po spuštětní dcdiag /f: mi vypíšeš chybu :
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site-Name\MSSERVER
Starting test: Connectivity
......................... MSSERVER passed test Connectivity
Doing primary tests
Starting test: Replications
......................... MSSERVER passed test Replications
Starting test: NCSecDesc
......................... MSSERVER passed test NCSecDesc
Starting test: NetLogons
......................... MSSERVER passed test NetLogons
Starting test: Advertising
......................... MSSERVER passed test Advertising
Starting test: KnowsOfRoleHolders
......................... MSSERVER passed test KnowsOfRoleHolders
Starting test: RidManager
......................... MSSERVER passed test RidManager
Starting test: MachineAccount
......................... MSSERVER passed test MachineAccount
Starting test: Services
......................... MSSERVER passed test Services
Starting test: ObjectsReplicated
......................... MSSERVER passed test ObjectsReplicated
Starting test: frssysvol
......................... MSSERVER passed test frssysvol
Starting test: frsevent
......................... MSSERVER passed test frsevent
Starting test: kccevent
......................... MSSERVER passed test kccevent
Starting test: systemlog
An Error Event occured. EventID: 0x00000457
Time Generated: 06/17/2005 07:00:38
(Event String could not be retrieved)
Time Generated: 06/17/2005 07:00:39
......................... MSSERVER failed test systemlog
Starting test: VerifyReferences
......................... MSSERVER passed test VerifyReferences
Running partition tests on : ForestDnsZones
Starting test: CrossRefValidation
......................... ForestDnsZones passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... ForestDnsZones passed test CheckSDRefDom
Running partition tests on : DomainDnsZones
......................... DomainDnsZones passed test CrossRefValidation
......................... DomainDnsZones passed test CheckSDRefDom
Running partition tests on : Schema
......................... Schema passed test CrossRefValidation
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test CrossRefValidation
......................... Configuration passed test CheckSDRefDom
Running partition tests on : mselektro
......................... mselektro passed test CrossRefValidation
......................... mselektro passed test CheckSDRefDom
Running enterprise tests on : mselektro.cz
Starting test: Intersite
......................... mselektro.cz passed test Intersite
Starting test: FsmoCheck
......................... mselektro.cz passed test FsmoCheck
Windows 2003 server a dcdiag
- 54075 Zobrazení
- 3791 Zobrazení
Poslední příspěvek od DeNNI85
- 11 Odpovědi
- 38284 Zobrazení
- 9 Odpovědi
- 23331 Zobrazení
- 13 Odpovědi
- 26156 Zobrazení
