Padání Crysis a CS:GO
A vše kolem nich…
b.m
Re: Padání Crysis a CS:GO
Příspěvek od b.m »
Tohle jsem posílal dřív, ale bylo to v komentech, tak nevim, jestli jsi to našel:
I found a solution for me. Solution was going to "C:\Program Files (x86)\Steam\SteamApps\common\Counter-Strike Global Offensive\csgo" doing a backup of the "cfg" folder and name it something like "cfg_backup" just cause if something goes wrong and I need to reuse some stuff there. Then I clicked the original "cfg" folder, deleted it completely, restarted steam, opened the game, went into a community server to see if the problem happened, it didn't, I recreated the folder and only put my Autoexec there. First time I went in-game I typed the "exec autoexec" once and there you go, my problem didn't persist anymore, hope it helps anyone.
Další možnost:
Edit 2: A better solution to the crashing is mentioned by calvinxquizit below. Keep your autoexec file in your cfg folder. Then take note of your video settings in help and options ingame. Delete your video.txt located at C:\Program Files\Steam\SteamApps\common\Counter-Strike Global Offensive\csgo\cfg\ and just redo your video settings to what they were before.
go into cfg folder and delete " video.txt " you will have to redo your video settings but it will fix your crash on load problem.
Ryzen 7 5700x3D, 4 x ADATA XPG GAMMIX D10 8GB DDR4 3000, ASRock AB350M Pro4, Sapphire Radeon RX 6700 XT, Kingston A2000 500GB, RM 650x, Fractal Design Define Mini, SilentiumPC Fera 3
Donator_HD
Příspěvek od Donator_HD »
Zkusil jsem a pořád to nefunguje :D
CPU: AMD Ryzen 7 2700,RAM: HyperX Furry Black Series 2X8GB 2666MHz,GPU: SAPPHIRE Radeon RX 470 8GB Nitro+,MB: MSI TOMAHAWK B450 MAX,PSU: EVGA 650 GQ
b.m
Příspěvek od b.m »
Tak to je nějaký marný :lol: . Když jsi měl v pc jenom jeden paměťovej modul, tak to bylo ok?
To už snad jedině si zkusit nějak pohrát v nastavenim pamětí, časování, frekvence, ale nevim teda jak.
Donator_HD
Ani když jsem měl jenom jednu ramku tak to nešlo, jenom po upgradu. Ale nějaký časování ramek CL16 CL 17 to je španělská vesnice :D Takže asi RIP :D
Dodatečně přidáno po 43 vteřinách:
Každopádně děkuju za pomoc a tvůj čas!
dvorakj
Master Level 7
Master Level 7
Příspěvek od dvorakj »
otestuj si RAM memtestem. RAM nastav jak mas dle parametru.bpak test - boot z flashky
uvolni misto na disku aspon 20 % by melo byt prazdne misto
disk otestuj pomoci HDTune
pak si soust prime95 a furmark aspon na hodinu.
jak to bude ok, uvidi se dal.
Donator_HD
Všechny testy jsou úspěšný, ten memtest přes boot z flešky jsem na základní rychlost dělal 2x8GB (2666Mhz), nenašlo to žádnou chybu, ale jakmile jsem se dostal do windowsu, hned to začalo padat, tak to mám na 2400MHz taky to nenašlo žádnou chybu a jede to v pohodě.
Dodatečně přidáno po 35 vteřinách:
CS:GO mám na HDD, ne na SSD
dvorakj
Master Level 7
Master Level 7
ten memtest se mi nezda, jak dlouho ti to jelo?
mas to urcite spatne nastavene v BIOSu.
uvolni misto na disku, aspon 20 % by melo byt prazdne misto
pak si spust prime95 a furmark aspon na hodinu.
Donator_HD
Ten memtest jel asi 2 hodiny 45 minut, zbytek jsem udělal už.
A pochybuju že by bylo něco špatně v biosu nastavený, zkoušel jsem cokoliv a i jsem několikrát dával defaultní nastavení.
b.m
Příspěvek od b.m »
Dneska mi CS tahalo nějakou aktualizaci, zkus, jestli to náhodou neni ok už.
Pokud jsi nezkoušel (už se v tom ztrácim :lol:), zkus dát grafiku na minimum, co to udělá.
Případně pokud máš místo na disku, můžeš tam zkusit hodit i třeba Win 7/Linux , jestli na tom to CS bude fungovat.
Pokud by to nefungovalo ani tam, už by musel bejt snad nějakej HW problém, což by mi ale přišlo divný, že by se to projevovalo jen u CS.
Donator_HD
Já žádnou aktualizaci neměl, alespoň o tom nevím, to s tou nízkou grafikou jsem už zkoušel, napsal mi to nějakej cápek na Steam Podpoře, stejně tak vypnout anti-aliasing nebo vícejádrový vykreslování. Nepomohlo to. A windows přeinstalovávat nechci a dělat další kraviny s PC taky nechci, nemám na to ani náladu už, to už mi líp vyjde ten nefunkční trash odinstalovat a na steam pod hru napsat milou recenzi :Dddd
Každopádně bych se chtěl ještě zeptat co v AMD Adrenalin (nastavení, grafické karty, pokročilé) znamená Zatížení GPU s výběrem Grafické karty a vypočítat a proč mi to ve Výkonnosti, hodnoty ukazuje, že mi procesor i při zátěži ukazuje 0 procent využití. Díky
behavioralista
Příspěvek od behavioralista »
Po výměně těch komponent proběhla nová instalace windows nebo ne?
dvorakj
Master Level 7
Master Level 7
mas to cele nejake divne, navic to pises zmatene.
furmark+prime nevime, misto na disku nevime.
hdtune nevime.
dej si bios default a preinstaluj win. to je nejrychlejsi metoda, cca 30 min.
  • Zamrzání PC a padání her
    od doldy » » v Problémy s hardwarem
    5050 Zobrazení
    Poslední příspěvek od rohlicek1
    9752 Zobrazení
Zpět na „Hry“
