Problém s internetem
Fjúčuring
Re: Problém s internetem
Příspěvek od Fjúčuring »
Windows IP configuration
Host name.................................... : Desktop
Primary DNS suffix.......................:
Node Type.....................................: Hybrid
IT Routing Enabled...................... : No
WINS Proxy Enabled....................: No
DNS Suffix Search List................: Home
Ethernet adapter Ethernet 3:
Media State.........................................: Media disconnected
Connection-specifics DNS Suffix.....:
Description..........................................: Tap-Windows Adapter V9
Psychical Address..............................: 00-FF-A6-A7-4C-DD
DHCP Enabled.....................................: Yes
Autoconfiguration Enabled............... : Yes
Ethernet adapter Ethernet 4:
Media State............................................: Media disconnected
Connection - specifics DNS Suffix......:
Description.............................................: Tap-ProtonVPN Windows Adapter V9
Physical Address...................................: 00-FF-CD-E7-FB-13
DHCP Enabled........................................: Yes
Autoconfiguration Enabled...................: Yes
Ethernet adapter Ethernet :
Connection-specifics DNS suffix.........: Home
Description..............................................: Intel (R) Ethernet Connection (2) I219-V
Physical Address....................................: 2C-FD-A1-E2-DC-81
DHCP Enabled..........................................: Yes
Autoconfiguration Enabled ....................: Yes
Link-Local IPv6 Address .........................: fe80: :b107:653c:642f:f433%6(preferred)
IPv4 Address ............................................: 10.0.0.2(preferred)
Subnet Mask.............................................: 255.255.255.0
Lease Obtained.........................................: 16.září 2019 19:25:46
Lease Expires............................................: 17.září 2019 21:19:57
Default Gateway........................................: 10.0.0.138
DHCP Server..............................................: 10.0.0.138
DHCPv6 IAID..............................................: 237829537
DHCPv6 Client DUID..................................: 00-01-00-01-24-9A-F6-A1-2C-FD-A1-E2-DC-81
DNS Servers...............................................: 10.0.0.138fe80: :1%6
NETBIOS over Tcpip..................................: Enabled
Dodatečně přidáno po 5 minutách 12 vteřinách:
Na routeru svítí tyto diody
Power
ETHERNET
WLAN
DSL............. která bliká zeleně a po chvilce oranžově.
Internet....... nesvítí
Fjúčuring píše:Na všech adaptérech je napsáno.... Media disconnected
Tady jsi lhal. Adaptér ethernet (bez čísla) je normálně nakonfigurován. A protože na modemu nesvítí internet, je chyba mezi modemem a přípojným místem. Obrať se na providera.
Někdy pomůže jen vypnout počkat minutu a zapnout modemrouter.
Pokud jsi udělal reset do továrního nastavení, pak jsi přišel o veškerou konfiguraci. K připojení jsi dostal dokumentaci, kde je napsáno, jak nastavit router. Jinak opět provider.
Fjúčuring
Děkuji, zkusím.
Dodatečně přidáno po 8 minutách 54 vteřinách:
Modem jsem vypnul, počkal minutu a stále se nedá používat. Vyúčtování máme zaplacené provider nám řekl, že si máme půjčit modem z pobočky poskytovatele služeb a pokud nebude půjčený reuter fungovat, tak potom budou řešit problém u nich.
Dodatečně přidáno po 7 hodinách 59 minutách 35 vteřinách:
Teď se mi internet zapíná a vypíná po dvou minutách. Vůbec nevím, co to je. Ví to někdo?
  • Problém s internetem
    19668 Zobrazení
    13746 Zobrazení
  • problem s ventilátorem
    33268 Zobrazení
    Poslední příspěvek od Sambala
  • Problém s mikrofonem
    10888 Zobrazení
  • Problem s nabijanim
    17933 Zobrazení
