upgrade grafické karty
magiw
Příspěvek od magiw »
Dobrý den, mám tuto sestavu a chtěl bych se zeptat jestli mi tam budou fungovat dobre graficke karty řady Geoforce RTX děkuji za odpověď
Driver Easy TXT Report
Binaries
Driver Easy version V 5.6.2
Overview
Machine Micro-Star International Co., Ltd. - MS-7B46
Operation System Microsoft Windows 10 Home (64-bit)
Memory 16 GB
Processor Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
Motherboard Micro-Star International Co., Ltd. - Z370 KRAIT GAMING (MS-7B46)
Video Cards NVIDIA GeForce GTX 960
Monitors ASUS VG278
Hard Disk KINGSTON SHSS37A240G (240,0 GB)
Network Card Intel(R) Ethernet Connection (2) I219-V
CPU
Processor
Name Intel Core i5
Code Name Kaby Lake
TDP 95 W
Package Socket 1151 LGA
Technology 14 nm
Core Voltage 1,29 V
Specification Intel(R) Core(TM) i5-8600K CPU @ 3.60GHz
Family 6
Model --
Stepping --
Ext. Family --
Ext. Model --
Revision --
Instructions MMX , SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, x86-64, NX, VMX, AES, AVX, AVX2, FMA3, TSX
Clocks
Core Speed 4299 MHz
Multiplier x 43
Bus Speed 100 MHz
QPILink --
Cache
L1 Data 6 x 32 KBytes
L1 Inst 6 x 32 KBytes
Level 2 6 x 256 KBytes
Level3 9216 KBytes
Motherboard
Motherboard
Manufacturer Micro-Star International Co., Ltd.
Model Z370 KRAIT GAMING (MS-7B46) 1.0
Chipset Intel ID3EC2
Revision 07
Southbrige Intel IDA2C9
Revision 00
LPCIO --
BIOS
Core Speed American Megatrends Inc.
Version 1.00
Date 08/29/2017
Graphic Interface
Version --
Transfer Rate --
Max. Supported --
Memory
General
Type --
Size 16384 MBytes
Channel# --
DC Model --
NB Frequency --
Timings
DRAM Frequency --
FSB:DRAM --
CAS# Latency(CL) --
RAS# to CAS# Delay(tRCD) --
RAS# Precharge(tRP) --
Cycle Time(rRAS) --
Bank Cycle Time(rRC) --
Command Rate(CR) --
Graphics
GPU
Name NVIDIA GeForce GTX 960
Manufacturer 17236486
Code Name GM206
Technology 28 nm
Revision --
Clocks
Core 1303,6 MHz
Shader --
Memory 3505,5 MHz
Memory
Size 4096 MBytes
Type 8
Bus Width --
xbs
Re: upgrade grafické karty
Příspěvek od xbs »
jo, v klidu zvládne RTX2080...
Michael850
Příspěvek od Michael850 »
Neměl by být problém. Ještě bych ale zvážil, jestli se ti nevyplatí místo do Turingu jít spíš do Pascalu...
  • Upgrade grafické karty
    7294 Zobrazení
  • Výměna grafické karty
    13749 Zobrazení
    6839 Zobrazení
    13460 Zobrazení
    8163 Zobrazení
