localhost a wordpress přestaly fungovat?
Natalie_
Re: localhost a wordpress přestaly fungovat?
Příspěvek od Natalie_ »
_hm píše:ngrok je teď kompletně odinstalován?
Ano, je odinstalován.
CZechBoY
Master Level 9.5
Master Level 9.5
Příspěvek od CZechBoY »
To co si poslala je pripojeni k mysql - k te se pripojuje aplikace, konfigurace je nejspis nejaky config.php
iPhone XS
Natalie_
CZechBoY píše:To co si poslala je pripojeni k mysql - k te se pripojuje aplikace, konfigurace je nejspis nejaky config.php
// ** MySQL settings - You can get this info from your web host ** //
/** The name of the database for WordPress */
define( 'DB_NAME', 'wordpress' );
/** MySQL database username */
define( 'DB_USER', 'root' );
/** MySQL database password */
define( 'DB_PASSWORD', 'root' );
/** MySQL hostname */
define( 'DB_HOST', 'localhost' );
/** Database Charset to use in creating database tables. */
define( 'DB_CHARSET', 'utf8mb4' );
/** The Database Collate type. Don't change this if in doubt. */
define( 'DB_COLLATE', '' );
* Authentication Unique Keys and Salts.
* Change these to different unique phrases!
* You can generate these using the {@link https://api.wordpress.org/secret-key/1.1/salt/ WordPress.org secret-key service}
* You can change these at any point in time to invalidate all existing cookies. This will force all users to have to log in again.
* @since 2.6.0
define( 'AUTH_KEY', '.EB#t7~oIfWA@*b}z>->Mw4&A?W58GaGTnRGVu:ivn^a-g88cwWpFx-/bks**pp/' );
define( 'SECURE_AUTH_KEY', ']^MK:1WYldG L#Wp(._E/c<7;3G/pH%$(G<%o+I?i$U0~:zX|wTvNb%g.R2.R((V' );
define( 'LOGGED_IN_KEY', 'D8i)9rC@JS~>!o_^>L!*ROOMFD z8Uk4jad~:O?t{9J$S<f7r79YIeVDq}d.UEV+' );
define( 'NONCE_KEY', 'e=,&qg8F6j+JW,Sm{TvMvDd:B|y}WY?Z [rc$L0$S8IJKSw3)@`8>a91z0.I&#N%' );
define( 'AUTH_SALT', 'h_NH!L(,;_2to3FiS0 x#2-{629`eL~A4C-ex^YeN}DbWfx)EHlYA~|yQxAy{)~d' );
define( 'SECURE_AUTH_SALT', 'Bv%-l-T<O#2zjYcw{fNT*N uv&a]j@zdDopoW^acX$1)2}t)gFcw4E3ooMW4 6_i' );
define( 'LOGGED_IN_SALT', '5G/ScB6q{!fhPYR12Cr`{kDmd;Rj#Dc0TM]~?~D=8U_~7-s7;6*,kN8IVny6i*Fq' );
define( 'NONCE_SALT', 'Xj9Q*KpeJ ta.Zrduifj!L>EaMmI0SAEi^v/@@ld)<&Gn(qKs;o8nHchNlFEevdG' );
* WordPress Database Table prefix.
* You can have multiple installations in one database if you give each
* a unique prefix. Only numbers, letters, and underscores please!
$table_prefix = 'wp_';
* For developers: WordPress debugging mode.
* Change this to true to enable the display of notices during development.
* It is strongly recommended that plugin and theme developers use WP_DEBUG
* in their development environments.
* For information on other constants that can be used for debugging,
* visit the documentation.
* @link https://wordpress.org/support/article/d ... wordpress/
define( 'WP_DEBUG', false );
/* That's all, stop editing! Happy publishing. */
/** Absolute path to the WordPress directory. */
if ( ! defined( 'ABSPATH' ) ) {
define( 'ABSPATH', __DIR__ . '/' );
/** Sets up WordPress vars and included files. */
require_once ABSPATH . 'wp-settings.php';
_hm
Příspěvek od _hm »
Jestli máš zazálohováno všechno, co jsi vytvořila či změnila, nepomohlo by kompletní odinstalování wordpressu a MAMP a jejich nové nainstalování?
Natalie_
Skoro všechno, to co jsem vytvořila přímo ve WP ne, proto jsem chtěla zjistit, čím to je, kdyby se po popř. znovu opakovalo. Asi to bude ale nejjednodušší takhle, zkusím to a uvidíme
Dodatečně přidáno po 37 minutách 44 vteřinách:
Tak to funguje..Ztratilo se mi teda víc věcí než jsem čekala, ale to se dodělá.. Zajímalo by mě akorát, čím to bylo, jestli něco udělal ten ngrok..a proč mi vlastně nefungoval.. (kdyby se někdo nudil a rád mi pomohl s tím ngrokem, třeba už ve zprávách, ať to tu nespamujem, budu mu opravdu nadosmrti vděčná :D ).. ale hlavně že můžu pokračovat ve webu..
Po nové instalaci MAMPu, když jsem se přihlašovala k serveru mi vyskočlo "Apache couldn't be started because port 8888 is in use by some other software." Pomohla změna portu.. ale kdybych chtěla používat pořád 8888, je něco, jak to udělám?
_hm
Příspěvek od _hm »
S ngrokem neporadím. Leda snad - příště před jeho instalací zazálohovat úplně všechno, co souvisí s MAMPem a wordpressem, pak instalovat ngrok a když se to zas podělá, porovnat obsahy všech aktuálních souborů se zálohou a zjistit změny. Na podobné pokusy se často doporučují virtuální počítače.
S portem 8888 se dá udělat to, že se vypne program, který si ho připojil. V macOs by, podle internetu, měl fungovat příkaz "lsof" (bez ovozovek) a "lsof -iTCP -sTCP:LISTEN" by mohl vypsat seznam obsazených portů včetně příslušných procesů.
    17 Odpovědi
    35452 Zobrazení
    Poslední příspěvek od rhsCZ
  • Budou tyto CD/DVD mechaniky fungovat?
    22 Odpovědi
    152325 Zobrazení
