Obcasny vypadek site
modem
Příspěvek od modem »
Zdravim,
mam problem s obcasnymi vypadky, ktere nastavaji cca co 10 minut. Problem je v tom, ze kdyz se napriklad divam na video na youtube, v urcitem bode se video sekne, dal nebufferuje a musim refreshnout celou stranku znova. Nebo kdyz hraju LOLko, sekne se mi a nejde se reconnectnout, musim vypnout a zapnout znova hru. Proste se to chova jakoby byl problem nekde s UDP protokolem.
Mam novy router, ASUS RT-N12LX, zkousel jsem factory reset. Pote jsem aktualizoval firmware. Prehodil jsem i jiny kanal na wifi tak, abych se nerusil s ostatnimi. Router se nebootuje, je porad v provozu behem te doby. A dela to jak na wifi tak pres kabel. Ostatni zarizeni maji stejny problem, tudiz neni chyba v PC ale nekde v routeru.
Poradi mi nekdo, prosim? Diky za jakekoli ohlasy.
LOG Z ROUTERU:
Feb 18 00:03:38 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:03:41 rlx-linux user.warn kernel: wlan0: A wireless client is disassociated - 2C:54:CF:CF:94:8F
Feb 18 00:03:41 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 18 00:03:41 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:03:41 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:04:32 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 18 00:04:32 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:04:32 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:04:45 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 00:04:45 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 18 00:05:20 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 18 00:05:20 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:05:20 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:07:44 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:07:44 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:07:44 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:07:44 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:10:52 rlx-linux user.warn kernel: wlan0: A STA is expired - 24:0A:64:EA:77:5D
Feb 18 00:12:43 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:12:43 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:12:43 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:12:44 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:12:49 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 00:12:49 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 18 00:14:18 rlx-linux user.warn kernel: wlan0: A STA is expired - 24:DB:AC:66:B2:CB
Feb 18 00:17:42 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:17:42 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:17:42 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:17:42 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:19:12 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 00:19:12 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 18 00:22:41 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:22:41 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:22:41 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:22:41 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:27:40 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:27:40 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:27:41 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:27:41 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:32:39 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:32:39 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:32:39 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:32:39 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:35:39 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 00:35:39 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 18 00:37:38 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:37:38 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:37:38 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:37:38 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:42:37 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:42:37 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:42:38 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:42:38 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:42:44 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 00:42:44 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 18 00:47:37 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:47:37 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:47:37 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:47:37 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:52:36 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:52:36 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:52:36 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:52:36 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:52:43 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:DB:AC:66:B2:CB
Feb 18 00:52:43 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:52:43 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:56:06 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 00:56:06 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 18 00:57:35 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:57:35 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:57:36 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:57:36 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:59:18 rlx-linux user.warn kernel: wlan0: A expired STA is resumed - 24:0A:64:EA:77:5D
Feb 18 00:59:19 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:0A:64:EA:77:5D
Feb 18 00:59:19 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:59:19 rlx-linux user.warn kernel: wlan0: A wireless client is disassociated - 24:0A:64:EA:77:5D
Feb 18 00:59:21 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:0A:64:EA:77:5D
Feb 18 00:59:21 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:59:21 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:59:22 rlx-linux user.info syslog: igmpproxy: Add membership 239.255.255.250
Feb 18 00:59:22 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.255.255.250, InpVIf: 1
Feb 18 01:00:36 rlx-linux user.info syslog: igmpproxy: Drop membership 239.255.255.250
Feb 18 01:00:36 rlx-linux user.notice syslog: Note: removing MFC: 0.0.0.0 -> 239.255.255.250, InpVIf: 1
Feb 18 01:00:36 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 01:00:36 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:22:53 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:27:52 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:27:52 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:27:52 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:27:53 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:27:55 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 23:27:55 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:32:51 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:32:51 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:32:51 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:32:51 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:35:21 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 23:35:21 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:37:49 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:37:49 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:37:49 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:37:50 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:42:49 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:42:49 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:42:50 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:42:50 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:43:19 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 23:43:19 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:47:47 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:47:47 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:47:48 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:47:48 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:49:18 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 23:49:18 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:50:31 rlx-linux user.info syslog: igmpproxy: Drop membership 239.192.152.143
Feb 17 23:50:31 rlx-linux user.notice syslog: Note: removing MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:50:33 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 30:3A:64:B3:9B:88
Feb 17 23:50:33 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 23:50:33 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 23:50:34 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 23:50:34 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:50:36 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:0A:64:EA:77:5D
Feb 17 23:50:36 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 23:50:36 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 23:50:39 rlx-linux user.warn kernel: wlan0: A wireless client is deauthenticated - 30:3A:64:B3:9B:88
Feb 17 23:50:42 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 30:3A:64:B3:9B:88
Feb 17 23:50:42 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 23:50:42 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 23:50:48 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:DB:AC:66:B2:CB
Feb 17 23:50:48 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 23:50:48 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 23:51:19 rlx-linux user.warn kernel: wlan0: A wireless client is disassociated - 24:DB:AC:66:B2:CB
Feb 17 23:51:20 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:DB:AC:66:B2:CB
Feb 17 23:51:20 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 23:51:20 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 23:52:49 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:52:49 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:52:49 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:52:50 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:52:52 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 23:52:52 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:57:14 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 17 23:57:14 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 23:57:14 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 23:57:46 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:57:46 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:57:46 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:57:47 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:00:17 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 18 00:00:17 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 18 00:00:49 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 18 00:00:49 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:00:49 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:01:52 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 18 00:01:52 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:01:52 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:02:45 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 00:02:45 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 16:02:45 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 00:02:45 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 00:03:10 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 18 00:03:10 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 18 00:03:11 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 18 00:03:38 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 18 00:03:38 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Jan 15 17:40:40 rlx-linux syslog.info syslogd started: BusyBox v1.13.4
Jan 15 17:40:40 rlx-linux user.warn kernel: eth1 added. vid=8 Member port 0x1...
Jan 15 17:40:40 rlx-linux user.warn kernel: eth2 added. vid=9 Member port 0x2...
Jan 15 17:40:40 rlx-linux user.warn kernel: eth3 added. vid=9 Member port 0x4...
Jan 15 17:40:40 rlx-linux user.warn kernel: eth4 added. vid=9 Member port 0x8...
Jan 15 17:40:40 rlx-linux user.warn kernel: [peth0] added, mapping to [eth1]...
Jan 15 17:40:51 rlx-linux user.notice syslog: UPnP: start_UPnP
Jan 15 17:40:52 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:DB:AC:66:B2:CB
Jan 15 17:40:52 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Jan 15 17:40:52 rlx-linux user.warn kernel: wlan0: Open and authenticated
Jan 16 01:40:54 rlx-linux daemon.info init: starting pid 740, tty '': '-/bin/sh'
Jan 16 01:40:57 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Jan 16 01:40:57 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Jan 15 17:40:58 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 22:38:05 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 22:38:31 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 24:0A:64:EA:77:5D
Feb 17 22:38:31 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 22:38:31 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 22:38:47 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 30:3A:64:B3:9B:88
Feb 17 22:38:47 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 22:38:47 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 22:38:58 rlx-linux user.warn kernel: wlan0: A wireless client is deauthenticated - 30:3A:64:B3:9B:88
Feb 17 22:39:01 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 30:3A:64:B3:9B:88
Feb 17 22:39:01 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 22:39:01 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 22:39:01 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 22:39:01 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 22:41:27 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 2C:54:CF:CF:94:8F
Feb 17 22:41:27 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 22:41:27 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 22:41:42 rlx-linux user.warn kernel: wlan0: A wireless client is deauthenticated - 30:3A:64:B3:9B:88
Feb 17 22:41:45 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 30:3A:64:B3:9B:88
Feb 17 22:41:45 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 22:41:45 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 22:43:01 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 22:43:01 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 14:43:01 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 14:43:01 rlx-linux user.warn kernel: wlan0: A wireless client is deauthenticated - 30:3A:64:B3:9B:88
Feb 17 22:43:01 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 22:43:04 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 30:3A:64:B3:9B:88
Feb 17 22:43:04 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 22:43:04 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 22:43:04 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 22:43:04 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 22:46:04 rlx-linux user.warn kernel: wlan0: A wireless client is deauthenticated - 30:3A:64:B3:9B:88
Feb 17 22:46:08 rlx-linux user.warn kernel: wlan0: A wireless client is associated - 30:3A:64:B3:9B:88
Feb 17 22:46:08 rlx-linux user.warn kernel: wlan0: WPA2-AES PSK authentication in progress...
Feb 17 22:46:08 rlx-linux user.warn kernel: wlan0: Open and authenticated
Feb 17 22:47:59 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 22:47:59 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 14:47:59 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 22:47:59 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 22:52:58 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 22:52:58 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 14:52:58 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 22:52:58 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 22:57:57 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 22:57:57 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 14:57:57 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 22:57:58 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 22:58:03 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 22:58:03 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:02:57 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:02:57 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:02:57 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:02:57 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:07:55 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:07:55 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:07:55 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:07:56 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:12:55 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:12:55 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:12:55 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:12:55 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:17:53 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:17:53 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:17:53 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 17 23:17:53 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 17 23:19:53 rlx-linux user.info syslog: igmpproxy: Add membership 239.192.152.143
Feb 17 23:19:53 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.192.152.143, InpVIf: 1
Feb 17 23:22:52 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 17 23:22:52 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 15:22:53 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 01:02:34 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 01:02:34 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 17:02:34 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 01:02:34 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 01:07:34 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 01:07:34 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 17:07:34 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 01:07:34 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 01:08:03 rlx-linux user.warn kernel: wlan0: A wireless client is deauthenticated - 30:3A:64:B3:9B:88
Feb 18 01:12:33 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 01:12:33 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 17:12:33 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 01:12:34 rlx-linux user.notice syslog: RT-N12LX:ntp client success
Feb 18 01:14:02 rlx-linux user.info syslog: igmpproxy: Add membership 239.255.255.250
Feb 18 01:14:02 rlx-linux user.debug syslog: Debu: adding MFC: 0.0.0.0 -> 239.255.255.250, InpVIf: 1
Feb 18 01:14:04 rlx-linux daemon.err dnrd[4937]: [truncated] m
Feb 18 01:14:05 rlx-linux daemon.err dnrd[4937]: [truncated] m
Feb 18 01:14:08 rlx-linux user.notice syslog: Note: adding VIF, idx=0 Fl flags=0x0 IP=192.168.1.1 br0
Feb 18 01:14:08 rlx-linux user.notice syslog: Note: adding VIF, idx=1 Fl flags=0x0 IP=10.161.128.35 eth1
Feb 17 17:14:08 rlx-linux user.notice syslog: RT-N12LX:ntp starts
Feb 18 01:14:08 rlx-linux user.notice syslog: RT-N12LX:ntp client success
  • Rozdělení sítě na podsítě, výpočet podsítí podle počtu hostů
    16106 Zobrazení
Zpět na „Administrace sítě“
