minecraft nefunguje
A vše kolem nich…
magor
Re: minecraft nefunguje
Příspěvek od magor »
aha, ale já mám monitor jen na vga :(
HappyMental
Příspěvek od HappyMental »
Tak musíš koupit redukci. Redukce DVI->VGA stojí pár korun.
I use Arch BTW
Jestli ta karta nema D/A prevodnik, tak zadna redukce na svete nebude fungovat.
Tazatel na otazku zda ma nejnovejsi Javu odpovedel ze ANO.
Scerrenshot ktery dal ale ukazuuje ze odpoved je NE.
magor
---- Minecraft Crash Report ----
// I just don't know what went wrong :(
Time: 9.6.19 15:19
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:252)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at bsu.am(SourceFile:523)
at bsu.aj(SourceFile:352)
at bsu.a(SourceFile:299)
at net.minecraft.client.main.Main.main(SourceFile:120)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8
Operating System: Windows 10 (x86) version 10.0
Java Version: 1.8.0_211, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 101408544 bytes (96 MB) / 158208000 bytes (150 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8
LWJGL: 2.9.1
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs: []
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
To uz je lepsi.
Nemas nainstalovanou 32bit verzi Windows ?
magor
Ne, nemám
Tak prečo máš už aj v prvom príspevku :
magor
AHA tak možná mám
Podivej se do vlastnosti pocitace v systemu (ovladaci panely).
Pokud ano, tak mas 8 GB RAM a 4 GB VRAM a z tech 12 GB mas pouzitelne pouze 4 GB (RAM + VRAM).
Otazka jestli to Minecraft hlasi jako verzi Windows nebo proto ze pouziva 32bit Javu.
Ja bych cekal ze bude hlasit Windows 10 (amd64) version 10.0
magor
Windows je 64 bit
magor
Uz mas ten prevodnik na VGA nebo monitor s digitalnim vstupem ?
  • Nefunguje nová PC
    11015 Zobrazení
    21 Odpovědi
    19178 Zobrazení
    Poslední příspěvek od mk7605
    10572 Zobrazení
    Poslední příspěvek od kecalek
    10291 Zobrazení
    Poslední příspěvek od Atjov1
Zpět na „Hry“
