00000000`00000200 fffff803`3a133680 : dxgkrnl!TdrResetFromTimeout+0x15
ffff8483`4d9478c0 fffff803`396d0f2f : ffffde8f`1cfdb040 ffffde8f`11302ce0 fffff803`00000000 ffffde8f`00000000 : dxgkrnl!TdrResetFromTimeoutWorkItem+0x22
ffff8483`4d947900 fffff803`3965a8b5 : ffffde8f`1cfdb040 ffff9b01`60de1000 ffffde8f`1cfdb040 fffff803`3981f907 : nt!ExpWorkerThread+0x14f
ffff8483`4d947af0 fffff803`3981a574 : ffff9b01`60dd2180 ffffde8f`1cfdb040 fffff803`3965a860 00000000`00000000 : nt!PspSystemThreadStartup+0x55
ffff8483`4d947b40 00000000`00000000 : ffff8483`4d948000 ffff8483`4d941000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x34
SYMBOL_NAME: nvlddmkm+e2cfe8
MODULE_NAME: nvlddmkm
IMAGE_NAME: nvlddmkm.sys
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x116_IMAGE_nvlddmkm.sys
OS_VERSION: 10.0.22000.1
BUILDLAB_STR: co_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
Followup: MachineOwner
Tuto chybu mi hlasi odkedy som vypol hardwerovu akceleraciu v Chrome a Edge, vypol som ju na skusku, pri hladani riesenia tohto isteho problemu, kde mi dochadza pri pouzivani Chrome a Edge k zamrznutiu PC a restartu.
Pri zapnutej hardwerovej akceleracii sa hlaska chyby v minidump zmeni na 0x133_ISR_nvlddmkm!unknown_function
Ci uz mam akceleraciu zapnutu alebo vypnutu, mrzne mi PC rovnako len sa meni hlasenie chyby 0x133 za 0x116.
Co jsem našel, tak ta chyba souvisí s corsair programama. Máš nějaký corsair program nainstalovaný? Pokud ano, můžeš je na test odinstalovat? A určitě preinstaluj ovladače grafické karty. Čistou instalaci, tedy, odstranit předcházející drivery a nainstalovat nové.
EX-RAPTOR-SR
- nováček
- pcmaker
- Level 4
Pusť na něj Error Scan v programu HD Tune. Nezatrhávej Quick Scan.
EX-RAPTOR-SR
- nováček
