Prosim pomozte!!!
Tak malá změna, zkusil jsem si vyhledat, o co se knihovna advpack.dll opravdu stará a zde je výsledek:
http://www.auditmypc.com/process/advpack.asp
advpack.dll
advpack.dll - Here is the scoop on Advpack Library. The big question: what is advpack.dll and is it spyware, a trojan and if so, how do I get rid of Advpack Library?
advpack.dll (Advpack Library) - Details
The library file advpack.dll is required for windows to operate. It is used by windows to verify .inf files. If advpack.dll is unavailable, windows will not function correctly.
advpack.dll is flagged as a system process and does not appear to be a security risk. However, removing Advpack Library may adversly impact your system.
The Spy Bot database currently registers advpack.dll to Microsoft.
This is part of Microsoft Windows.
Whenever you have a concern about a file like advpack.dll, feel free to visit our free spyware removal page to help verify your file is not a security risk.
The Spy Bot database is updated often, but inaccuracies may still exist, often caused by viruses named after valid files such as Advpack Library. Always verify your results just to play it safe.
ADVPACK.DLL - Disclaimer
Every attempt has been made to provide you with the correct information for advpack.dll or ADVPACK LIBRARY. Many spyware/malware programs use filenames of usual, non-malware programs. If we included information about a file that is inaccurate, we would greatly appreciate your help by dropping us a comment and we'll promptly correct it.
You should verify the accuracy of information we provided about advpack.dll. Advpack Library may have had a status change since this page was published.
Čili chápu-li to dobře, advpack.dll používají Windows k ověřování .inf souborů. Odinstalací tebou zmiňovaného software mohlo dojít k poškození této knihovny a myslím si, že by stálo za to zkusit nakopírovat tenhle soubor z jiných Windows - napiš mail, pošleme ti ho a uvidíme.
advpack.dll
Rimms
muj email je: erebos@email.cz predem diky moc!
jinak mam Soundblaster Live!, ale na desce mam i integrovanou - kdyz se kouknu do spravce zarizeni, tak je tam jedno nezname zarizeni - Řadič jednoduché komunikace pro sběrnici PCI- ktery nevim co je a ani k nemu nemam ovladace- kdyz si je dam najit automaticky, nic mi to nenajde a jeste se to kousne - at dam storno, nbeo zpet- stale hleda a hleda...
Umístění: Patice PCI 4 (Sběrnice PCI 0, zařízení 11, funkce 0) - mozna ze by to mohlo byt ono... - neda se nejak vypnout zvukovka integrovana na desce? na desce by jeste mela byt sitovka- ale sitovou kartu mam nalezenou SiS 900 PCI Fast Ethernet Adapter, tak nevim.
Lummox: Přes co se připojuješ k internetu? Pomocí modemu asi ne viď? Protože tebou zmiňovaný problém ve správci zařízení - Řadič jednoduché komunikace pro sběrnici PCI - se týká právě modemu.
Nemusí to s naším problémem nijak souviset, ale může......jestli ho nepoužíváš, tak ho jednoduše zakaž (pravým tlačítkem na něj a dát zakázat) no a pokud ho potřebuješ, napiš typ desky a nějaký ten driver se najde.
V BIOSu by se měla zvukovka vypínat snad v Peripherals..
Miras: díky za odeslání, uvidíme co to udělá..
Rimms
ted jsem prochazel comp a nasel jsem nejake divne soubory primo u mne a nevim, jestli s tim treba nesouvisi:
C:\Documents and Settings\Martin\ErrorLog - textovy dokument
C:\Documents and Settings\Martin\intlname.ols
C:\Documents and Settings\Martin\NTUSER.dat
dal bych je sem ke sdileni, ale to asi toto forum nepodporuje...
Premyslel jsem a premyslel cim by to mohl byt- a vzpomnel jsem si, ze jsem nekdy pocatkem tohoto roku experimentoval s vyladenim PC, aby slapalo rychleji - jednou z veci, co jsem delal bylo odstraneni Windows Messengera, ktery mne stale otravoval - to jsem delal podle navodu z PCTUNNINGU - kdyz jsem to ted prohlizel, tak toto odstraneni vyzadovalo praci s knihovnou advpack.dll, se kterou jsou ted potize- tto by mohlo mit souvislost, ne???
I kdyz je mi divne, ze to skoro 2 mesice slapalo bez problemu- az ted...
Zde je odkaz na to, co jsem delal - bod 7:
http://www.pctuning.cz/titulnistrana/la ... rtId=20618
OK, uz se na to psychicky pripravuju!!
Ted mam teda jeste jeden dotaz- pomuze oprava windows? nebo jak se jmenuje ta vec, jak se vlastne preinstalujou windowsy, ale programy a nastaveni zustanou stejna??
kdyz nainstaluju NOVE windowsy a ty budou jine verze, nez puvodni - sice oboji XP, ale driv Home SP1 a dodany SP2, nyni Proff SP2 - a budu chtit zachovat svuj profil- pujde to? Jde mi o to, aby se mi nejak nesmazaly data, co jsou nyni v mem profilu (C:\Documents and Settings\Martin\...) protoze druhy disk nemam tak velky, aby vse pojmul- chtel bych se vyhnout formatovani disku... takze staci treba jen data presunout do nejakeho adresare, primo na dsku C??? Napr: C:\Data\... ???
- 5677 Zobrazení
- 5696 Zobrazení
- 4981 Zobrazení
- 10891 Zobrazení
- 3361 Zobrazení
