minecraft nefunguje
A vše kolem nich…
magor
minecraft nefunguje
Příspěvek od magor »
Ahoj, minecraft mi hází to. Co mám dělat? Děkuji za odpovědi
Nainstalování nové verze programu grafické karty nepomáhá
---- Minecraft Crash Report ----
// I just don't know what went wrong :(
Time: 5.6.19 20:02
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at ave.ap(SourceFile:534)
at ave.am(SourceFile:363)
at ave.a(SourceFile:310)
at net.minecraft.client.main.Main.main(SourceFile:124)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:131)
at net.minecraft.launchwrapper.Launch.main(Launch.java:27)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.9
Operating System: Windows 10 (x86) version 10.0
CPU: <unknown>
Java Version: 1.8.0_191, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 9580008 bytes (9 MB) / 143396864 bytes (136 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
OptiFine Version: OptiFine_1.8.9_HD_U_I7
Render Distance Chunks: 8
Mipmaps: 4
Anisotropic Filtering: 1
Antialiasing: 0
Multitexture: false
Shaders: null
OpenGlVersion: null
OpenGlRenderer: null
OpenGlVendor: null
CpuCount: 4
magor
Re: minecraft nefunguje
HappyMental
Příspěvek od HappyMental »
Co to je za pc?
I use Arch BTW
magor
aho,j je to Intel Core i5-2500, DELL 06D7TR, Sapphire RX 560 Pulse 4GB, 8 GB ram
flowem
Příspěvek od flowem »
Je ta hra koupená?
magor
ano
flowem
Hrál jsi to už někdy předtím? Nebo jak se chyba začala projevovat? Máš novou Javu?
magor
Ahoj, na tomto kompu jsem to ještě nehrál. Novou Javu mám.
Turion
Příspěvek od Turion »
Nejedeš náhodou na integrovanou grafiku na které je jen základní mikrosoftí ovladač? Máš kabel od monitoru do grafiky nebo základní desky?
flowem
Popř. sem hoď screen do přílohy ze správce zařízení s rozbalenou nabídkou grafické adaptéry.
magor
Kabel mám do základní desky.
HappyMental
Tak jej zapoj do grafické karty. Pokud máš kabel zapojený v desce, jedeš přes integrovanou grafiku.
I use Arch BTW
  • Nefunguje nová PC
    10970 Zobrazení
    21 Odpovědi
    19106 Zobrazení
    Poslední příspěvek od mk7605
    10522 Zobrazení
    Poslední příspěvek od kecalek
    10284 Zobrazení
    Poslední příspěvek od Atjov1
Zpět na „Hry“
