=== RogueKiller Changelog ===
- Adlice Software -
V15.11.0 06/22/2023
- Updated to core 6.11.0
* Fixed possible crash when opening EULA
* Deployed cloud config
* Added cloud config for MalPE
* Fixed potential crashes in DirectoryCounter
* Fixed issue where files removed at reboot were not triggering user notice
* Added SearchScope (Bing) search rules
* Fixed issue where ACLs protected registry keys could not be read/deleted
* Fixed minor issues for URL scanning
* Fixed issue were Cloud mitigated detections were not showing in Diag
* Minor Fixes
V15.10.0 05/24/2023
- Updated to core 6.10.0
* Ability to login to shop account to retrieve license keys
* Registration page re-designed
* NTFS module
* FileScanner fast enumeration during scan
* Now showing progress during filesystem scanning
* Minor Fixes
V15.9.0 04/24/2023
- Updated to core 6.8.0
* Now uploading unknown files using dedicated cloud API
* Fixed an issue where directores with specific ACLs were not removed
* Minor Fixes
- Fixed an issue where exiting after a certain scenario would lead to error message in a loop
V15.8.2 03/22/2023
- Updated to core 6.7.2
* Fixed an issue where volatile licenses were eating activations
* Fixed encoding issue in installer translations
* Fixed file types filtering in archives scanning
* Minor Fixes
V15.8.1 03/06/2023
- Updated to core 6.7.1
* Added client tagging on signatures check/update
* Added scheduled scan type in config
* Update checks task only executing on Premium
* RTP task not exeutes every 60 mns (prior, 15mns)
* RTP task disabled when RTP not enabled
* Minor Fixes
- Moved scheduled scans to its own settings tab
- Added ability to choose between Standard/Quick type for scheduled scan
V15.8.0 01/26/2023
- Updated to core 6.7.0
* Updated libraries (libyara)
* Updater translations
* Fixed issues on Windows XP
* Fixed an issue where Powershell was slow to open with Clipboard protection
* Fixed issue in exclusions where sometimes wrong target was set
* Fixed minor issue in Cloud scanner
* Minor fixes
- Removed wizard button
- Now outdated notice has an hyperlink
V15.7.0 01/16/2023
- Updated to core 6.6.0
* Fixed multiple issues with cloud scanning
* Minor Fixes
V15.6.5 01/04/2023
- Updated to core 6.5.8
* Fixed an issue with Curl network check
* Minor Fixes
V15.6.4 12/15/2022
- Updated to core 6.5.7
* Fixed an issue where link open may fail under LocalSystem account
* Fix for obtaining default browser path
* Fix for Pipe exit
* Abortable scan report
* Moved some links opening to more secured method
* Minor Fixes
- Moved some links opening to more secured method
- Dynamic translations
V15.6.3 11/15/2022
- Updated to core 6.5.5
* Fixed download issue in UCheck module
* Minor fixes
- Translations update
V15.6.2 10/13/2022
- Updated to core 6.5.4
* Moved URL protocol to installer
* Rkflt version 0.10.4
- Fixed possible BSOD at driver Load
* Fixed possible altitude collision on Windows 11
* Minor fixes
V15.6.1 09/13/2022
- Updated to core 6.5.1
* NEW! Protocol URLs: Ability to register license from an URL
* Fixed issue where scanning whitelisted folders' content was not honored in custom scan
* DLP no longer in BETA
- Translations updated
- Fixed an issue where scan was not stopped on session log out, leading to a crash
V15.6.0 08/22/2022
- Updated to core 6.5.0
* NEW! Process injection (rkmon32 & rkmon64) [BETA]
* NEW! Clipboard protection module [BETA]
* Fixed an issue where RTP cleanup routine was not executed
* Fixed an issue where RTP signatures were not updated automatically
* Fixed an issue where RTP cache was not limited in Size
* Optimization for RTP cache on process termination
V15.5.3 06/13/2022
- Updated to core 6.4.3
* Fixed a critical issue in signatures engine (some signatures were not working)
V15.5.2 06/07/2022
- Updated to core 6.4.2
* Truesight 3.1 (Win10+)
- Fixed memory leaks
- Fixed missing allocations tagging
* Added -excluded-paths CLI switch
- Removed Wizard (better UX)
- Fixed a bug where update could launch during a scan
- Fixed missing label in Web addons exclusions
- Added refresh button on Account tab
V15.5.1 05/16/2022
- Updated to core 6.4.1
* Fixed Rkflt version 0.10.3 for 32 bits
V15.5.0 05/04/2022
- Updated to core 6.4.0
* Rkflt version 0.10.3 (Win10+)
* Windows 11 official support
* Logs reduction
* Minor fixes
- Added/Updated translations
* NEW: Japanese
* NEW: Dutch
* NEW: Portuguese
* NEW: Brazilian
* NEW: Polish
* NEW: Italian
* NEW: Arabic
* NEW: Japanese
V15.4.0 03/07/2022
- Updated to core 6.3.3
* Fixed potential memory leak in zip module
* Fixed issue in cloudscanner where empty batches were sent for analysis
* MalPE mitigation: Unknown cloud files are no longer considered malicious
* Added background scanner configs
* Command scanner is now able to retrieve current process directory and use it for path resolution
- Added setting to revert full scan performance (on demand + scheduled)
- New dashboard page
V15.3.0 02/17/2022
- Updated to core 6.3.2
* Added first cloudscan config
* Fixed an issue where detection was added even with a cloudscan invalidation
* Fixed an issue where Windows backup history svchost was detected as DLP
* Curl timeout increase
* Redesigned all command line arguments
* Minor fixes
* Redesigned UIs to better resize
* Background scan enabled by default
V15.2.0 01/20/2022
- Updated to core 6.3.0
* Cloudscanner (new module, BETA)
* New detection design (Pipeline, BETA)
* Minor fixes
* New scan progress design
* New marketing page design
* New settings page design
* New history page design
V15.1.5 12/15/2021
- Updated to core 6.1.8
* Fixed infinite reload loop in scheduler causing UI to hang / having performance issue
* Fixed possible crashes (log formatting)
* Fixed possible crash (CLSID scanner)
* My Account UI redesign
* Registration UI redesign
- Fixed potential crash on exiting for update
- Settings redesign
V15.1.4 11/18/2021
- Updated to core 6.1.7
* Fixed issue in scheduler where monthly scan was not working
- Fixed numerous UI / UX issues across the app
- Opened Exclusions to free version
- Fixed an issue where switches where slow to update
- Better wording in settings descriptions
- Added UCheck link in miniscan banner
- Fixed missiing translation on signatures download link
- Fixed refresh issue where driver was showing unloaded after registration
- Fixed refresh issue where secured storage was showing unavailable after registration
- Removed setup registration (now all inside the software)
V15.1.3 11/09/2021
- Updated to core 6.1.6
V15.1.2 11/03/2021
- Updated to core 6.1.5
* Fix for scheduler (fixed time not starting after sleep)
* Fixed an issue in common report view
* Fixed an issue in path parser (task scheduler)
* Fixed an issue in DLP where prefetch service was blocked
* Minor fixes
- Setup: Always force desktop icon
- UI lib update (button padding issue)
V15.1.1 10/11/2021
- Updated to core 6.1.4
* Fixed an issue with scheduled scans not starting
* Added ability to cancel scan during archive scanning
* New scheduler
* Added EDGE scanner
* Minor fixes
- Added Next Scan date on dashboard
- Removed scan notifications if UI is shown
V15.1.0 09/06/2021
- Updated to core 6.1.1
* New reporting
* Fixed an issue when adding exclusions
* Fixed a false detection on explorer / DocLock
V15.0.9 08/05/2021
- Updated to core 6.0.11
* Fixed self folder scanning issue
* Asynchronous logging
* Fixed possible deadlock
* Fixed possible infinite loop in config migration
* certificate update
- Fixed possible issue with information update at startup
- Re-enabled thanks page opening
- Deactivated Cloud Upload windows (later integrated into own worker)
- Added Proxy authentication settings
V15.0.8 07/13/2021
- Disabled temporarily "thanks page" opening (will be reworked later)
- Updated to core 6.0.10
* Fixed possible crashes when stopping
V15.0.7 07/08/2021
- Updated to core 6.0.9
* Quarantine delete all
* Minor fixes
- Fixed issue where UI was showing inconsistent state during long initialization
- Added locks during engine initialization
- Added banner when there's too many quarantine items to display (> 1000)
V15.0.6 07/01/2021
- Updated to core 6.0.8
* Fixed possible crash in pipe communication
- Fixed issue when checking for updates (signatures state not refreshed)
- translations update
V15.0.5 06/30/2021
- Updated to core 6.0.7
* Fixed possible deadlock (SecuredIPC) between scheduler / signatures_changed callback
V15.0.4 06/28/2021
- Updated to core 6.0.6
* Fixed another issue where dates are not saved properly in config file
* Fixed service scan request (scheduler)
* Fixed service signatures status update
V15.0.3 06/15/2021
- Updated to core 6.0.5
* Fixed potential crash getting username from session ID
* Updater 4.0.1
* Fixed crash on certain cases (double download worker thread)
* Fixed crash issue when old config is present (Config migration)
* Fixed an issue where dates are not saved properly in config file
- Fixed potential crash on Initialization
V15.0.2 06/14/2021
- Fixed potential crash on exporting portable config
V15.0.1 06/14/2021
- Fixed potential crash on startup
V15.0.0 06/14/2021
- Updated to core 6.0.4
* Fixed an issue where context menu scan was not working when UI is started by the service
* Fixed potential crash in getting computer name
* Fixed issue with Windows Updates status
* Fixed issue with ucheck progress counters
* Refactored using safer memory management (smart pointers)
* Refactored with asynchronous initialization (faster to start)
* Updater 4.0
* RK DLL 4.0
* Minor fixes
- Fixed an issue where some settings in combobox where changing on page scroll (lang, theme)
- Minor UI fixes
V14.8.6 03/24/2021
- Updated to core 5.3.5
* Fixed potential stack overflows
* Reducing Cloud.Generic FPs by ignoring some 3rd parties
* Translations update
* Minor fixes
- Augmenting contrast on detections results page
V14.8.5 02/15/2021
- Updated to core 5.3.4
* Fixed possible hang on Zip
* Fixed bad licensing error message in some cases
- Now opens Update form if clicked on "new version" notification
- Now all notifications honor the "no notification" user setting
V14.8.4 01/13/2021
- Fixed wrong rkflt version (0.10.0 => 0.10.1) for x64
V14.8.3 01/12/2021
- Updated to core 5.3.3
* Fix for XP compat (CancelSynchronousIo)
* Fix for disk enumeration hang
* Fix for network file resolution hang
* rkflt 0.10.1 (fixed a potential crash on USB device plug)
V14.8.2 12/28/2020
- Updated to core 5.3.2
* Fixed a possible crash in scan worker
V14.8.1 12/14/2020
- Updated to core 5.3.1
* Fixed licensing issue with XP
* Fixed issue in VTScanner on exit (submit on exit)
* Fixed possible memory leak in scan items
* Fixed possible memory leak in zlib module
* Fixed possible memory leak in zip module
* Fixed possible memory leak in COM module
* Fixed possible memory leak in Event module
* Fixed possible memory leak in SigCheck module
* Fixed possible stack overflox in Time module
* Fixed possible hang in Drives enumeration (async file opening)
* Added hash in event history
* Fixed an issue where filemon event took time resolving process path and could hang on certain programs (WoT block)
* Minor fixes
V14.8.0 11/17/2020
* Fixed possible issue (small buffer) in filter com
* Fixed VTScanner cache, not working in some conditions
* Fixed FileMemoryScanner, archive not scanning in some conditions
* Fixed DigisigScanner, suspicious CAs
* Fixed multiple crashes in PE module
* Fixed possible crashes (SO) in registry, path modules
* Fixed possible crashes (except) in string, buffer, curl modules
* Minor fixes
- Added Chinese translation
V14.7.4 10/22/2020
- Updated to core 5.1.4
* Fixed potential issue with broken Shell extension (explorer context menu)
* Fixes for DocLock DLP FP mitigation
* Minor fixes
- Added Archives scan configuration
V14.7.3 09/15/2020
- Updated to core 5.1.3
* Fixed several memory leaks
* Leverage AME cache for DocLock classification
* Disabled RTP for portable config
* Minor fixes
- Fixed refresh issue on dashboard
V14.7.2 09/01/2020
- Updated to core 5.1.2
* Fixed potential crash in digisig module for x86
V14.7.1 08/31/2020
- Updated to core 5.1.1
* Fixes for Data Leak Prevention (BETA)
* Fix for digisig module (check file from cert store)
* Minor fixes
V14.7.0 08/24/2020
- Updated to core 5.1.0
* RKFlt 0.10
* RogueKillerSVC 1.5
* Added Data Leak Prevention (BETA)
* Deferred Kill to post-processing
* Fixes for MalPE pre-filtering
* Minor fixes
V14.6.3 08/10/2020
- Updated to core 5.0.4
* Fixed crash in PE parser
* Fixed crash in config Migration
* Minor fixes
V14.6.2 07/27/2020
- Updated to core 5.0.1
* DocLock: Mixed protection (FP mitigation)
* DocLock: Now preventing to add system folders
* Fix for Bad.Extension on files disguised as PE
- Fixed scheduled updates / button updates
V14.6.1 06/16/2020
- Fixed Truesight digital signature
- Updater 3.5
* Bigger and better
* Added cancel button
V14.6.0 06/15/2020
- Updated to core 5.0.0
* Added more logs for Curl
* Proxy validation
* Truesight 3.0 (refactored with HLK validation)
* Antirootkit module re-integrated (silent mode as a 1st step)
* RogueKillerSVC: 1.4
* Minor fixes
V14.5.0 05/27/2020
- Updated to core 4.3.4
* MalPE AI 0.6
* DocLock: Blocking suspicious NETSH
* DocLock: Blocking suspicious WMIC
* Added default printer location
* Added ability to scan files with context menu
* Added ability to scan network paths with context menu
* Added Browser extension type for exclusions
* Minor fixes
- Added white-circled icon
- Updater 3.4.1
* Fixed a possible crash at exit
V14.4.2 04/29/2020
- Updated to core 4.3.3
* Fix for crash upload (limitation by dump is present)
* RKSvc 1.3.1
V14.4.1 04/29/2020
- Updated to core 4.3.2
* Fixed pipe disconnect (retry logic)
* Fixed pipe security
* Fixed IPC cache
* Added config auto-backup/restore
* Fixed self-update task
* Fixed crash reports upload
V14.4.0 04/01/2020
- Updated to core 4.3.0
* Fix for XP (libzip, openssl rebuilt)
* Added scan warnings
* Added filescanner warning on abnormally long folder scan
* Added scan warnings JSON reporting
* Size optimizations
* Removed warnings
* New advert payload
* Added some logging
* Minor fixes
V14.3.0 03/23/2020
- Updated to core 4.2.0
* Libraries update (libzip / sqlite)
* New version manager (network failure proof)
* Flush DNS cache on network domain resolve error
* Fix for XP (libcurl rebuilt)
* Fixed a possible crash in PE parser (VersionInfo)
* [DocLock] Added suspicious digisig filtering => Mitigation against signed Ransomware
* [DocLock] Allowing more explorer processes
* Fixed an issue where process termination was not properly detected
* Update to rkflt 0.9.4
* Update to rksvc 1.3.0
* Update to roguekillerdll 3.2.0
* Update to roguekillerupdater 3.4.0
* Fixes for early logging
* Minor fixes
- My Account links
V14.2.1 02/24/2020
- Updated to core 4.1.3
* Fixed url for signatures download
V14.2.0 02/24/2020
- Updated to core 4.1.2
* Updated libraries (openssl / libssh2 / libcurl /libyara)
* Fixed an issue in Path parser
* Update to rkflt 0.9.3
* Update to rksvc 1.2.0
* Fixed an issue where certain command lines could hang until timeout in rkflt
* Improved performances for scanning filesystem network resources
* Fixed scheduled version check
- Updated translations
V14.1.1 01/28/2020
- Updated to core 4.1.1
* Service: Defer crash upload in a worker thread
* Fixed potential issue with hanging processes (including web browsers)
- Fixed EULA showing in installed mode
V14.1.0 01/20/2020
- Updated to core 4.1.0
* Fixed a possible crash in Buffer module (implicitcasts)
* Fixed an issue where threat name wasn't properly parsed
* Reduced API calls frequency
* Update to rkflt 0.9.2
* Update to rksvc 1.1.0
* Fixed possible crash at exit
* DockLock: Prevent RW from rebooting
* DockLock: Prevent RW from using shadow copy removal
* DockLock: Fixed an issue where renaming whas not fully detected
* DockLock: Added RIPlace detection and blocking
* Updates libraries (jansson / cryptopp)
* Driver loading sanity check
- Added gamer mode (no notifications during full screen)
V14.0.4 01/06/2020
- Updated to core 4.0.5
* Fix for getting username from SYSTEM account
* Fixes for scheduler engine
* Fixed FP remediation for Proc.Svchost detections
* Fixed exclusions when path have spaces
* Minor fixes
- Added "refresh" button for custom scan paths directories tree (to use on external drives (un)plugged)
- Fixed laggy UI at startup
V14.0.3 12/23/2019
- Updated to core 4.0.4
* Fixed Bad.Extension on Zero-filled
* Fixed heuristics in command-line scanner
* Fix for telemetry
* Fixed bad reference decrement in Yara scanner
* Fixed initialization order in worker threads
* Fixed ACLs removal in Debug module
* Fixed potential crash in Exclusions and History Events modules
* Minor fixes
- Added button to export RTP history
- Added button to export service log
- Added button to clear RTP cache
- Fixed warning about modules disabled when explicitely turned off by config
- Fixed an issue with exit warning not showing
- Updated German translation
- Updated Turkish translation
V14.0.2 12/16/2019
- Updated to core 4.0.2
* Fixed possible crashes in logging
* Fixed an issue with processes CLI exposing pipe names (some VPN softs)
* Fixed an issue where DocLock reset was not removing old entries
* Now displaying full command line instead of process path in history/events
* Cloud upload (async) when needed
* New telemetry data
* Minor fixes
V14.0.1 12/12/2019
- Updated to core 4.0.1
* Added ability to reset doclock folders to default
* Improved doclock remove all folders call
* MalPE model 0.5 (fast)
* minor fixes
- Fixed an issue where self-exit displayed a warning
- Added ability to reset doclock folders to default
V14.0.0.16 12/10/2019
- Updated to core 4.0.0
* Real Time Protection
* Malware Protection module
* Documents Protection module
* Real Time Protection settings and UI changes
* Minor fixes
V13.5.7 11/20/2019
- Updated to core 3.2.17
* Added Background scan
* Fixed possible crash at scanner destroy
* Minor fixes
* Added background scan (low CPU usage) setting for scheduled scans
* Icons refactoring
V13.5.6 11/07/2019
- Updated to core 3.2.16
* Fixed possible crash when exiting during a scan
* Minor fixes
V13.5.5 10/23/2019
- Updated to core 3.2.15
* Fixed common folders/files ACLs
* RogueKillerDLL 2.4
* Using Restart Manager whenever possible
* Added registry setting to force debug logging
* Fixed an issue where folders were not properly quarantined and removed
* Added Critical flag manipulation before processes termination
* Fixed an issue where exclusions were not working with shortcuts
* Minor fixes
- Fixed an issue with licensing button notifications
V13.5.4 10/14/2019
- Updated to core 3.2.13
* Fixed a possible deadlock and crash in scheduler/advert
V13.5.3 10/10/2019
- Updated to core 3.2.12
* Fixed an issue where Marketing request wasn't properly processed (notifications loop)
* UCheck engine duplicates handle
* Minor fixes
V13.5.2 10/07/2019
- Updated to core 3.2.10
* Fixed an issue where advert tasks were re-added (and cleared) on network issues
V13.5.1 10/07/2019
- Updated to core 3.2.9
* Fixed a handle leak when scanning big files
* Minor fixes
- Fixed an issue in Scheduled scan settings (impossible to set minutes value)
V13.5.0 09/24/2019
- Updated to core 3.2.8
* MalPE model 0.4
* Minor fixes
- Improved binaries replacement in installer
V13.4.4 09/16/2019
- Updated to core 3.2.6
* Minor fixes
- Fix for notifications (bug: under taskbar)
- Fixed possible crash at startup
V13.4.3 08/20/2019
- Updated to core 3.2.4
* Fixed an issue in WinTrust (part 2)
* Fixed possible deadlock while enumerating processes
* Fixed SearchStrings method
* Signatures 20190819_114745
* Added new Scan locations
* Fixed an issue with ACLs where config files may not be properly saved
* Fixed portable_license CLI parameter
* Fixed low privilege Shell extension registration
V13.4.2 08/09/2019
- Updated to core 3.2.3
* Fixed scheduler reload
- Fixed a possible deadlock in scheduler
V13.4.1 08/08/2019
- Fixed an issue with Shell extension on x64
V13.4.0 08/08/2019
- Updated to core 3.2.2
* Fixed MalPE threshhold
* Fixed Wintrust scan (slow)
* Added signatures package integrity check
* Fixed MalPE detection name (negatives values sometimes)
* Fixed issue with Bad.Extension detection
- Added Shell extension (Explorer context menu entry)
- Added Shell extension setting
V13.3.2 07/15/2019
- Updated to core 3.2.0
* Signed files are whitelisted by default
* Fixed an issue in scheduler
* MalPE V2
- Added AI score to reports
V13.3.1 07/01/2019
- Updated to core 3.1.1
* Minor fixes
V13.3.0 07/01/2019
- Updated to core 3.1.0
* Fixed an issue where GetErrorMode API isn't present on XP
* New machine ID (less prone to changes on Windows install)
* Technician trial (if applicable)
* Scheduler V2
* Reviews notifications
- Better notifications
- Added Machine ID on Account page
V13.2.2 06/10/2019
- Updated to core 3.0.11
* Fixed startup registration issue when laptop on battery
* Fixed warning message at startup when floppy drive exists
* Fixed file not closing after zip operations
- Added automatic updates setting
- New Automatic update system (silent with notifications and scheduler)
- Fixed last scan date (taken from config and not history)
V13.2.1 05/22/2019
- Updated to core 3.0.10
* Bug fixes
* Fixes for scheduler (grace period)
- Added button to cleanup crash information
- New registration form
- New account form
- Fixed issue with dashboard not reflecting scan status
V13.2.0 05/14/2019
- Updated to core 3.0.9
* Bug fixes
* Updated signatures
* UCheck engine update
- Fix for hidden.proc
- Free users can now download signatures package automatically
V13.1.10 04/24/2019
- Added notifications setting
- Updated to core 3.0.8
* Bug fixes
V13.1.9 03/27/2019
- Fixed marketing notification, now won't show at startup after first time
- Updated to core 3.0.7
* Fixed crash in notifications engine
* Fixed COM initialization in real time services
* Fixed Scanner queue initialization
* MSHTA and WScript detections
* Minor Bug fixes
V13.1.8 03/11/2019
- Updated to core 3.0.6
* Bug fixes
V13.1.7 03/05/2019
- Updated to core 3.0.5
* Fixed WebScanner mitigation
* Disabled PUM.StartMenu for RogueKiller
* Fixed Appdata scan duplicate
* Fixed LocalAppdata scan duplicate
- Fixed an issue with renewal links
V13.1.6 02/25/2019
- Updated to core 3.0.4
* Added Firefox registry addons search
* Fixed registry items duplicates on scan
- Fixed translations
- Removed tray icon in portable version
- Fixed freeze on custom scan selection
- Fixed autostart minimize on Free version
- Fixed autostart initial state
- Minor fixes
V13.1.5 02/18/2019
- Updated to core 3.0.3
* Added ability to read encrypted signatures packages (AV detection mitigation)
V13.1.4 01/30/2019
- Updated to core 3.0.2
* Fixed a crash in ZIP module
* Fixed an issue in Folder creation (preventing creating working directory when executing from non system drive)
* Now VT.Unknown is not treated as a threat anymore
* Now updater runs installer with /silent
- Updated shop links to use download API
- Updated marketing notification from every 1 hour to every 3 hours
V13.1.3 01/24/2019
- Improvment: Installer now kills existing processes before replacing the files
- Fixed: Support form not sending proper Program name
- Updated: Signatures, package 20190121
- Improvment: Pricing table is clearer
- Improvment: Exit button icon
- Fixed: Renewal link for FR
V13.1.2 01/23/2019
- Fixed: Translations (French, Spanish, German)
- Fixed: notifications showing under taskbar in certain conditions
- Refactored notifications (removed useless ones)
- Added marketing table (easier to understand Premium features and differences with Free version)
- Hiding filters in report view (useless for RogueKiller)
V13.1.1 01/22/2019
* Fixed: a crash in PE parser when file is driver protected
- Fixed: renewal link for Technician
- New: Added better notifications
- Fixed: Custom filesytem locations selection
- Fixed: Notifications on multiple monitors
V13.1.0 01/21/2019
- Updated to core 3.0.0
* Ability to download signatures from YED server
* Now using Scheduled task to run as admin at startup
* Now ignoring excluded items from scanner
- New: Added Scheduled scans (Premium)
- New: Added Automatic signatures updates from adlice.com YED server (Premium)
- New: Added Manual signatures packages loading
- New: Added setting to run at startup
- New: Added exclusions settings and option
V13.0.22 01/14/2019
- Added service detection by name
- Added signatures
V13.0.21 01/07/2019
- Improved support for high DPI screens (V2)
- Added signatures
- Added support for .lic file (registration)
V13.0.20 12/31/2018
- Updated to core 2.2.2
* Fixed an issue with installer and updater/DLL - Part 2
* Fixed possible crash on File IO operations
V13.0.19 12/26/2018
- Updated to core 2.2.1
V13.0.18 12/24/2018
- Added signatures
- Updated to core 2.2.0
- Added link to threat page on Quarantine items
- Added buttons to quarantine / report page
- Fixed multiple dates
- Added dashboard shortcuts
- Minor themes fixes
V13.0.17 12/17/2018
- Added signatures
- Updated to core 2.1.0
V13.0.16 12/10/2018
- Added signatures
V13.0.15 12/03/2018
- Updated to core 2.0.25
- Fixed a issue in Filescanner where LNK arguments were not expanded for variable environment
- Added signatures
V13.0.14 11/27/2018
- Updated to core 2.0.24
- Fixed a crash in scanner engine when scanning a file locked by driver
V13.0.13 11/26/2018
- Added signatures
V13.0.12 11/21/2018
- Updated to core 2.0.23
- Fixed an issue in Curl, leading to download aborts on file sharing issue
- Improved Curl file download, now retaining file handle on write (Windows Defender slow download fix)
- Added UCheck mini-scan setting (Premium)
V13.0.11 11/19/2018
- Updated to core 2.0.22
- Added Registry heuristic scanner
- Added signatures
V13.0.10 11/14/2018
- Updated to core 2.0.21
- Fixed an issue in the path parser
- Minor fixes and enhancements
- Added signatures
V13.0.9 11/12/2018
- Updated to core 2.0.20
- Added German translation
V13.0.8 11/06/2018
- Updated engine to Yara 3.8.1
- Updated to core 2.0.18
- Added Spanish translation
V13.0.7 11/05/2018
- Fixed a potential crash in yara engine
- Updated to core 2.0.17
- Added signatures
V13.0.6 11/01/2018
- Fixed a potential crash in VirusTotal engine
- Updated to core 2.0.16
V13.0.5 10/31/2018
- Minor fixes
- Updated to core 2.0.15
V13.0.4 10/30/2018
- Fixed a crash in Unzip engine
- Fixed a crash that occured at startup with Agent enabled
- Fixed installer UUID (reverted to RK12 UUID)
- Fixed telemetry setting
- Fixed premium settings
- Updated to core 2.0.14
- Added: Activations manager screen (List/Remove)
V13.0.3 10/29/2018
- First official release
- Added signatures
V13.0.2 10/25/2018
- Added Comments and Forum Url fields for CloudRemoval
- Updated scan rules
- Updated CloudRemoval payload
- Updated to core 2.0.13
- Updater 3.1 (fixes an issue in Config file readonly)
- RKDLL 2.2 (fixes an issue in Config file readonly)
- Added detections
V13.0.1 10/19/2018
- Update to core 2.0.12
- Fixed minor bugs
V13.0.0 10/12/2018
- Update to core 2.0.11
- Fixed minor bugs
V12.99.11 10/05/2018
- Fixed a potential crash in FileScanner (COM)
- Fixed detection color for PUP/PUM
- Fixed FileScanner path scan for folders
- Updated documentation link
- Added detections
V12.99.10 10/03/2018
- Technician license compatibility
- Trusight cleanup at exit
- Setup gives the ability to clean license/data at uninstall
- Fixed issue where Filescanner was detecting Folders with suspicious path
- Backported V12 missing settings (Proxy, Agent)
- Backported V12 support form
- Now detecting and migrating V12 config file and license
- Added Scan mode information in report view and scan progress
- Fixed report view for RogueKiller
V12.99.9 09/20/2018
- Adlice Diag project backport
- Rewritten engine from scratch
- Rewritten UI from scratch
- Scanner is now multithreaded, optimized for speed.
- Scanner has new modules: Digisig scanner, Webconf scanner,
V12.13.6 10/22/2018
- Added detections
V12.13.5 10/15/2018
- Added detections
V12.13.4 10/08/2018
- Added detections
V12.13.3 10/01/2018
- Added detections
V12.13.2 09/24/2018
- Added detections
V12.13.1 09/17/2018
- Added detections
V12.13.0 09/10/2018
- Fixed a critical memory leak in core (buffer)
- Added detections
V12.12.34 09/03/2018
- Added detections
V12.12.33 08/27/2018
- Added detections
V12.12.32 08/20/2018
- Added detections
V12.12.31 08/10/2018
- Added detections
V12.12.30 08/06/2018
- Added detections
V12.12.29 07/30/2018
- Added detections
V12.12.28 07/23/2018
- Added detections
V12.12.27 07/19/2018
- Added detections
V12.12.26 07/09/2018
- Added detections
V12.12.25 07/02/2018
- Added detections
V12.12.24 06/25/2018
- Added detections
V12.12.23 06/18/2018
- Fixed a crash in Curl module
- Fixed Win32 API usage that broke XP compatibility
V12.12.22 06/18/2018
- Added detections
V12.12.21 06/11/2018
- Added detections
V12.12.20 06/04/2018
- Added detections
V12.12.19 05/28/2018
- Added detections
V12.12.18 05/22/2018
- Added detections
V12.12.17 05/14/2018
- Added detections
V12.12.16 05/04/2018
- Added detections
V12.12.15 04/30/2018
- Added detections
V12.12.14 04/23/2018
- Added detections
V12.12.13 04/16/2018
- Added detections
V12.12.12 04/09/2018
- Added detections
V12.12.11 04/03/2018
- Added detections
V12.12.10 03/26/2018
- Added detections
V12.12.9 03/19/2018
- Added detections
- Update Korean translation
V12.12.8 03/12/2018
- Added detections
V12.12.7 03/05/2018
- Added detections
V12.12.6 02/26/2018
- Added detections
V12.12.5 02/19/2018
- Added detections
V12.12.4 02/12/2018
- Added detections
V12.12.3 02/05/2018
- Added detections
V12.12.2 01/29/2018
- Added detections
V12.12.1 01/22/2018
- Fixed possible crash in PE parser
- Added detections
V12.12.0 01/15/2018
- Fixed possible hang while processing file MD5
- Fixed Chrome extension removal
- Fixed Chrome configuration removal
- Added detections
V12.11.32 01/08/2018
- Added detections
V12.11.31 01/02/2018
- Added detections
V12.11.30 12/26/2017
- Added detections
V12.11.29 12/18/2017
- Added detections
- Fixed Windows Defender FP
V12.11.28 12/11/2017
- Added detections
V12.11.27 12/04/2017
- Fixed potential issue with "device not found, insert disk" messages
- Added detections
V12.11.26 11/27/2017
- Added detections
V12.11.25 11/20/2017
- Added detections
V12.11.24 11/13/2017
- Added detections
V12.11.23 11/06/2017
- Added detections
V12.11.22 10/30/2017
- Added detections
V12.11.21 10/23/2017
- Added detections
- Fixed a bug in JSON export
V12.11.20 10/16/2017
- Added detections
V12.11.19 10/09/2017
- Added detections
V12.11.18 10/02/2017
- Added detections
V12.11.17 09/25/2017
- Added detections
V12.11.16 09/18/2017
- Added detections
V12.11.15 09/18/2017
- Added detections
V12.11.14 09/11/2017
- Added detections
V12.11.13 09/04/2017
- Added detections
- Added msiexec handler to pathparser
V12.11.12 08/28/2017
- Added detections
V12.11.11 08/21/2017
- Added detections
- Dutch translation update
V12.11.10 08/14/2017
- Added detections
- Fixed issue with uploader (please note this will apply to next update)
V12.11.9 08/03/2017
- Added detections
- Fixed POST requests with proxy
- Fixed Upload timeout (crash upload/support form)
V12.11.8 07/24/2017
- Fixed proxy persitence in Free mode
- Fixed a bug in MalPE
- Added detections
V12.11.7 07/17/2017
- Added detections
- Added Proxy configuration
V12.11.6 07/10/2017
- Added detections
V12.11.5 07/03/2017
- Added detections
V12.11.4 06/26/2017
- Added detections
V12.11.3 06/19/2017
- Added detections
- Minor fixes
V12.11.2 06/12/2017
- Added detections
V12.11.1 06/04/2017
- Added detections
- Fixed possible bug in MalPE scanner
- Forced VT mitigation for MalPE scanner to avoid FPs
V12.11.0 05/29/2017
- Added detections
- NEW! MalPE module (BETA)
- NEW! RogueKillerAdmin V2 compatible
- DEPRECATED: RogueKillerAdmin V1
V12.10.10 05/22/2017
- Added detections
V12.10.9 05/15/2017
- Added detections
V12.10.8 05/08/2017
- Added detections
- Fixed a bug in settings where Offline registry setting wasn't saved
V12.10.7 05/01/2017
- Added detections
- Fixed a possible crash in COM module
- Fixed a possible crash in Path parser
V12.10.6 04/24/2017
- Added detections
V12.10.5 04/18/2017
- Added detections
V12.10.4 04/10/2017
- Added detections
V12.10.3 04/03/2017
- Added detections
V12.10.2 03/27/2017
- Added detections
V12.10.1 03/20/2017
- Added detections
V12.10.0 03/13/2017
- Added detections
- Now using common translations
- Fixed UI error where the "Pause" button was not reset after a scan
- Fixed a bug in the MBR scan
- Fixed minor bugs
V12.9.9 02/27/2017
- Added detections
- Added warning when no element is selected prior to removal
- Fixed a bug in detection labels
- Fixed a bug in VT module
V12.9.8 02/21/2017
- Added detections
V12.9.7 02/06/2017
- Added detections
V12.9.6 01/30/2017
- Added detections
V12.9.5 01/23/2017
- Added detections
V12.9.4 01/16/2017
- Fixed FP on Mozilla Maintenance Service
V12.9.3 01/16/2017
- Added detections
- Fixed licensing machine ID
V12.9.2 01/09/2017
- Added detections
- Fixed critical bug in File module leading to a crash when scanning big files (> 2GB)
V12.9.1 01/02/2017
- Added detections
- Various fixes
V12.9.0 12/26/2016
- Added detections
- Signatures reorganization with YaraEditor database
- Donation text rewording
- Fixed big files scan
- Switched Yara fast mode ON
- Fixed tasks working dir recognition
V12.8.6 12/19/2016
- Added detections
V12.8.5 12/12/2016
- Added detections
V12.8.4 12/05/2016
- Added detections
- RogueKillerDLL 1.0.3
- Fixed a bug in licensing, where it was impossible to remove license if about to expire
V12.8.3 11/28/2016
- Added detections
V12.8.2 11/21/2016
- Added detections
V12.8.1 11/14/2016
- Added detections
- Fixed update page translations
- Fixed eula page translations
- Fixed machine identification method
V12.8.0 11/07/2016
- Added detections
- NEW! Chrome configuration scanner
- Added Print Providers scanner
V12.7.5 10/31/2016
- Added detections
- Fixed COM crash on some machine at initialization
- Added Svchost path parser and service scanner
- New telemetry
- Fixed hidden tasks not being scanned
V12.7.4 10/24/2016
- Added detections
- Fixed COM init/close implementation, that led to a hang on Windows XP
- Improved path parsing security
- Now path parser is able to scan for powershell EncodedData payloads
V12.7.3 10/17/2016
- Added detections
- Fixed bugs in task scanner prenventing from scanning entirely and removing tasks
- Fixed a bug with exit button
- Now installer has complete version number
V12.7.2 10/15/2016
- Emergency fix for ADS false positive
V12.7.1 10/10/2016
- Added detections
V12.7.0 10/03/2016
- Added detections
- Improved filesystem scanner
- Improved telemetry
- Added winsock scanner
- Fixed a bug in installer
- Fixed installer error messages translations
V12.6.4 09/26/2016
- Added detections
- Fixed a bug in disk serial read
V12.6.3 09/19/2016
- Added detections
- NEW! Firewall rules scanner
V12.6.2 09/12/2016
- Added detections
- Fixed a bug in LNK cleanup
- Added powershell path parser
V12.6.1 09/06/2016
- Fixed missing resources (leading to a crash)
V12.6.0 09/05/2016
- Added detections
- Fixed a bug where patched files were not fixed on removal
- Added warning when license is expired or about to expire
- NEW! WMI Scanner
V12.5.2 08/29/2016
- Added detections
V12.5.1 08/22/2016
- Fixed a bug in Yara module
V12.5.0 08/22/2016
- Added detections
- Added file exclusion for forged files
- Fixed a bug where big files were detected as VT.Unknown
- Updated scanner to use Yara 3.5: https://github.com/VirusTotal/yara/releases/tag/v3.5.0
- Fixed (Yara 3.5): Processes scan doesn't use all memory/cpu
- Improvements (Yara 3.5): Scan is faster
V12.4.4 08/16/2016
- Added detections
V12.4.3 08/08/2016
- Added detections
V12.4.2 08/01/2016
- Added detections
V12.4.1 07/28/2016
- Added detections
Prosím o kontrolu Logu NTB
Re: Prosím o kontrolu Logu NTB
- Shortcuts scanner now cleans them instead of removing
V12.4.0 07/18/2016
- Added detections
- Added Feed fallback (no more blank thing when website is slow)
- Added Shortcuts scanner
- Added Tasks scanner (by name/path)
- Moved IRP scan to expert mode
- Fixed a bug where LNK pointed by tasks where not resolved
- Added registry Classes scanner
- (Premium) Added -noremove switch, to ignore detections
V12.3.8 07/11/2016
- Added detections
- New feed version, with licensing filtering
- Registry scanner enhancement: Now stops the service before removing a service key
- Fixed a bug where Processes files were marked as missing
- Fixed VT score display
V12.3.7 07/04/2016
- Added detections
- Updated internal links
V12.3.6 06/27/2016
- Fixed a bug leading to app being quit when a message is closed while in tray.
- Now displaying warnings on "Expert settings" turned on.
V12.3.5 06/22/2016
- Fixed all links, now using a file provider API.
V12.3.4 06/20/2016
- Added detections
- Added folder children exclusion scanner rule
- Signatures normlization
- Fixed a bug leading to hosts file not being scanned
V12.3.3 06/13/2016
- Added detections
- Fixed a bug where HTML reports were'nt readable on Chrome
V12.3.2 06/06/2016
- Added detections
- Fixed possible crash on Intel files scan
- Refactor of marketing page
- Fixed a bug in VirusTotal upload leading to files not being sent for analysis
- Minor UI improvments
V12.3.1 05/30/2016
- Added detections
V12.3.0 05/22/2016
- Added detections
- NEW! (Premium) Themes
- NEW! Clear theme
- NEW! Naked theme
- NEW! Dark theme
- Modified stats payload
- Update form: Now displays a warning when Updater is not present
- Update form: Now opens direct link to setup for Premium user in case Updater not present
V12.2.1 05/16/2016
- Added detections
- Fixed transfer progress reset
- Fixed UI hangs bug in old GUI
V12.2.0 05/10/2016
- Added detections
- Fixed a bug preventing from starting the scan on machines with 1 CPU
- Added a Quit button (useful when you want to skip close to tray)
- Fixed links in About tab
- Fixed check for updates (was not showing outdated when update arrives after the program is started)
V12.1.6 05/09/2016
- Added detections
- Improvement of path parsing module, added "cmd start x" method.
V12.1.5 05/02/2016
- Added detections
- Update form now shows changelog
- Fixed RKAdmin link in updater
V12.1.4 04/25/2016
- Added detections
- Fixed forged files dump to VT
- Now displays a warning when using wrong bits version
- Now shows GeoIP results
- Fixed an issue in updater where RogueKillerCMD wasn't recognized
V12.1.3 04/18/2016
- Added detections
- Fixed default check state in installer
- Fixed a bug that allowed check state modification of non-removable items
- Updater now uses cloud link
- Feed now uses cloud link
- Fixed a bug in GeoIP module
- Fixed a potential crash in MBR reading
V12.1.2 04/11/2016
- Added detections
V12.1.1 04/04/2016
- Added detections
- Now file replacements are made with sfc.exe on Vista+
- Added button to remove trial
- Fixed a bug in Chrome scanner preventing the scan from starting
V12.1.0 03/29/2016
- Added detections
- NEW! Tools menu
- NEW! Hosts File Tools menu (Premium)
- Fixed a bug in context menu actions
V12.0.3 03/21/2016
- Added detections
- Added indonesian language
- Added more translators names
- Fixed a bug in AutoStart/AutoDelete
- Fixed a bug preventing to quit on Update
- Added a link to Lost license form
V12.0.2 03/14/2016
- Added detections
- Added crash dump form
- Fixed a bug that showed steps not supposed to run
- Updated translations / Fixed typos
- Added Data column in scan results
- Fixed Autoscan
- Fixed Autoremove
- Now scan progress live detection shows in red when an item is detected
- Fixed a bug that led to driver state being wrong in reports
V12.0.1 03/07/2016
- New user interface
- Added detections
V11.0.14 02/29/2016
- moved driver loading at the beginning of the scan
- introducing expert mode
- processes no longer killed during scan (killed at removal, on demand)
- moved IAT scanning into expert mode
- core preparation for V12
- Added detections
V11.0.13 02/22/2016
- moved signatures loading at the beginning of the scan
- Added detections
V11.0.12 02/15/2016
- Added detections
- Fixed a bug in Files module
- Fixed a bug in Web module
V11.0.11 02/08/2016
- Added detections
V11.0.10 02/01/2016
- Added detections
V11.0.9 01/25/2016
- Added detections
- Updater 2.1
- Updater can now serves installable version
- Updater can now skip licensing page if already registered
V11.0.8 01/19/2016
- Added detections
- TrueSight v2.0.2 (fixed digital certificate for SHA1)
- Added Turkish language
V11.0.7 01/11/2016
- Added detections
- Added ADS whitelisting/blacklisting
V11.0.6 01/04/2016
- Added detections
- Using new licensing API
V11.0.5 12/28/2015
- Added detections
- Now setup will verify license key when entered
V11.0.4 12/20/2015
- Added detections
V11.0.3 12/14/2015
- Added detections
- Added translations in setup
V11.0.2 12/07/2015
- Fixed a bug in Buffer search
V11.0.1 12/07/2015
- Added detections
- Fixed a possible bug in scanner
- Fixed a possible issue in COM module
V11.0.0 11/30/2015
- Added rating link in marketing window
- Now detects ADS (Alternate Data Streams)
- Qt 5.5
- Moved Prescan into Scan
- Now IAT scan is able to scan Microsoft Edge
- Better hooks report for kernel hooks
- Truesight v2
- Now kernel hooks are scanned on userland
- Fixed a bug in COM module
- Added software keys detection
- Added registry path signatures
- Added detections
V10.11.7 11/23/2015
- Added detections
- Fixed a possible hang issue on HTTP calls (timeout broken)
- setup improvments, ability to deploy both version (32/64 bits)
- setup improvments, banner and translations
- fixed a possible crash in junctions data parsing
V10.11.6 11/16/2015
- Added detections
- Fixed a bug that closed the app when closing child window when minimized in tray
- added -reportpath command line parameter
- UI tweaks
V10.11.5 11/09/2015
- Added detections
V10.11.4 11/02/2015
- Added detections
- Fixed a bug in licensing engine, leading to a lost of configuration sometimes.
- Fixed a bug in processes module where main module was not good
- Fixed a bug in processes module where Updater was crashing if a very long command line was passed
V10.11.3 10/26/2015
- Added detections
- Added warning when driver is not loaded
- Fixed Microsoft Security Client as legit parent for svchost
- (Premium) Added Premium label in reports
- (Premium) Added information for external scanner (tab in settings)
- (Premium) Now application closes in tray and persist
- (Premium) Now able to start a scan from the tray icon
- Fixed a bug where services/windows were not scanned
- Fixed a bug where filesystem was not properly scanned
V10.11.2 10/20/2015
- Fixed a crash in Buffer module
- Moved rebranding to Premium Technician
V10.11.1 10/19/2015
- Added detections
- Moved rebranding to Premium documented features
- Fixed an issue with IAT scan progress (progress reset after process scan)
- NEW! (Premium Technician) Added an option to limit time validity of portable config files
- Improved performance of filesystem scanner (scan is now much faster)
- Whitelisted Chrome sandbox IAT hooks
- Added timeout for file shortcut resolution (improves performance of filesystem scanner)
V10.11.0 10/12/2015
- Added detections
- Added filter on VirusTotal internal submit (no user file)
- Improved shellcode module detection in inline hooks module
- Fixed memory growth while scanning filesystem
- IAT scan is now much faster because only scanning windows DLLs table
- Table-based hooks have cleaner display in logs (module!export)
- Fixed a bug in modules enumeration on 64 bits
- Excluded wow64cpu enter from inline hooks detection
- Now inline hooks architecture detection relies on import module architecture instead of process
- RogueKillerCMD: Added -dont_ask switch (to eliminate all user interactions and use default actions)
V10.10.9 10/05/2015
- Fixed bug in Disk module
- Fixed bug in IAT parser
V10.10.8 10/05/2015
- Added detections
- Now Updater restarts application using same command line parameters
V10.10.7 09/28/2015
- Added detections
V10.10.6 09/21/2015
- Added detections
- New social icons
- RogueKillerCMD: Added build number, licensing state
V10.10.5 09/14/2015
- Added detections
V10.10.4 09/04/2015
- Added detections
- Updated links
- (Premium) Added notification when license is about to expire
- Fixed bug in Disks module
V10.10.3 08/31/2015
- Added detections
- Now all legit antirootkit entries are hidden
- fixed a bug in Process module
- internal reorganization
V10.10.2 08/24/2015
- Added Detections
- NEW! Added Processes list to json report
- NEW! (Premium) Added -vtupload yes/no command line parameter
- Updated EULA to reflect licensing terms
- Added help button in "?" menu
- Fixed way of reading disk serial
- Fixed a bug in VT scanner
V10.10.1 08/17/2015
- Added detections
- (Premium) Added message when Updater is not present and program is outdated
- Added link to public Trello board
- Added version check in about form
- NEW! VirusTotal choice for upload
- NEW! (Premium) VirusTotal choice setting
- Fixed automatic updates when Updater is not present
- NEW! EULA will show up again if a new version is present
- Extended injection signature search to 4 sections (instead of 1), to better identify injection code.
- Now infection urls for antirootkit point to non technical posts
- Resized main and about forms
- (Premium) Added more information in licensing server check
- (Premium) Prepared for annual subscription switch
V10.10.0 08/11/2015
- Added detections
- Compatibility with Windows10
- Added error message when key has wrong pattern
- NEW! File Scanner is more aggressive, and will search in a lot more locations
- Fixed a bug in honey module
- Fixed a bug in logging module
V10.9.4 07/30/2015
- Added detections
- Fixed file scan when path contains unicode characters
- Fixed offline licensing issue (License was not recognized when no internet available). Now once registered (with internet on) it works offline.
- NEW! (Premium) Tray icon phase 1.
V10.9.3 07/21/2015
- Fixed a crash when scanning Digital Certificate of some files
- Fixed a FP when LNK files have unicode characters in path (OneNote 2010 - Capture d??cran et lancement.lnk)
V10.9.2 07/20/2015
- Added detections
- NEW! HTML reports
- NEW! HTML Open button
- NEW! TXT Open button
- NEW! HTML log setting + command line parameter
- Fixed timeout for Curl operations (max 5 seconds)
- NEW! signature database is now pre-compiled, will load much faster
- Updated Yara engine to 3.4
- Refactored Digisig engine, better performances
- Added more information in Json log for killed processes
- Fixed a bug where x64 processes names are not found when using x86 version
- Fixed path whitelist priority on VT blacklist (processes scanner)
- Fixed an issue where Floppy drives become very noisy during scan
V10.9.1 07/09/2015
- Added detections
- NEW! Added Open Text button in Json log viewer.
- NEW! Korean language
- Fixed Scan randomly performed.
- NEW! Command line parameter: -reportformat [txt|json]
- NEW! Report format setting
- Merged Txt report generation with Txt export
V10.9.0 07/06/2015
- Separate database for RogueKillerCMD / Updater
- NEW! Updater is now generic (cannot be used by double click anymore, takes command line)
- NEW! RogueKillerCMD can now use automatic updates
- NEW! RogueKillerCMD has now a version check
- NEW! RogueKiller has now accessibility (JAWS compatibility)
- Added detections
- -autodelete implicit has been removed from -hide
- Fixed a bug in RogueKillerCMD where command line isn't handled correctly
- NEW! RogueKiller now uses JSON as root format for reporting
- NEW! RogueKiller can open JSON logs into a new window
- NEW! JSON logs can be exported in RAW text format
- NEW! setup now embeds RogueKillerCMD
- Fixed a bug in tasks scanner
- Fixed certificate timestamp
V10.8.7 06/29/2015
- Removed AV.Killer definition (too many FPs)
- Fixed a bug in mstring module, leading to infinite loop in certain circumstances
- Now tasks scanner scans arguments too
- Added detections
V10.8.6 06/22/2015
- Adjusted AV.Killer definition
V10.8.5 06/22/2015
- Added detections
- NEW! External Scanner
- Fixed a bug in Process Scanner
- Fixed a bug in File Search
- Fixed a bug in Registry Scanner
- Now process paths are expanded
- Fixed a bug in -autoscan
V10.8.4 06/16/2015
- Added Skype to exclusions for RunPE detections
V10.8.3 06/15/2015
- Added detections
- NEW! RunPE heuristic detection
- (Premium) Removed Paypal/Premium images
- Refactored settings form
- NEW! (Premium) -autoupdate command line parameter + setting
- Fixed a bug in WebServer (Not starting sometimes)
V10.8.2 06/09/2015
- Using Licensing 2.0
- Added detections
V10.8.1 06/03/2015
- Fixed a bug in Licensing
- Fixed a bug in VirusTotal module
- Now portable license generated file is read-only
- Added GUI indicators when using portable license
- Added detections
- Extension checker optimizations
V10.8.0 06/01/2015
- Updated database
- Fixed a bug in reporting
- Disabled PUM.DesktopIcons (too confusing, and not critical)
- Disabled PUM.Orphan (too confusing, not critical)
- Better unit testing
- Initialization optimizations
- NEW! (Premium) Web service
- NEW! Web service /info url (get version info)
- NEW! Web service /scan/new url (start new scan)
- NEW! Web service /scan/status url (get scan status)
- NEW! Web service /report/last url (get last report)
- NEW! (Premium) -pupismalware command line parameter + setting
- NEW! (Premium) -pumismalware command line parameter + setting
- Reverted portable fixed location in rk_config.ini
- Fixed error message when too many instances
- Setup now adds RogueKiller bin folder to %PATH%
- Updated userland certificate
- NEW! Promotional nag.
V10.7.0 05/25/2015
- New configuration module, not compatible with old one. Able to use read-only medium for portable license.
- NEW! no more rk_config.ini for technician license.
- NEW! command line parameter: -portable-license
- Updated languages
V10.6.5 05/20/2015
- Fixed a bug with KnownDLLs detection when value name starts with underscore (_)
V10.6.4 05/18/2015
- NEW! Preferred language is now saved
- Added detections
- Fixed processes scan aggressiveness
- NEW! Logo can now be rebranded (Please contact us)
- Fixed a bug in Extensions Checked
- Fixed a bug in CLSID scanner
- Fixed Orphan detection level + vendor name => PUM.Orphan
- Fixed License fallback state
- Added new autostart locations
- Added Transfert progressbar
V10.6.3 05/11/2015
- Added detections
- Fixed a bug in File Search module
- Increased feed rotation time
- Better UI information
- Deactivated VT IP scan (too many FPs)
V10.6.2 05/04/2015
- NEW! Breaking news banner
- External libs update + optimizations (Zlib, SQLite, udis86)
- Fixed a bug in Tab navigation
V10.6.1 04/27/2015
- Now VT file scan has minimum/maximum size
- Refactored PUP/PUM classification to be clearer and more consistent
- Fixed VT file scanner scanning LNK files instead of target
- Now VT unknown s classified as PUP
- Now VT cache has outdated date (fixed to 5 days)
- Now VT scanner rescans pending items at initialization
- Added detections
V10.6.0 04/20/2015
- Added detections
- Moved version check before Prescan
- Fixed a bug in IAT scanner, where call stack was not recorded correctly
- Fixed a bug in IAT scanner, where unknown module was not displayed
- Fixed a bug in RogueKiller OLD GUI, where config file was not read properly
- Fixed ShowLegitHooks command/setting
- Fixed slow UI when a lot of entries are added to a table
- Fixed a bad items insertion when sorting was enabled
- Fixed a bug in MBR (GPT) module
- Fixed missing Premium info when internet access is broken
- Fixed a bug in libcurl library (X64)
- Added new method to detect IAT inline hooks
- NEW! VT Scan on registry, tasks, files, mbr, web browsers and antirootkit scans.
- NEW! VT scan no more in beta
- NEW! VT scan now scans all processes
- NEW! VT scan has local caching
V10.5.10 04/13/2015
- Added detections
- Now can register Premium with command line parameter: -register <email> <key>
- Now displays remaining activations for Premium
- All communications are now using SSL (HTTPS)
- RogueKillerCMD: Added better colors
- RogueKillerCMD: Now can recognize RogueKiller's command line parameters
V10.5.9 04/07/2015
- Added detections
- Now logs are sorted by date
- Now can attach last log even if a scan was not performed in the same session
- Fixed a bug where registration form cannot upload last report
- Removed Post Delete message asking for Premium buying when a user is already registered
- Now file scanner shows unscanned files (for progression), so that software doesn't give an impress of being stuck
V10.5.8 03/30/2015
- Added detections
- Fixed a bug where config isn't reset after removing the license.
- Fixed NoPop configuration bug
- Added all command line parameters in Settings
- Now registration Id/Key are trimmed to avoid copying/writing spaces before/after them (and have wrong key error message)
- Fixed updater now recognizing License on Windows 8 (now needs admin rights to be launched).
- Updated EULA to reflect VirusTotal integration rules.
V10.5.7 03/22/2015
- Fixed a crash when starting the application
V10.5.6 03/21/2015
- Added detections
- Fixed bug forbidding technician licenses to use command line
- Added Persian translation
- Fixed a possible hang on service termination
- Added progress text on progressbar during the scan
- NEW! VT scan on Processes (beta, only premium, disabled by default)
- NEW! VT scan on Services (beta, only premium, disabled by default)
- RogueKillerCMD : removed tutorial opening in case of an infection
V10.5.5 03/16/2015
- Added detections
- PREMIUM: Added more settings options
- Unhidden premium options, added Nag message
- Moved Scan choices to settings
V10.5.4 03/12/2015
- Added detections
- Added credits for translators (About)
- Now service scanner is aware of ServiceDll path
- Now Premium registration email is trimmed (remove spaces before and after the email)
V10.5.3 03/10/2015
- Fixed a bug in Path module where all shortened path were not properly expanded (Ex: LogMe~ => LogMeIn Rescue Applet)
V10.5.2 03/09/2015
- PREMIUM: Technician License can now use portable config file
- Added Premium logo
- Fixed a bug when opening website
V10.5.1 03/05/2015
- Using new licensing system
- Added detections
V10.5.0 03/01/2015
- NEW! Now RogueKiller is available with an installer
- PREMIUM: Separate updater
- PREMIUM: Trial of 30 days per machine
- Added detections
- Fixed a crash in jansson library
V10.4.3 02/23/2015
- Added detections
V10.4.2 02/23/2015
- Added detections
V10.4.1 02/19/2015
- Added detections
V10.4.0 02/18/2015
- Uniformization of whitelists/blacklists (we dropped a lot of detections, this can lead to false positives...
...but they will be fixed as people report them)
- Fixed a bug in LNK signature detection
- Fixed a buf in Time module
- NEW! Better CLSID scanner
- NEW! Now MBR scanner is EFI compatible
- Updated italian translation
V10.3.0 02/16/2015
- Added detections
- New command line flag: -showlegithooks (Shows legit hooks that are normally hidden)
- Big improvements in the IAT hooks engine; Preparation of refactoring for the kernel hooks.
- Big improvements in Extension Checker module
- NEW! Arabic translation
- Updated Yara engine to 3.3
V10.2.0 01/19/2015
- Added detections
- Updated Italian translation
- Added Chinese traditional translation
- Fixed a bug in Registry scanner where .DEFAULT hive is not scanned
- Added MBR signature for FinFisher
- Added MBR signature for TDL4
- Added MBR signature for Rovnix
- Fixed some bugs in MBR scanner
- Improved low level disk access library
- Added VBR (Volume Boot Record) scanner
V10.1.2 01/06/2015
- Added detections
- Updated Spanish translation
- Added Italian translation
- Added hook signatures engine
V10.1.1 12/23/2014
- Added detections
- PREMIUM: Added settings form
- PREMIUM: Added MBR Scan setting
- PREMIUM: Added Honey Scan setting
- PREMIUM: Added Antirootkit Scan setting
- PREMIUM: Added Open website setting
- Added Dutch translation
- Added sanity check for website opening
V10.1.0 12/11/2014
- Added detections
- Fixed mbamservice false positive
V10.0.9 12/08/2014
- Fixed Xpaj false positive with DiskCryptor MBR
- Added DiskCryptor MBR signature
- Added detections
- TrueSight 1.0.4: Better shellcode module detection
- IAT Hooks: Better shellcode module detection
V10.0.8 11/20/2014
- Added detections
- Fixed bug of processes not killed
- Now process memory is scanned before path scan
V12.4.0 07/18/2016
- Added detections
V12.3.8 07/11/2016
- Added detections
V12.3.7 07/04/2016
- Added detections
V12.3.6 06/27/2016
V12.3.5 06/22/2016
V12.3.4 06/20/2016
- Added detections
V12.3.3 06/13/2016
- Added detections
V12.3.2 06/06/2016
- Added detections
V12.3.1 05/30/2016
- Added detections
V12.3.0 05/22/2016
- Added detections
- NEW! Clear theme
- NEW! Naked theme
- NEW! Dark theme
V12.2.1 05/16/2016
- Added detections
V12.2.0 05/10/2016
- Added detections
V12.1.6 05/09/2016
- Added detections
V12.1.5 05/02/2016
- Added detections
V12.1.4 04/25/2016
- Added detections
V12.1.3 04/18/2016
- Added detections
V12.1.2 04/11/2016
- Added detections
V12.1.1 04/04/2016
- Added detections
V12.1.0 03/29/2016
- Added detections
- NEW! Tools menu
V12.0.3 03/21/2016
- Added detections
V12.0.2 03/14/2016
- Added detections
- Fixed Autoscan
- Fixed Autoremove
V12.0.1 03/07/2016
- Added detections
V11.0.14 02/29/2016
- Added detections
V11.0.13 02/22/2016
- Added detections
V11.0.12 02/15/2016
- Added detections
V11.0.11 02/08/2016
- Added detections
V11.0.10 02/01/2016
- Added detections
V11.0.9 01/25/2016
- Added detections
- Updater 2.1
V11.0.8 01/19/2016
- Added detections
V11.0.7 01/11/2016
- Added detections
V11.0.6 01/04/2016
- Added detections
V11.0.5 12/28/2015
- Added detections
V11.0.4 12/20/2015
- Added detections
V11.0.3 12/14/2015
- Added detections
V11.0.2 12/07/2015
V11.0.1 12/07/2015
- Added detections
V11.0.0 11/30/2015
- Qt 5.5
- Truesight v2
- Added detections
V10.11.7 11/23/2015
- Added detections
V10.11.6 11/16/2015
- Added detections
- UI tweaks
V10.11.5 11/09/2015
- Added detections
V10.11.4 11/02/2015
- Added detections
V10.11.3 10/26/2015
- Added detections
V10.11.2 10/20/2015
V10.11.1 10/19/2015
- Added detections
V10.11.0 10/12/2015
- Added detections
V10.10.9 10/05/2015
V10.10.8 10/05/2015
- Added detections
V10.10.7 09/28/2015
- Added detections
V10.10.6 09/21/2015
- Added detections
- New social icons
V10.10.5 09/14/2015
- Added detections
V10.10.4 09/04/2015
- Added detections
- Updated links
V10.10.3 08/31/2015
- Added detections
V10.10.2 08/24/2015
- Added Detections
V10.10.1 08/17/2015
- Added detections
V10.10.0 08/11/2015
- Added detections
V10.9.4 07/30/2015
- Added detections
V10.9.3 07/21/2015
V10.9.2 07/20/2015
- Added detections
- NEW! HTML reports
V10.9.1 07/09/2015
- Added detections
V10.9.0 07/06/2015
- Added detections
V10.8.7 06/29/2015
- Added detections
V10.8.6 06/22/2015
V10.8.5 06/22/2015
- Added detections
V10.8.4 06/16/2015
V10.8.3 06/15/2015
- Added detections
V10.8.2 06/09/2015
- Added detections
V10.8.1 06/03/2015
- Added detections
V10.8.0 06/01/2015
- Updated database
V10.7.0 05/25/2015
- Updated languages
V10.6.5 05/20/2015
V10.6.4 05/18/2015
- Added detections
V10.6.3 05/11/2015
- Added detections
V10.6.2 05/04/2015
V10.6.1 04/27/2015
- Added detections
V10.6.0 04/20/2015
- Added detections
V10.5.10 04/13/2015
- Added detections
V10.5.9 04/07/2015
- Added detections
V10.5.8 03/30/2015
- Added detections
V10.5.7 03/22/2015
V10.5.6 03/21/2015
- Added detections
V10.5.5 03/16/2015
- Added detections
V10.5.4 03/12/2015
- Added detections
V10.5.3 03/10/2015
V10.5.2 03/09/2015
V10.5.1 03/05/2015
- Added detections
V10.5.0 03/01/2015
- Added detections
V10.4.3 02/23/2015
- Added detections
V10.4.2 02/23/2015
- Added detections
V10.4.1 02/19/2015
- Added detections
V10.4.0 02/18/2015
V10.3.0 02/16/2015
- Added detections
V10.2.0 01/19/2015
- Added detections
V10.1.2 01/06/2015
- Added detections
V10.1.1 12/23/2014
- Added detections
V10.1.0 12/11/2014
- Added detections
V10.0.9 12/08/2014
- Added detections
V10.0.8 11/20/2014
- Added detections
V10.0.7 11/20/2014
- Now process pages are scanned for whitelist
- Added detections
- Reverted some command line to free version: -nodriver -nokill -nopop -nothirdparty
V10.0.6 11/12/2014
- Fixed a bug in Process module (not enough rights to get process path)
- Fixed a bug in AV whitelist detection
- Added detections
V10.0.5 11/11/2014
- Now AV processes are whitelisted
- Added language separator for "Your language here"
- Added Injected process heuristic detection
- Fixed bad Zeus signature
- More aggressive against Poweliks processes
- Added detections
- Updated links
V10.0.4 10/29/2014
- Added link to translations in language menu
- Added Delay IAT in PE module
- Added Delay IAT hooks in antirootkit
- Now IAT hooks are printed to UI as they are scanned
- Removed ctfmon from sensitive processes
- Now detects Zeus variants
- Now informative texts are not elided
- Better choices (currency/amount) for Paypal form
- Removed unused resources
- Improvements in quarantine module
- Now DNS entries show country IP in text report
- PREMIUM: Added quarantine handler
- Added detections
V10.0.3 10/22/2014
- New user-agent: Now sends extended vendor names for real time monitoring
- Added detections
V10.0.2 10/16/2014
- Added detection of services hidden from SCM and from registry
- Dropped command line support in free version
- Removed EAT hooks (useless)
- Improved IAT hooks scanner (now scans all modules instead of main module)
- Fixed a bug in driver library (driver could not load under certain circumstances)
- Added Czech translation
- Added tooltip with detection level (for colorblind people)
- Added detections
V10.0.1 10/10/2014
- Improvements in Process library
- Added COM integrity check to disable COM calls when server is corrupted (Poweliks)
- Fixed Poweliks rule
- Added detections
- Fixed Bug in registry module
V10.0.0 10/08/2014
- Major UI changes
- Added support for future Premium version
- Added support for ShellIconOverlayIdentifiers and ShellServiceObjectDelayLoad keys
- Now CLSIDs are scanned for path and memory
- Added detections
V9.3.0 10/06/2014
- New Rules engine. Easier to maintain, more robust.
- Fixed a lot of bugs in Scanner engines.
- Added detections
V9.2.13 09/25/2014
- Fixed a bug in registry module introduced in 9.2.12
- Fixed a bug in process engine that forbids svchost processes to be killed
- Added detections
V9.2.12 09/23/2014
- TrueSight: 1.0.3: Fixed a Kernel stack overflow leading to a BSoD
- Better handling of multistring registry value/key names (ZeroAccess/Poweliks)
- Added Poweliks detections
- Added detections
V9.2.11 09/18/2014
- Added detection to new Poweliks variant
- Fixed a bug of infinite wait when COM objects are broken
V9.2.10 09/09/2014
- Fixed a bug in Yara scanner
- Fixed a bug in language module
- Fixed a crash dump uploader (due to surlatoile.org move to https)
- Added service binary path in report
V9.2.9 09/01/2014
- Updated Yara to 3.1.0
- Added detections
- Firefox PUM.HomePage is using domain whitelist
V9.2.8 08/15/2014
- Added detections
V9.2.7 08/15/2014
- Added scan of Search Page/Start Page for Internet Explorer
- Added scan of Start Page for Firefox
- TrueSight 1.0.2: Process Kill
- TrueSight 1.0.2: Registry key Kill
- TrueSight 1.0.2: File Kill
- RogueKiller: Implementation of new Truesight features
- RogueKillerCMD: Implementation of new Truesight features
V9.2.6 08/07/2014
- Removed a ZeroAccess false detection
- Fixed a bug in registry module (introduced in 9.2.5)
V9.2.5 08/07/2014
- Fixed a bug in registry module (poweliks/zeroaccess trick)
- Fixed a bug in command line parsing
- RogueKillerCMD: Added registry value/subkey removal by index
- Added detections
V9.2.4 07/24/2014
- Added detections
- Added Key present rule
- Added Value data rule
- Updated Yara
- Fixed a bug in file search module
- Fixed a bug in honey file module
- Fixed string limit in path module
- RogueKillerCMD: Registry Kill
V9.2.3 07/14/2014
- Fixed a bug in file module
- Added detections
V9.2.2 07/11/2014
- Fixed a bug in task scanner
- Fixed a bug in path parser
- Fixed a bug in install module
- Unknown MBRs are dumped in %programdata%/RogueKiller/Debug
- Added detections
V9.2.1 07/09/2014
- Fixed unicode hosts file read/write
- Fixed empty hosts lines scan
- Truesight 1.0.1
- Truesight now suspends TDL4 threads before MBR fix
- Removed debug messages from Truesight
- Fixed pcalua detection in task scanner
- Added links
V9.2.0 07/07/2014
- Truesight 1.0 (no more in beta)
- Truesight loads in X64
- Truesight rewriten from scratch (increased stability, code compatibility)
- Truesight now detects Filters (regular, reverse)
- Added detections
- Fixed regression about vendor url opening
- Fixed bug about duplicate registry entries on x86
V9.1.0 06/23/2014
- Added detections
- Fixed a problem of ProgramFiles/ProgramFilesX86/ProgrameFilesW6432 var env parsing
- Binaries are now digitally signed.
- updated translations
V9.0.3 06/17/2014
- Fixed encoding bug in quarantine handler
- Fixed crash window opening when no dump is available
- Fixed duplicated files in common startup folder on XP
- Detection of WinPE. Now LivePE/LiveUSB scan is faster and more accurate.
- Fixed reboot query
- Improved replacement method
- Fixed DNS whitelisting
- Added Zekos signatures
- Now file replacement engine looks for same file version before replacing.
- Fixed a bug in startup honey module
- Fixed a bug in mbr module
- Added detections
V9.0.2 06/04/2014
- Fixed a bug in registry scanner
- Fixed a bug in Buffer lib
- Added chrome extensions removal
- Fixed service repair
- Added single instance mutex
- Fixed a bug when trying to quit
- Added detections
- Added Necurs link
- Added pathparser special rules (rundll32, wscript)
- Fixed a bug in file parsing
- Fixed a bug in Honey module
V9.0.1 06/02/2014
- Fixed a bug in File lib
- Fixed a bug in GUI
- Optimizations in String parser
- Added detections
- Fixed a bug in addons detection
- Fixed a bug in forged file detection
- Fixed a bug in service scanner
- Now malware hooks are Orange
V9.0.0 05/29/2014
- Fixed bugs
V9.0.0 beta 3 05/26/2014
- CLI commands -nodriver -autoscan -autodelete -autoquit -autoeula -hideui
- Added detections
- Fixed EULA
- Added service repair
- Added check for updates
- Changed driver icon
- Added reboot notification
- Added pending detections notification on quit
V9.0.0 beta 2 05/23/2014
- Fixed a bug in MBR log
- Fixed a bug in Service log
- Fixed a bug in log (RTL characters removed, ZeroAccess)
- Replaced SUSP PATH label by Suspicious.Path
- Removed Chrome.exe IAT/EAT scan
- Fixed 3 bugs in IEAT/EAT display (process is displayed / legit entries are hidden / fixed size of function in console display)
- Now suspicious services registry keys are not prechecked (to avoid confusion with true malware)
- Disabled Forged files removal (except if contains malware signature), due to some false positives
- Fixed a bug in Registry subkey removal (ZeroAccess)
- Fixed a bug in File replacement (added ACL copy before replace, Zekos)
- Fixed a bug in ListView sorting (was too slow)
- Added detections
V9.0.0 beta 1 05/22/2014
- Added crash handler window
- Reports are now translated
- Added missing translations
- Added hover event for Facebook / Paypal links
- Added fancy Facebook button
- Replaced old icons by high res icons
- Added detections
- Fixed a bug in ComManager
V9.0.0 alpha5 05/21/2014
- Brand new high res icon! (thanks nfn678 from deviantart.com)
- Now sending statistics to adlice.com webserver database
- PUM color detection is now Dark Gray
- Added web browser scan
- Added stop button (during scan only)
V9.0.0 alpha4 05/20/2014
- Added context menu select/unselect all
- replaced old MBR display by a listview
- added MBR scan
- fixed carriage return bug in reports
- fixed bad driver decryption
- added Hooks scanner
V9.0.0 alpha3 05/19/2014
- Fixed a bug when exiting with file menu
- Added hosts fix button (hosts tab)
- Fixed window names bug (massive false positive)
- Added true version number comparison for version checker
- Fixed elided text bug
- Added report footer
- Now general progressbar is used as progression
- Now displays fine progression
- Added file scanner
V9.0.0 alpha2 05/16/2014
- Fixed a crash in Yara scanner on some processes
- Fixed a bug in Hidden processes detection
- Fixed a bug in report module, prescan results were removed from reports
- Fixed display bug (wrong X64 display in title)
- Fixed crash handler, now crash dumps will be located in %ProgramData%/RogueKiller/Debug
- Fixed display bug. After removal, status of items was not updated.
- Added Hosts file support
- Added Hosts file line removal
- Removed Proxy, DNS and Shortcut buttons/tabs
V9.0.0 alpha1 05/14/2014
- Rewritten engine from scratch ( RKSdk V1 )
- Moved to Yara scanner
V8.8.14 03/26/2014
- Fixed a bug in PE parser
- Optimizations
- Added detections
V8.8.13 03/25/2014
- Optimizations
- Prepare for 8.9.0
- NEW! Now scans IAT/EAT on x64 operating systems
- NEW! Now scans non-PE files (example: .bat)
- Addded detections
V8.8.12 03/20/2014
- Optimizations
- Prepare for 8.9.0
- Added Thanks for Downloading Url at first use.
- Fixed bug in MBR fix
- Fixed progressbar behavior
V8.8.11 03/14/2014
- Optimizations
- Added lot of PUP detections
- file path are elided in console
V8.8.10 02/28/2014
- Added detections
- Changed links
- Fixed a bug in File library
- RogueKillerCMD 0.1.3
* Added service list
* Added service kill
V8.8.9 02/24/2014
- Added double check for current version
- Added double post for autofeedback
- Changed sur-la-toile.com domain for new one surlatoile.org (fixed statistics and version check)
V8.8.8 02/19/2014
- URL are now localized
- Fixed tree process creation deadlock
V8.8.7 02/11/2014
- Fixed bugs in Hidden process detection
- Added traces for killed processes check bug.
V8.8.6 02/07/2014
- ACLs management improvement
- Fixed FP in hook module
- NEW! Google Chrome extensions are listed [Removal not supported yet]
- Fixed Zekos FP with Zanga.exe
- Fixed forum link in report
V8.8.5 02/03/2014
- Added debug trace for dllhost issue
- Added rogue detections
- Fixed duplicates in Firefox Addons list
- Added extensions.json / extensions.sqlite in the firefox watch list
- Now kills firefox before removing extensions
V8.8.4 01/27/2014
- Added ACL module.
- Fixed bug with ACLs when replacing patched file [Black Screen - Zekos]
- Restored Zekos signatures
V8.8.3 01/24/2014
- NEW! Extension removal for IE / Firefox (context menu)
- Neutralized Zekos signatures to avoid black screen at replacement. [To be fixed]
V8.8.2 01/17/2014
- NEW! Miuref detection and removal
- Added Zekos x64 detection
- Fixed a bug in core module
- Fixed a bug in driver module
V8.8.1 01/14/2014
- Fixed bug in registry module
- NEW! Zekos detection and removal.
V8.8.0 12/27/2013
- NEW! web browser addons are listed (Internet Explorer | Firefox )
- NEW! Cryptolocker pattern
- NEW! Killed process verifier. If some processes remain, they are killed by their whole tree.
- Added detections
V8.7.13 12/18/2013
- Translated Paypal Icon
- Fixed a bug in GUI lib
- Added PUP pattern
- Fixed a bug in File lib (ZeroAccess detection)
- Added addons tab
V8.7.12 12/16/2013
- Windows 8.1 detection
- Fixed bug in Shortcut mode
- Refactoring of File lib
- Added detections
- RogueKillerCMD 0.1.2
* Added process list
V8.7.11 12/04/2013
- Fixed a bug in UI lib
V8.7.10 12/04/2013
- Added detections
- RogueKillerCMD 0.1.1
* Fixed DLL dependencies
V8.7.9 11/25/2013
- Fixed a bug in regex parsing
- Optimization of regex
- Added 2 new methods for registry Read/Write
- NEW! Honey module now uses the Win32 API Offline method (Safer)
- Fixed a bug in script cleanup
- Added detections
- Added Error code for MBR read
- Removed ROGUE ST detection for registry values
V8.7.8 11/14/2013
- NEW! Added Zlib compression for crash dump sending
- Improvement of args handler
V8.7.7 11/11/2013
- NEW! new banner
- Fixed bugs in Registry module
- Fixed bug in PeParser
- Added progress window for crash report uploading
- Now collecting FUll dumps [This can be long, be patient!]
V8.7.6 10/28/2013
- Changed crash feedback for sending crash dump instead of custom crash logs
V8.7.5 10/22/2013
- Added useragent in debug log sending
- NEW! Geoloc for proxy / DNS IPs
- Fixed bug on TaskMan value
- NEW! -report_output and -hide switches
- NEW! Stop button
V8.7.4 10/16/2013
- Added COUNTRY in user agent of statistic module
V8.7.3 10/15/2013
- NEW! Detection/Removal of generic name mismatches in registry key/values (API fool trick -Rootkit)
- Fixed a bug in HiveReader module
- Fixed a bug in Pattern module
V8.7.2 10/10/2013
- Fixed memory leak in sigcheck
- Fixed bug in File module
- Added RECYCLER suspicious path (DorkBot)
- Added TaskManager key monitoring
V8.7.1 10/03/2013
- Fixed bugs in PeParser
- Fixed bug in IAT/ETA hooks
- NEW! Listview sorting
V8.7.0 09/30/2013
- NEW! Scan IAT/ETA of sensible processes
- NEW! Filesystem userland antirootkit
- Added colors to differenciate type of objects
- Added Romanian language
- Fixed bug in file deletion
- Fixed bugs in Pe parser
- Optimizations: Com library
- Fixed bug in GUI library
- Added detections
V8.6.12 09/18/2013
- Added detections
- Added MBR infos
- Added PUM label, and more consitent colors
- Fixed a bug in MBR module
V8.6.11 09/11/2013
- Fixed a crash a startup on x64 OS
V8.6.10 09/09/2013
- Fixed a bug in PeParser
- TrueSight 0.9.1
V8.6.9 09/03/2013
- Added Export parsing
- Fixed a bug in SSDT parsing
- Added detections
V8.6.8 09/02/2013
- Fixed a bug in peParser
- Truesight v0.9
----- Now Date in english format
V8.6.7 27/08/2013
- Fixed display issue
- Fixed problem in Registry module
- Added Rogue.AntiSpy-LSP pattern (Live Security Professional)
- Added detections
V8.6.6 19/08/2013
- NEW! Ability to resize the application (but still flickering when resized...)
- Fixed display issue in safe mode
- Removed Hosts scan if file is bigger than 1MB
- Added detections
- Fixed bug in removal
V8.6.5 04/08/2013
- NEW! Added support for new ZeroAccess variant (RTL)
- NEW! Added AutoRun value support in PE mode
- Fixed bug for rebooting query
- Fixed bug in file/folder deletion
- Removed unauthorized characters in report
- Updated links
V8.6.4 29/07/2013
- Fixed display bugs
- Added tab icons
- NEW! One scan can allow user to trigger each option once (Delete, HostsFix, DNSFix, ProxyFix)
- Fixed bug in DLL module
- Modified Honey display in report
- Fixed bug in file parser
- Added detections
- Database queries switched to UNICODE
V8.6.3 17/07/2013
- Added detections
- Fixed bugs
- Added crash feedback link into crash window
V8.6.2 02/07/2013
- Modified links
- Fixed bugs
- Added Turkish translation
- Added switches -autoscan, -autoaccepteula, -autoquit and -autodelete for automation of the flow
- NEW! Minidump writting for DEBUG version (in cas of crash)
- Added detections
V10.0.6 11/12/2014
- Added detections
V10.0.5 11/11/2014
- Added detections
- Updated links
V10.0.4 10/29/2014
- Added detections
V10.0.3 10/22/2014
- Added detections
V10.0.2 10/16/2014
- Added detections
V10.0.1 10/10/2014
- Added detections
V10.0.0 10/08/2014
- Major UI changes
- Added detections
V9.3.0 10/06/2014
- Added detections
V9.2.13 09/25/2014
- Added detections
V9.2.12 09/23/2014
- Added detections
V9.2.11 09/18/2014
V9.2.10 09/09/2014
V9.2.9 09/01/2014
- Added detections
V9.2.8 08/15/2014
- Added detections
V9.2.7 08/15/2014
V9.2.6 08/07/2014
V9.2.5 08/07/2014
- Added detections
V9.2.4 07/24/2014
- Added detections
- Updated Yara
V9.2.3 07/14/2014
- Added detections
V9.2.2 07/11/2014
- Added detections
V9.2.1 07/09/2014
- Truesight 1.0.1
- Added links
V9.2.0 07/07/2014
- Added detections
V9.1.0 06/23/2014
- Added detections
V9.0.3 06/17/2014
- Added detections
V9.0.2 06/04/2014
- Added detections
- Added Necurs link
V9.0.1 06/02/2014
- Added detections
V9.0.0 05/29/2014
- Fixed bugs
- Added detections
- Fixed EULA
- Added detections
- Added detections
- added MBR scan
V8.8.14 03/26/2014
- Optimizations
- Added detections
V8.8.13 03/25/2014
- Optimizations
- Prepare for 8.9.0
- Addded detections
V8.8.12 03/20/2014
- Optimizations
- Prepare for 8.9.0
V8.8.11 03/14/2014
- Optimizations
V8.8.10 02/28/2014
- Added detections
- Changed links
V8.8.9 02/24/2014
V8.8.8 02/19/2014
V8.8.7 02/11/2014
V8.8.6 02/07/2014
V8.8.5 02/03/2014
V8.8.4 01/27/2014
- Added ACL module.
V8.8.3 01/24/2014
V8.8.2 01/17/2014
V8.8.1 01/14/2014
V8.8.0 12/27/2013
- Added detections
V8.7.13 12/18/2013
- Added PUP pattern
- Added addons tab
V8.7.12 12/16/2013
- Added detections
V8.7.11 12/04/2013
V8.7.10 12/04/2013
- Added detections
V8.7.9 11/25/2013
- Added detections
V8.7.8 11/14/2013
V8.7.7 11/11/2013
- NEW! new banner
V8.7.6 10/28/2013
V8.7.5 10/22/2013
- NEW! Stop button
V8.7.4 10/16/2013
V8.7.3 10/15/2013
V8.7.2 10/10/2013
V8.7.1 10/03/2013
V8.7.0 09/30/2013
- Added detections
V8.6.12 09/18/2013
- Added detections
- Added MBR infos
V8.6.11 09/11/2013
V8.6.10 09/09/2013
- TrueSight 0.9.1
V8.6.9 09/03/2013
- Added detections
V8.6.8 09/02/2013
- Truesight v0.9
V8.6.7 27/08/2013
- Added detections
V8.6.6 19/08/2013
- Added detections
V8.6.5 04/08/2013
- Updated links
V8.6.4 29/07/2013
- Added tab icons
- Added detections
V8.6.3 17/07/2013
- Added detections
- Fixed bugs
V8.6.2 02/07/2013
- Modified links
- Fixed bugs
V8.6.1 17/06/2013
- Fixed bugs
- Improved filename parsing
V8.6.0 14/06/2013
- Changelog in English
- Rewrited whole engine
- NEW! Added icons in lists
- NEW! Added colors for Hosts lines detection
- Report: Splitted in object coherency (Tasks, Startup folders, registry)
- NEW! Honey module (previous PE module rewriten from scratch)
- NEW! .ini file for configuration storing
- NEW! Firefox malware detection module
- Added signatures
- Added ZeroAccess infection => Windows Defender repair
- Added disclaimer on Shortcut fix option
- Added hosts malicious lines identification in report
- Translations updated
- Added drivers to the patched files list to check
- Added service repair option (Tools/Repair services)
- Added Aho-Corasick algorithm for fast signature matching. Improved signature finding speed.
- NEW! Opera module - Added Proxy configuration
V8.5.4 18/03/2013
- D?tection de lignes malicieuses Hosts file
- Ajout de signatures
V8.5.3 13/03/2013
- Correction de bugs
V8.5.2 23/02/2013
- D?placement des signatures MBR dans la base de donn?es
V8.5.1 12/02/2013
- MAJ d?tection Necurs.A
- MAJ base de donn?es
- Correction d'un bug dans le module database
V8.5.0 08/02/2013
- Meilleure prise en charge de ZeroAccess
V8.4.4 01/02/2013
- Langue Italien
- Langue Polonais
- Langue Cor?en
- Module PE: Correction de bugs
- Module Reg: correction d'un bug
- Detection ZeroAccess - Am?liorations
V8.4.3 08/01/2013
- Langue Russe
- Module PE: Ajout des dossiers de d?marrage
- Module PE: Am?liorations diverses
V8.4.2 31/12/2012
- Am?lioration du module PE
V8.4.1 23/12/2012
- Correction d'un bug dans le module PE
- Correction d'un bug dans le module Files
- Correction d'un bug dans le module Hive
- Langue Spanish
- Dell MBR
V8.4.0 11/12/2012
- Optimisations de code pour passage en x64
- Version x64 disponible
- correction d'un bug dans le module Tasks
- correction d'un bug dans le module Hooks
V8.3.2 07/12/2012
- correction d'un bug dans le module startup
- correction d'un bug dans le module patched
- Correction d'un bug dans le module ntreg
- Possibilit? de d?senregistrer un service (ntreg) si impossibilit? de supprimer en mode RAW
- Prise en charge du MBR Fix pour TDL4 (Thanks XdeadCode)
- d?tection Root.MBR Alipop
- D?tection Root.MBR Mebroot
- D?tection Root.MBR Plite
V8.3.1 20/11/2012
- R?organisation du traitement
V8.3.0 17/11/2012
- Migration de la base de donn?es
- Bouton facebook
V8.2.3 07/11/2012
- Preparation ? SQLite
- Optimisation module parsing
- Correction d'un bug de d?tection du chemin process x64
- WL dll
HPStatusBL.dll
- Correction d'un bug dans le module Crypt
- WL
Screenpresso.exe
V8.2.2 03/11/2012
- Window BL
Micorsoft Essential Security Pro 2013
Windows 8 Defender 2013
- BL
MESP.exe
- Ajout d'une whitelist par chemin
- Corection d'un bug dans le module blacklist
- Modification du lien FR tutoriel
- Traduction N?erlandais
- Ajout de la date et du mode dans le nom du rapport
- Executable pack? UPX
- driver WL
sbhips.sys */ SunBelt */
d347bus.sys /* Daemon tools*/
- WL
Windir/VPro500.exe
windir/*np325.exe
- BL particular
Windir\\syswow64\\config\\systemprofile\\AppData\\Local\\{********-****-****-****-************}\\@
Windir\\syswow64\\config\\systemprofile\\AppData\\Local\\{********-****-****-****-************}\\U
Windir\\syswow64\\config\\systemprofile\\AppData\\Local\\{********-****-****-****-************}\\n
Windir\\syswow64\\config\\systemprofile\\AppData\\Local\\{********-****-****-****-************}\\L
V8.2.1 29/10/2012
- DNS WL
24.222.0.95
- Driver WL
avgtpx86.sys /*AVG*/
regguard.sys /*RegRun*/
- Whitelist
cdloader2.exe
magicJack.exe
AmazonCloudDrive.exe
V0220Mon.exe
msnotif.exe
LGMLauncher.exe
Communicator.exe
- Correction d'un bug dans le module debug
- Modifications du module d'importance
- Adaptation du driver pour Windows 8
- R?cup?ration des noms d'API SSDT en userland (compatibilit? Win8)
V8.2.0 22/10/2012
- Truesight v0.7
- Fix langue German
- Divers corrections de bugs
- Whitelist
sys32/pcalua.exe
LogMeInSystray.exe
Dashlane.exe
- DNS Whitelist
86.64.145.14*
129.250.35.251
- Driver WL
SbFw.sys /*GFI Software*/
- Window BL
File Restore (FakeHDD)
V8.1.1 01/10/2012
- Traduction Chinois traditionnel
- correction de bugs mineurs
- ajout de couleurs sur les listviews pour diff?rencier les type de d?tection
- correction d'un bug dans le module Blacklist
- Window BL
XP Defender 2013
Vista Defender 2013
Win 7 Defender 2013
V8.1.0 28/09/2012
- Support du changement de langue au runtime
- correction d'un bug dans le module processes
- ajout d'un bouchon MBR (pour les tests)
- ajout d'un lien "website" dans l'ent?te du rapport
V8.0.5 23/09/2012
- gestion des switchs de lancement
- ajout du switch "-nodriver" qui emp?che le chargement du driver
- ajout du switch "-nokill" qui emp?che le kill de processus (certains processus provoquent un BSOD au kill, il vaut mieux attaquer leur cl? de registre)
- ajout d'une cat?gorie "Extern Hive" dans le rapport => Listing des ruches externes trouv?es
- correction d'un bug dans le module Extern hives
V8.0.4 19/09/2012
- Encryption des fichiers en quarantaine (Utiliser Cryptonic avec la cl? "RogueKiller" pour d?chiffrer)
- optimisation du module WEB
- Ajout de la suppression hors API lorsqu'une cl? est prot?g?e
- Correction d'un bug dans le module HiveReader
- Suppression de la v?rification des cl?s LEGACY (pas utilis?)
- Dll whitelist
adawarebp.dll
SkyDriveShell.dll
V8.0.3 13/09/2012
- Correction d'un bug dans le module Registry
- Correction d'un bug dans le module File ASSO
- Correction d'un bug dans le module Proxy FF
- Prise en charge des rootkits maxSST (fix d?sactiv? car non test?)
- Deactivation of "Patched" module (not really used, to many false positives)
- Whitelist DLL
tv_w32.dll
- Whitelist
%Windir%/HelpPane.exe
TeamViewer.exe
tv_w32.exe
TeamViewer_Desktop.exe
ibsvc.exe
V8.0.2 31/08/2012
- Fichiers particuliers
\\RECYCLER\\[ANYFOLDER]\\$********************************\\n
\\RECYCLER\\[ANYFOLDER]\\$********************************\\@
\\RECYCLER\\[ANYFOLDER]\\$********************************\\L
\\RECYCLER\\[ANYFOLDER]\\$********************************\\U
\\$recycle.bin\\[ANYFOLDER]\\$********************************\\n
\\$recycle.bin\\[ANYFOLDER]\\$********************************\\@
\\$recycle.bin\\[ANYFOLDER]\\$********************************\\L
\\$recycle.bin\\[ANYFOLDER]\\$********************************\\U
- Incproc HJ
{fbeb8a05-beee-4442-804e-409d6c4515e9}
{5839fca9-774d-42a1-acda-d6a79037f57f}
- Blacklist
%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%.exe
V8.0.1 30/08/2012
- Whitelist
c2c_service.exe
SkyDrive.exe
procexp.exe
- Driver WL
RapportCerberus$ (trusteer)
- Truesight v0.6
Surveillance de DriverEntryIO
- Ajout patterns pour blacklist (GENDARMERIE)
install_0_msi.exe
hleo32.exe
regsrv64.exe
msconfig.dat
hos32.exe
V8.0.0 26/08/2012
- [[Ramaniement de Code]]
- Surveillance de la cl? HKEY_LOCAL_MACHINE\\SYSTEM\\CurrentControlSet\\services\\Tcpip\\Parameters : DataBasePath (HOSTS)
- Am?liorations diverses
- Ajout d'un cartouche d'information sur l'infection
- Refonte de certaines fenetres
- Whitelist
StatBar.exe
%windir%\^^Service.exe
%sys32%\iac25_32.ax
V7.6.6 10/08/2012
- Recherche de fichiers de remplacement en cas de fichiers patch?s.
- Remplacement des fichiers patch?s en mode SUPPRESSION
V7.6.5 03/08/2012
- Correction d'un bug dans le module peParser (PE x64)
- Ajout signature
ZeroAccess (services.exe x64)
- Windows BL
Live Security Platinum
V7.6.4 17/07/2012
- Ajout d'une blacklist pour valeurs de registre
- BlacklistValue
Update (GENDARMERIE)
fest0r_ot.exe
Schnarch.exe
- Whitelist DLL
cleanup.dll (MBAM)
- Windows BL
File Recovery
V7.6.3 08/07/2012
- Correction d'un bug dans le module HiveReader (gestion valeurs de registre unicode)
roper0dun.exe
rasmxs.exe
SCardDlg.exe
TapiSysprep.exe
0_0u_l.exe
glom0_og.exe
V7.6.2 02/07/2012
- Ajout d'un module de kill / relaunch de processus englobant la suppression de fichiers particuliers
(explorer.exe est tu? / r?activ?)
- Correction d'un bug dans la d?tection des fichiers particuliers
- Surveillance de la cl? : HKCR\\CLSID\\{42aedc87-2188-41fd-b9a3-0c966feabec1}\\InprocServer32 (ZeroAccess)
- Blacklist
sys32 / n
- Part files blacklist
windows\\Installer\\{********-****-****-****-************}\\L
localAppdata\\{********-****-****-****-************}\\L
sys32\\config\\systemprofile\\Local Settings\\Application Data\\{********-****-****-****-************}\\L
sys32\\config\\systemprofile\\Local Settings\\Application Data\\{********-****-****-****-************}\\U
sys32\\config\\systemprofile\\Local Settings\\Application Data\\{********-****-****-****-************}\\@
sys32\\config\\systemprofile\\Local Settings\\Application Data\\{********-****-****-****-************}\\n
V7.6.1 28/06/2012
- R?ctivation du module de recherche de signatures
- Ajout d'un module de v?rification des fichiers syst?mes (ASLR + recherche de signatures)
- V?rification du fichier services.exe
- Ajout signature
ZeroAccess (services.exe)
- Correction de bugs (module Window)
er_00_0_l.exe
V7.6.0 26/06/2012
- Ajout d'un contract utilisateur (EULA)
- Modification du module Particular files pour prise en compte des raisons de suppression + comparaison par masque
windows\\Installer\\{********-****-****-****-************}\\n
windows\\Installer\\{********-****-****-****-************}\\@
windows\\Installer\\{********-****-****-****-************}\\U
localAppdata\\{********-****-****-****-************}\\n
localAppdata"\\{********-****-****-****-************}\\@
windows\\Assembly\\GAC\\Desktop.ini
windows\\Assembly\\GAC_32\\Desktop.ini
windows\\Assembly\\GAC_64\\Desktop.ini
- Drivers WL
avgidsshimx.sys (AVG)
V7.5.4 07/06/2012
- Surveillance de la cl? : HKCR\\CLSID\\{F3130CDB-AA52-4C3A-AB32-85FFC23AF9C1}\\InprocServer32 (ZeroAccess)
- Ajout programdata dans chemins sensibles
pkg0u.exe
pkg_0ll.exe
WinzipArchiver.exe
TarArchiver.exe
Smoerrebroe.exe
tpl_0_c.exe
RarArchiverWin.exe
V7.5.3 05/06/2012
- Am?lioration de l'interface
- Revue des traductions
- Mise ? jour de la detection ZeroAccess (Sirefef)
krussel3.exe
AMD_cpx.exe
Apple_Store.exe
cs8v0k.exe
V7.5.2 30/05/2012
- Correction d'un bug faisant apparaitre une popup
- Am?lioration du module de redirection des chemins
- Whitelist
SpotifyWebHelper
%windows%/ALCMTR.exe
ArchiverforWin.exe
game_client.exe
WinArchiver.exe
V7.5.1 28/05/2012
- Am?lioration du module de comparaison par masque
- Surveillance de HKLM\\SYSTEM\\ControlSet001\\Control\\SafeBoot : AlternateShell
- Surveillance du registre x64 pour la cl? SHELL
k8h0pp.exe
temp##.exe
ServiceVBOX.exe
%sys32%/%%%%%%%%%%%%%%%%%%%%.exe
V7.5.0 24/05/2012
- Ajout de la possibilit? d'utiliser RogueKiller sous environnement PE.
- Possibilit? de scanner les ruches windows en branchement externe du DD.
- Correction d'un bug dans ntreg
- Ajout bureau dans suspect paths
k8h00.exe
VboxServs.exe
V7.4.5 18/05/2012
- Int?gration librairie ntreg
ch8l0.exe
p0j99p.exe
spoolsrv.exe
FSnapshot_x86.exe
BSI.bund.exe
GboxService.exe
InfoServices_a.exe
ksprskylabs1.exe
V7.4.4 08/05/2012
- D?tection de Xpaj (bootkit)
- Ajout de patterns de d?tection GENDARMERIE
ms.exe
#{1}.#{12+}.exe
wpbt#{1}.dl{2}
hnszs#{1}.exe
ms*****.bat
ram_reserver64.exe
itunes_service#{2}.exe
syncservicex86.exe
EPUhelpers.exe
DNS_Servicex86.exe
kitre#{1}.exe
V7.4.3 04/05/2012
- Mise en place des patterns pour d?tection des processus, cl?s RUN, SHELL, Startup
- TrueSight : Securisation du code
V7.4.2 03/05/2012
V7.4.1 02/05/2012
- Whitelist
E_FATIHJL.EXE
- Ajout du pattern GEMA
- Ajout du pattern GENDARMERIE
- Correction d'un bug dans le module readMBR
- Correction d'un bug dans le module SSDT
V7.4.0 01/05/2012
- Ajout du module ExceptionHandler => gestion automatique des plantages (en partie).
Quand un crash survient, une fen?tre s'ouvre et propose ? l'utilisateur de l'envoyer automatiquement.
- Window BL
Data Recovery (FakeHDD)
- Support des langues:
Allemand
V7.3.4 27/04/2012
- Ajout du module SigCheck, permettant la recherche de signatures dans les fichiers binaires.
=> Recherche de signatures dans les processus
- Correction d'un bug dans le module readMBR (r?organisation de la priorit? des signatures)
- Correctifs dans les resources de langue.
V7.3.3 22/04/2012
- Prise en compte de la valeur Start_TrackProgs (Programmes r?cents menu d?marrer)
- Modification des ACLs avant v?rification des cl? RUN (bug virus Gendarmerie)
Grec
Portugais
V7.3.2 20/03/2012
- [13/04/2012] Correction de bugs
- [03/04/2012] Window BL
SMART HDD
- [23/03/2012] Ajout lien vers Security Shield (blog)
- [22/03/2012] Module Debug - Second ajout
- [22/03/2012] Module statistique => Activation de plusieurs langages.
- [21/03/2012] Ajout progressBar (permet de savoir si un scan est en cours)
- [21/03/2012] Activation des styles visual
- [21/03/2012] Module Debug - Premier ajout
- [21/03/2012] Correction d'un bug
- [21/03/2012] Window Blacklist
System Shield
Security Shield
- Correction d'un bug dans le module startup
- Ajout de la surveillance du dossier "Common Startup"
- TrueSight v0.5 : Optimisations de code
- MAJ langue Czech / Slovak
- Ajout checkbox "AntiRootkit" qui d?sactive les fonctionnalit?s du module TrueSight
V7.3.1 10/03/2012
- Correction d'un bug dans le module faked
- Ajout d'une checkbox pour d?sactiver le module faked (le scan prend du temps)
- Whitelist
Skype.exe
FixCamera.exe
firefox.exe
plugin-container.exe
- Driver WL
Crypto.sys /*SafeNet*/
mfehidk.sys /*McAfee*/
wpsdrvnt.sys /*Symantec*/
V7.3.0 08/03/2012
- TrueSight v0.4
- Possibilit? de fixer les hooks inline.
- TrueSight : D?tection des hooks IRP (Major et Inline) sur un driver donn? -> Atapi.sys
- Possibilit? de fixer les hooks IRP inline (peut g?n?rer un BSOD dans certains cas, cette fonction reste ? am?liorer. A utiliser uniquement en dernier recours).
- Ajout d'un messagebox demandant confirmation si aucune suppression n'a ?t? effectu?e
- TrueSight : Bypass des fonctions du driver pour Windows 8 (pas compatible pour le moment)
- TrueSight : Optimisations de code
- Detection de Windows 8
- Correction d'un bug dans le module HiveReader (valeur / cl?s avec accents)
- Ajout d'un module de d?tection des fichiers FAKED (exp?rimental)
-> Appliqu? sur sys32/drivers
- Correction d'un bug dans le module SHELL
- Correction d'un bug dans le module STARTUP
- Correction d'un bug dans le module WEB
- Module Startup : Possibilit? de voir les dossiers de toutes les sessions (au lieu de la courante)
- Surveillance de la cl? HKCU\...\Advanced : Start_ShowRun
V7.2.1 29/02/2012
- TrueSight v0.3
- Detection des hooks inline (fonctions SSDT seulement)
- Driver WL
avipbb.sys /*Avira*/
avkmgr.sys /*Avira*/
- Window BL
Smart Fortress 2012
Windows Shield Tool
Windows PRO Scanner
Windows Basic Antivirus
Windows Stability Guard
Windows Firewall Constructor
V7.2.0 27/02/2012
- Ajout d'une option FixMBR dans l'onglet MBR. Cette option devient disponible si une infection MBR est trouv?e.
- Possibilit? de fixer le bootstrap MBR avec un MBR standard (XP, Vista ,Seven)
- Ajout d'un module de lecture directe des ruches => d?tection cl?s / valeurs cach?es de l'API
- d?tection MBR Toshiba
- d?tection MBR Lenovo
- d?tection MBR Standard
- d?tection MBR KIWI Image system
- Whitelist
Spotify.exe
jusched.exe (global)
- Window BL
Windows Functionality Checker
Windows Smart Warden
Home Malware Cleaner
Windows Smart Partner
Antivirus Protection
Windows Telemetry Center
Windows Perfomance Catalyst
Strong Malware Defender
V7.1.0 15/02/2012
- Passage du code en logique UNICODE (au lieu de ANSI)
- Ajout du support des langues:
Czech
Slovak
- Mise ? jour des d?tections MBR whistler/sinowal
- d?tection MBR myBIOS
- D?tection des MBR flood?s par NOP
- Blacklist window
Security Scanner
Internet Security
Internet Security 2012
- Rogue ProgFile
\\PCSpeed Service\\
\\everyclear\\
- Blacklist
gema.exe
V7.0.4 08/02/2012
- Ajout d'une checkbox pour d?sactiver le scan MBR (choix utilisateur)
- Correction d'un bug d'affichage faisant disparaitre les boutons dans certaines basses r?solutions d'?cran
V7.0.3 06/02/2012
- Modification du module LL2 => moins d'erreur d'acc?s, notemment sur les OS x64
- Correction d'un bug dans le workflow des modes secondaires
- Blacklist
InetAccelerator.exe (Gendarmerie2)
V7.0.2 30/01/2012
- Correction de bugs d'affichages (retours ? la ligne en trop) dans l'?dition du rapport
- Correction dans le module MBR => taille des partitions actualis? (1ko = 1024 octets)
- Whitelist
adawarebp.exe
DropBox.exe
- Rogue ProgFiles
\\BoanCatch\\
\\pcupgrade\\
\\best-pc\\
\\PCMaster Antispyware\\
\\InfoSeven\\
\\comdoumi\\
- Ajout pattern Rogue.ViusDoctor, Rogue.Zaxar
- Window BL
Antivirus Smart Protection
Malware Protection Center
V7.0.1 28/01/2012
- Correction d'un bug dans le module MBR => Type de partitions actualis?s
- Correction d'un bug dans le module MBR => Calcul des tailles de partition actualis?
- Passage ? 5 PhysicalDrive Max
- Ajout du nom des disques physiques
V7.0.0 26/01/2012
- Passage en mode GUI
V6.2.4 12/01/2012
[24/01/2012] - Ajout de cl?s Advance: Start_ShowMyDocs Start_ShowRecentDocs Start_ShowUser
Start_ShowMyPics Start_ShowMyGames Start_ShowMyMusic Start_ShowControlPanel Start_ShowDownloads
Start_ShowVideos Start_ShowHelp Start_ShowPrinters Start_ShowSetProgramAccessAndDefaults
[23/01/2012] - Correction d'un bug dans le module MBR
[23/01/2012] - Correction d'un bug dans le module TASKS
[23/01/2012] - Window BL : Smart Protection 2012
[16/01/2012] - Prise en charge des dlls lanc?es depuis un raccourci startup (virus Gendarmerie)
[16/01/2012] - Correction d'un bug dans le module checkPath
- Ajout HKEY_USERS\\Software\\Classes\\pezfile\\shell\\open\\command
- Ajout HKEY_USERS\\Software\\Classes\\.exe\\shell\\open\\command
- Ajout HKEY_USERS\\Software\\Classes\\exefile\\shell\\open\\command
- Correction d'un bug dans le module de sauvegarde REG
- Ajout de l'option a : WhyIGotInfected? => ouverture de la page de WIGI
- Ouverture de liens vers les manips du blogspot en fonction de l'infection detect?e (ZeroAccess, FakeRean)
V6.2.3 09/01/2012
- Whitelist
smad.exe
- Whitelist Dll
BatInfEx.dll
BatLogEx.dll
- Driver Whitelist
hookcentre.sys /*Gdata*/
- Window Blacklist
System Check
- Rogue ProgFiles
\\InfoSafe\\
\\CleanerCom\\
\\MicroVaccine\\
\\PC-Spider\\
\\CYAK\\
\\PcVirusDoctor\\
\\VDoctor Professional\\
\\CheckSpeed\\
V6.2.2 31/12/2011
- Detection MBR Code TestDisk
- Detection MBR Code HP tatou?
- Detection MBR Code Whistler
- Distinction entre Vista / 7 MBR Code
- Detection MBR Code Linux
- Correction d'un bug dans le module de backup REG
V6.2.1 28/12/2011
- Detection MBR codes XP et Vista/7
- Detection MBR codes MaxSS / TDL4 / PiHar
- Modification du module MBR (prise en compte de plusieurs PhysicalDrive)
- Whitelist DLL
%sys32%/LogiLDA.dll
panda_url_filtering.dll
nsMouselib.dll
msconf.dll
- Whitelist
B2CNotiAgent.exe
HpSAUpgrade.exe
HPSFUpdater.exe
panda_url_filtering.exe
MpSigStub.exe
dplaysvr.exe
realplayerent_config.exe
- rogue ProgFiles
\\info-manager\\
- Window BL
Security Monitor
V6.2.0 12/12/2011
- Ajout d'un module de d?tection des screensavers : HKEY_CURRENT_USER\\Control Panel\\Desktop : SCRNSAVE.EXE
- Mise ? jour du pattern ZeroAccess (d?tection du FS $NtUninstallKB / consrv.dll)
- Ajout de mot-cl?s d'importance dans les rapports (redirection des logs au niveau du serveur PHP)
- Ajout du pattern statistique Root.MBR
- Ajout check du MBR (LL2) + activation du module
- Dump des MBR trouv?s dans la quarantaine
- Modification de la fin du script => possibilit? de garder le notepad ouvert
- Rogue ProgFiles
\\datasave\\
\\sweeperlab\\
\\virussecurity\\
\\ProtectCop\\
\\HomeBoan\\
\\SmartSafer\\
- Whitelist
pccntupd.exe
pull.exe
RapportService.exe
HWDeviceService.exe
windir\v0330mon.exe
- Driver Whitelist
uphcleanhlp.sys /*WinXP (?)*/
FireTDI.sys /*Mac Afee*/
fslx.sys /*Symantec*/
savonaccesscontrol.sys /*Sophos*/
ShldDrv.sys /*Panda*/
bdrsDrv.sys /*BitDefender*/
- WhitelistDLL
rooksbas.dll
- Blacklist
%sys32/sysrunc.exe
V6.1.12 02/12/2011
- Ajout check du MBR (User / LL1) --> d?sactiv? pour tests
- Ajout pattern Rogue.AntiSpy-AH
- Window Blacklist
XP Antispyware 2012
XP Antivirus 2012
XP Security 2012
XP Antispyware 2012
XP Home Security 2012
XP Internet Security 2012
Vista Antispyware 2012
Vista Antivirus 2012
Vista Security 2012
Vista Home Security 2012
Vista Internet Security 2012
Win 7 Antispyware 2012
Win 7 Antivirus 2012
Win 7 Security 2012
Win 7 Home Security 2012
Win 7 Internet Security 2012
V6.1.11 30/11/2011
- Ajout d'un module de chargement direct du driver (plus efficace)
- d?sactivation du module "LOCKED"
- Window Blacklist
BlueFlare Antivirus
Wolfram Antivirus
OpenCloud Security
Malware Protection
Spyware Protection
Cloud Protection
Guard Online
AV Guard Online
Cloud AV 2012
- Rogue ProgFiles
\\NDoctorCom\\
\\perfectcare\\
\\privacyup\\
\\PowerPC\\
\\CleanCatch\\
- blacklist
Cloud AV 2012v121.exe
V6.1.10 18/11/2011
- Ajout d'un module de r?cup?ration des donn?es des pr?c?dents scans (PREVRUN)
- Rogue ProgFiles
sweeperlab
VirusSecurity
- Blacklist
AV Protection 2011v121.exe
- Window Blacklist
AV Protection 2011
V6.1.9 16/11/2011
- Ajout d'un module de v?rification des fen?tres windows ouvertes
- Ajout d'un module de r?sidu des process (pour registre)
- Window Blacklist
System Fix
Privacy Protection
AV Security 2012
System Restore
System Security 2011
AV Protection Online
Security Sphere 2012
- Driver WL
pxrts.sys /*PrevX real time scanner*/
guard.sys /*AVG 7*/
- Whitelist
%windows%\wanmpsvc.exe
%windows%\*snpstd$
%windows%\sttray.exe
%windows\lclock.exe
%windows\ATKKBService.exe
MessageCheck.exe
%windows\UpdReg.EXE
uUACTokenSvc.exe
GameXNGO.exe
- Whitelist DLL
LC.dll
npSkypeChromePlugin.dll
- Whitelist DNS
4.2.2.$
V6.1.8 14/11/2011
- Ajout Pattern: PrivacyProtection
- Ajout cl? : HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced : Start_ShowMyComputer
- Ajout cl? : HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced : Start_ShowSearch
- Whitelist
netsession_win.exe
SetWallpaper.cmd
TUAutoReactivator32.exe
%windows%\VM_STI.EXE
%windows%\ZSSnp211.EXE
%windows%\Domino.EXE
FacebookUpdate.exe
googletalkplugin.exe
%windows%\SiSUSBrg.exe
lsnfier.exe
%windows%\Imgtask.exe
mediaget.exe
%windows%\AutoKMS.exe
%windows%\mixer.exe
- Driver WL
SandBox.sys /*Sandboxy*/
RapportPG.sys /*Trusteer (Report)*/
sbaphd.sys /*Sunbelt*/
PavProc.sys /*Panda antivirus*/
PavSRK.sys /*Panda antivirus*/
- Dll WL
KeyboardOnlineTray.dll
mcdvd_32.dll
- Blacklist
AV Security 2012v121.exe
V6.1.7 05/11/2011
- Am?lioration du module statistique (Patterns ZeroAccess, Fake HDD, Rogue ProgFiles)
- Ajout d'un module de gestion de la reflection du registre (x64)
- am?lioration du backup en .reg (prend en charge les cl?s au lieu des valeurs seulement)
- Rogue ProgFile
\\PatchUp_Plus\\
\\NVirusKorea\\
\\ProtectCode\\
\\CoreScan\\
\\AntiAvoid\\
\\IPRIVACY\\
\\ProtectKeep\\
\\AnyCop\\
\\windowpc\\
- Whitelist
arservice.exe
supprim? kmservice.exe (crack pour Office 2010)
- Whitelist DLL
IadHide5.dll
V6.1.6 01/11/2011
- Ajout d'un module statistique (connexion base de donn?e SLT)
- DNS whitelist:
8.8.4.$
- Whitelist :
windows\BCMSMMSG.exe
windows\*snp2***.exe
windows\stsystra.exe
windows\qmc.exe
windows\cthelper.exe
windows\ALCXMNTR.EXE
sys32\ANIWConnService.exe
sys32\PSDrvCheck.exe
rnupgagent.exe
googletalk.exe
E_FATICDL.EXE
- Drivers WL:
OADriver.sys /*Online armor*/
sp_rsdrv2.sys /*Spyware terminator*/
cmdguard.sys /*Comodo IS*/
SYMEVENT.SYS /*Symantec*/
SASKUTIL.SYS /*SUPER Antispyware*/
PSINProc.sys /*Panda Security*/
- Whitelist DLL
migrate.dll
OIExt.dll
BthAuthenticationTime.dll
NativeHelpNotifier.dll
V6.1.5 29/10/2011
- Ajout d'un module de v?rification en ligne du num?ro de versio
- Ajout d'un module d'envoi automatique des rapports ? l'adresse du d?veloppeur (pour am?lioration de l'outil)
- Drivers WL:
fshs.sys /*F-Secure Orange AV*/
- Rogue ProgFiles
\\boankorea\\
\\FastScan\\
V6.1.4 22/10/2011
- Rogue ProgFiles
\\VirusScan\\
\\pcspeedup\\
- Drivers WL:
ehdrv.sys /*ESET Helper Driver*/
- Whitelist
AVGIDSMonitor.exe
- Ajustement de la d?tection dans le module RANDOMNAME
V6.1.3 14/10/2011
- TrueSight v0.2
- R?arrangement du code
- Ajout backup des suppressions registre en .reg
- Ajout d'un module de d?tection des noms al?atoires
- Blacklist
sys32\lvvm.exe
crss.exe (Cloud Protection)
- Rogue ProgFiles
\\realcleaner\\
V6.1.2 07/10/2011
- Drivers WL:
PCTCore.sys /*PCTools*/
bdselfpr.sys /*Bitdefender*/
- Kill des processus v?rouill?s
- WellKnown processes
audiodg.exe
- Rogue ProgFiles
\\vaccinecom\\
\\PCPlusSecurity\\
- WellKnown WL
sys32\ctfmon.exe
sys32\lsm.exe
sys32\SearchIndexer.exe
sys32\sppsvc.exe
sys32\SearchProtocolHost.exe
sys32\SearchFilterHost.exe
sys32\mctadmin.exe
sys32\dllhost.exe
sys32\alg.exe
sys32\wscntfy.exe
sys32\notepad.exe
sys32\wuauclt.exe
sys32\userinit.exe
sys32\msdtc.exe
windows\agrsmmsg.exe
- Whitelist dll
nvsysrot.dll
V6.X.X XX/XX/XXXX (Version repous?e)
- Module de suppression de cl?s (recursif) par appel direct
- chargement du driver en mode BOOT antagoniste si bloqu?
- Detection de cl?s de registres cach?es du SCM
- Ajout chemin sensible %sysroot% pour processus
- Ajout d'un module de detection des noms long -processus et cl?s- (Guard Online / OpenCloud / ...)
V6.1.1 28/09/2011
- Correction d'un bug dans le chargement / d?chargement du driver
- Supprim? messages debug
- TrueSight v0.1
- Ajout driver Whitelist avec masque
- Ajout blacklistPath dans recherche des services
- Drivers WL:
unknown /*Unknown*/
vsdatant.sys /*ZoneAlarm*/
procguard.sys /*ProcGuard*/
aswSP.sys /*Avast*/
aswSnx.sys /*Avast*/
PCTAppEvent.sys /*PCToolsFirewallPlus*/
sp**.sys /*Daemon tools*/
AVGIDSShim.Sys /*AVG*/
- Rogues progFiles
\\HelpPrivacy\\
\\InfoBoan\\
\\windowsliveprotect\\
\\DrBoan\\
\\Privacyi\\
\\Micropop\\
- Service Blacklist
MPopService
V6.1.0 22/09/2011
- R?cup?ration des vrais adresses de la SSDT
- Ajout option 7 (restauration de la SSDT par index) : OPTION CACHEE car dangereuse. A utiliser sur demande d'un helper
- module TrueSight : Restauration SSDT
- module TrueSight : Kill par appel direct aux APIs NT (DrvNtTerminate)
V6.0.0 21/09/2011
- Ajout d'un driver embarqu? dans les ressources
- Chargement du driver TrueSight (x86 seulement)
- Recherche des Hooks SSDT
- Recherche des Hooks Shadow SSDT
V5.3.5 21/09/2011
- WhitelistDLL
LVPrcInj01.dll
- Whitelist
kmservice.exe
- Rogues ProgFiles
\\BoanCop\\
\\cleancert\\
\\VIHunter\\
V5.3.4 30/08/2011
- Correction d'un bug dans la detection de la whitelist (masque)
- Ajout module de restauration des icones du bureau (SHELL)
- Ajout module de restauration de la barre des t?ches (SHELL)
- Ajout d'un mutex pour emp?cher le lancement de plusieurs instances
- Rogues ProgFiles
\\PrivacyBoho\\
\\SafePrivacy\\
\\BoanClear\\
- Whitelist
BR040286.exe
V5.3.3 18/08/2011
- Ajout d'un module de d?tection de fichiers / dossiers particuliers
- Blacklist Particular:
%Appdata%\Adobe\shed
%Appdata%\Adobe\plugs
- Dll Whitelist
rpchrome$
MSVC^71.dll
- Rogue ProgFile
\\errordoctor\\
- GUID
{19090308-636D-4E9B-A1CE-A647B6F794BF} //Wolfram antivirus
V5.3.2 18/08/2011
- Meilleure prise en charge du x64
--> Ajout des variables d'env SysWow64 / Program Files (x86)
--> Ajout de la restauration de Program Files (x86) dans le mode 6
- Optimisation de code
- WellKnownProcess:
varEnv.syswow64\\svchost.exe
- Whitelist:
nclaunch.exe
V5.3.1 06/08/2011
- Ajout d'un module de surveillance des cl?s manquantes
- Ajout des cl?s manquantes:
HKEY_CLASSES_ROOT\\exefile\\shell\\open\\command" => default : "%1" %*
- Rogue ProgFile:
\\PrivacyCode\\
\\InfoGuard\\
\\DefenseVirus\\
\\PatchUp_Plus\\
- Whitelist dll:
btmshell.dll
mkil.dll
V5.3.0 01/08/2011
- Detection des d?tournements des noms syst?me
- Le programme est maintenant capable de tuer un process de 6 mani?res diff?rentes
Cel? permet de contourner les protections de pas mal de malwares
- Service Blacklist:
wxpdrivers
srvsysdriver32
srvbtcclient
srviecheck
- Rogue progFiles
\\MacroVirus\\
\\DualVaccine\\
\\CodeScan\\
V5.2.9 31/07/2011
Windows_Update
- Dll Whitelist
MSVCP71.dll
- Whitelist
alcwzrd.exe
PLFset^.exe
V5.2.8 23/07/2011
- Ajout v?rification des .exe dans dossier d?marrage
- Dll Whitelist
Dropbox$
PLFSet.dll
-Whitelist
vsnp2uvc.exe
- Rogue progFiles
\\Clear2PC\\
\\PCMedic\\
\\boanking\\
- ajout BlackList
<user>\startupFolder\csrss.exe
V5.2.7 30/06/2011
- Correction de bugs (RegCloseKey)
- Correction de bugs provoquant un ?cran noir apr?s passge de OTL (au reboot)
V5.2.6 23/06/2011
- Ajout de la surveillance de la ligne:
HKEY_CLASSES_ROOT\.exe => default
V5.2.5 23/06/2011
Correction de bugs majeurs faisant planter l'appli
V5.2.4 22/06/2011
Rogue ProgFiles:
-\\privacyalpha\\
-\\basicprivacy\\
-\\MicroPC\\
-Whitelist
Bginfo.exe
PLFsetL.exe
- Ajout suppression ACL pour les cl?s Shell
V5.2.3 16/06/2011
- Blacklist
%ProgramFiles%\csrss.exe
%ProgramFiles\conhost.exe
- Service blacklist
QTUpdate
- Rogue ProgFiles
-\\Milestone Antivirus\\
V5.2.2 05/06/2011
- Ajout d'infos sur les lecteurs pour le mode 6
- Correction de bugs faisant planter les modes 6/1/2
V5.2.1 02/06/2011
- Correction de bugs faisant planter le module Task Scheduler 2.0
- Raports sur le bureau quelque soit le repertoire de lancement de l'application
V5.2.0 01/06/2011
- Blacklist service
cdfss
wcscd
- Prise en charge des cl?s
Software\\Microsoft\\Windows\\CurrentVersion\\Policies\\Explorer\\Run
HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\ShellServiceObjectDelayLoad
HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\SharedTaskScheduler
HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Explorer\\Browser Helper Objects
HKEY_CURRENT_USER\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Ext\\Stats
- V?rification et kill des DLL malicieuses charg?es sous explorer.exe
- Ajout du kill des dll explorer.exe dans les r?sidues
- Ajout d'un module d'exploration des GUID (Si un GUID est connu, on retrouve le chemin de la DLL malicieuse
et on l'ajoute ? la BlackList dynamique)
- Prise en charge du dossier Common Startup
V5.1.9 29/05/2011
- Rogue ProgFile:
\\vaccineu\\
- Affichage des icones User / Poste de travail / Corbeille sur le bureau
Hijack : WarnOnHTTPSToHTTPRedirect
- Whitelist
soundman.exe
- Blacklist
wuaucldt.exe
V5.1.8 27/05/2011
- Correction de bugs dans le mode 6
- Ajout des librairies dans la mode 6
V5.1.7 26/05/2011
- Whitelist:
mhotkey.exe
mmkeybd.exe
dit.exe
LxrAutorun.exe
sw2#.exe
Screenpresso.exe
V5.1.6 21/05/2011
- Rogue ProgFile
\\\Error Fix\\
- Whitelist
OEM0#Mon.exe
vVx#000.exe
V5.1.5 20/05/2011
- Correction d'un bug majeur du mode 6
- Whitelist
RtHDVCpl.exe
V5.1.4 16/05/2011
- Prise en charge de la sauvegarde effectu?e par Windows Recovery (Option 6)
- Whitelist:
RtHDVCpl.exe
googlecrashhandler.exe
megakeyupdater.exe
zHotkey.exe
ASScrProlog.exe
ASScrPro.exe
V5.1.3 13/05/2011
- Ajout de chemins dans les repertoires sensibles:
%SystemDrive% / Windows
%System Drive% / Documents and settings / <user>
- Policy:
HKEY_CURRENT_USER\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Policies\\Explorer -> NoDesktop
- Rogues PF:
\\Ifkpr\\
\\AntiDefend\\
- WhiteList:
vVX1000.exe
regedit.exe
V5.1.2 13/05/2011
- Correction d'un bug dans le module rundll32
- Rogue progFile
\\selfprivacy\\
\\PrivacyKey\\
V5.1.1 05/05/2011
- Correction d'un bug de fausse d?tection dans le module RUNDLL32 (RUN) -> report? dans 4.3.12
V5.1.0 02/05/2011
- Prise en charge du Task Scheduler 2.0 (Vista / Seven)
- Rogue progFile
\\PrivacyView\\
V5.0.0 30/04/2011
- Migration d'IDE
V4.3.12 30/04/2011
- Ajout ACCESS_DENIED dans rapports
- Ajout date p?remption de l'ex?cutable, avec message d'avertissement si > 3 jours
- Whitelist
RockMeltUpdate.exe
V4.3.11 25/04/2011
- Grosses optimisations (Rapidit? du scan x4)
- Whitelist
OctoshapeClient.exe
- Rogue progFile
\\PC2Safe\\
V4.3.10 24/04/2011
- Rogue progFile
\\Boan119\\
\\VaccineCore\\
\\Antivirus Clean 2011\\
- Ajout cl? : FIREFOX.EXE\\shell\\safemode\\command
- Ajout whitelist:
ereg.$ (Dragon naturally speaking)
- Correction bug module Shell
- Whitelist DNS:
62.251.229.237
- Blacklist
sys32\\windupdt\\winupdate.exe
- Whitelist:
Rsystems Support.exe
- DllWhitelist:
bthprops.cpl
-WellKnownProcess:
dwm.exe
wininit.exe
V4.3.9 16/04/2011
- DllWhitelist:
"csnp2uvc.dll"
"gcswf32.dll"
"rpchromebrowserrecordhelper.dll"
- Ajout whitelist:
OrangeInside.exe
- Rogue progFile
\\Error Repair Professional\\
- Correction bug module WhitelistDLL
- Ajout de la date de la version
- Ajout d'un mode (0) pour quitter. Le programme se relance automatiquement ? la fin.
Il convient donc de choisir le mode 0 pour fermer le programme
V4.3.8 09/04/2011
- Ajout d'un module de reconnaissance de processes connus (explorer.exe, etc..)
- Optimisations
- Ajout d'un module de reconnaissance des dlls charg?es en 04 sous rundll32
- Rogue progFile
\\HomeClean\\
\\BoanSupport\\
- DllWhitelist:
"oobefldr.dll" "nvsvc.dll" "NvCpl.dll"
"NvMcTray.dll" "nview.dll" "srclient.dll"
"dr25svc.dll" "cmicnfg.dll" "ksrun.dll"
"sbavmon.dll" "dlbttime.dll" "ftutil2.dll"
"nvclock.dll" "nvhotkey.dll" "nvmctray.dll"
"p17.dll" "spirun.dll" "p17rune.dll"
"ptipbmf.dll" "ulutil2.dll" "sispower.dll"
"wf2kcpl.dll" "zsscheduler.dll" "apphelp.dll"
"advpack.dll" "sti_ci.dll" "ASTSVCC.dll"
"LXBUtime.dll" "p0**0pin.dll"
- Purge rogues ProgFile
- Correction bugs (Language anglais, kill svchost.exe)
- Ajout module de restauration des param?tres du centre de s?curit?
- Ajout whitelist:
clavier.exe
V4.3.7 04/04/2011
- Ajout d'un module de reconnaissance MD5 pour les process, les dll et les cl?s RUN
- MD5 Blacklist:
2eb8bf9d3fad4cb9e26a1ae184a65816 //AntivirusPlus "random.dll"
V4.3.6 29/03/2011
- AJout module Association de fichiers StartMenuInternet (Firefox, IE, Opera)
- Rogue Program files
\\ADSTOP\\
\\SystemDefender\\
- DNS Whitelist
90.0.0.38
V4.3.5 29/03/2011
- Ajout du disque local syst?me dans l'option 6
- Ajout du repertoire CurrentUser dans l'option 6
- Am?lioration de l'algorithme, gain de rapidit? (option 6)
- Ajout des modules de surveillance UAC: "ConsentPromptBehaviorAdmin" , "ConsentPromptBehaviorUser" , "EnableLUA"
- Ajout de module de r?paration du fond d'?cran.
\\vaccinescan\\
- Whitelist DNS
199.243.213.* (Canada)
V4.3.4 26/03/2011
- Ajout des removable devices dans l'option 6, sauf lecteur disquette.
- Ajout des repertoires Ma musique, Mes videos, Mes images
- Correction bug sur la r?cup?ration des chemins Mes videos.
V4.3.3 24/03/2011
- Ajout module de v?rification de l'activation de la restauration syst?me
- Modification du syst?me WL/BL => Ajout de plusieurs chemins possible
- Ajout des disques locaux (Sauf syst?me) pour le mode 6.
- DNS Whitelist
86.64.145.145 (NEUF)
84.103.237.145 (NEUF)
- Whitelist
Dropbox.exe
LBubble Dock.exe
V4.3.2 16/03/2011
- Ajout d'un module pour neutraliser les liens dans les rapports (fichiers Hosts principalement)
- Correction d'un bug g?n?rant des FPs dans le module de services
- Rogue PF
\\ProPrivacy\\
\\antiguard\\
- Whitelist
rockmeltcrashhandler.exe
rockmelt.exe
- WhitelistDNS
195.235.96.90 (DNS Espagnol)
195.235.113.3 (DNS Espagnol)
V4.3.1 14/03/2011
- Ajout d'un module pour la restauration des fichiers pass?s en "cach?" par le rogue Windows diagnostic (option 6)
- Ajout whitelist:
IMVUQualityAgent.exe
- Suppression du checkPath pour les services (trop de FPs)
V4.3.0 10/03/2011
- Refonte des Whitelist/Blacklist, ajout de chemins (permet de dire qu'un fichier est blacklist? sauf dans un certain repertoire, etc...)
- Correction d'un bug causant des probl?mes d'affichage dans le module de langue englais
V4.2.1 09/03/2011
- Correction d'un bug faisant planter le module de langue
- Prise en charge Quarantaine pour les modules RUN/Services/Tasks/Startup Folder/Residus
- Ajout Whitelist:
isuspm.exe (Install Shield Update manager)
V4.2.0 07/03/2011
- Modification du syst?me de rapports:
Les rapports ne s'ajoutent plus au fichier RKreport.txt, mais ? des fichiers distincts ? chaque lancement, nomm? suivant la norme: RKreport[NUMERO].txt
Le r?capitulatif de tous les fichiers disponibles s'affiche ? la fin du rapport.
- Whitelist DNS: 81.253.149.$
V4.1.1 07/03/2011
- Correction d'un bug dans la detection des chemins de fichiers, entra?nant la non d?tection de certaines cl?s de registre avec espaces.
- Ajout rogue program files:
\\ZeroVaccine\\
V4.1.0 04/03/2011
- Ajout d'une traduction Fran?ais/Anglais selon la langue du PC
V4.0.1 28/02/2011
- Correction de bugs (refonte du systeme de parsing des cl?s de registre)
- Ajout de surveillance des cl?s RunOnce, RunServices, RunOnceEx, RunServiceOnce pour toutes les sessions.
Des rogues comme System tool peuvent maintenant ?tre supprim?s depuis une session saine.
- Rogue Program files:
\\pcvaccine\\
V4.0.0 23/02/2011
- Refonte du moteur avec passage du C au C++
- Modification de l'affichage des rapports, plus d'infos.
- Ajout blacklist
sdra64.exe
- Rogue program files
\\specialguard\\
V3.10.3 21/02/2011
- Ajout des modules de surveillance Associations de fichiers:
HKEY_LOCAL_MACHINE\Software\\Classes\\pezfile\\shell\\open\\command
HKEY_LOCAL_MACHINE\Software\\Classes\\.exe\\shell\\open\\command
HKEY_LOCAL_MACHINE\Software\\Classes\\exefile\\shell\\open\\command
HKEY_CURRENT_USER\Software\\Classes\\exefile\\shell\\open\\command
- Ajout blacklist
eksplorasi.exe
V3.10.2 17/02/2011
- Ajout d'une mise en quarantaine pour les process tu?s (pas encore pour les DLL et les r?sidus)
La quarantaine se trouve ? la racine de l'ex?cutable (RK_Quarantine) et comprends:
* Les fichiers au format -> Nom_de_lexe.exe.vir
* un fichier texte (QuarantineReport.txt) comprenant le r?capitulatif par date des suppression, ainsi que les chemins d'origine.
Demander ce rapport en cas de faux positif pour restaurer (? la main) les fichiers d?plac?s par erreur.
- Ajout module HKEY_USERS (cl? Winlogon/Windows) pour surveiller les cl?s Shell et Load des autres sessions du PC
- Ajout surveillance proxy sur HKLM
- Ajout Association fichiers EXE: HKEY_CLASSES_ROOT\\exefile\\shell\\open\\command
- Rogue Program Files
\\McAVG\\
\\AVGT\\
V3.10.1 16/02/2011
- Ajout module HKEY_USERS (cl? RUN) pour surveiller les cl?s RUN d'autres sessions.
- Correction bug CheckPath
- Ajout surveillance du chemin des fichiers Services
- Ajout surveillance cl? ProxyEnable (Module Proxy)
\\PrivacyHidden\\
\\SafeCare\\
V3.10.0 11/02/2011
- Ajout module de d?tection rootkits (sommaire)
=> BruteForce PIDs + v?rification Blacklist / WhiteList
- Ajout ouverture UAC au lancement (pour mode admin)
- R?organisation DNS Blackist => Comparaison par masque
- Rogues program files
"\\eoRezo\\"
"\\homevaccine\\"
"\\smartscan\\"
V3.9.0 01/02/2011
- Migration des modules Proxy et DNS dans des options distinctes. (options 4 et 5)
- Ajout BlackList:
printer.exe (EasySpywareCleaner)
ctfmona.exe (EasySpywareCleaner)
xpupdate.exe (EasySpywareCleaner)
- Rogue Program Files:
\\EasySpywareCleaner\\
- Correction Bug sur module Shell, qui emp?chait la detection des cl?s "Load"
V3.8.5 31/01/2011
- Ajout module de reconnaissance du mode de d?marrage (Normal, Mode sans ?chec avec / sans prise en charge r?seau)
- Ajout reconnaissance du nom de la session courante
- Ajout DNS WhiteList: "74.118.212.1","74.118.212.2", "192.168.10.1", "15.243.128.51","15.243.160.51", "193.95.75.10","193.95.75.13"
\\MyPCCheck\\
- Ajout WhiteList:
autologin.exe
V3.8.4 29/01/2011
- Ajout module de reconnaissance des DNS malicieux
- Ajout WhiteList DNS: http://www.commentcamarche.net/faq/1496 ... cipaux-fai
- 74.118.212.1,74.118.212.2,192.168.10.1,156.154.70.22,156.154.71.22
- Ajout Whtelist
little transparency.exe
SmpSys.exe
- Changement Icone
V3.8.3 27/01/2011
- Ajout module de d?tection de lancement automatique de raccourcis dans le dossier Startup
(C:\Documents and Settings\<USER>\Menu D?marrer\Programmes\D?marrage)
- Ajout rogues program files:
\\liveboan\\
\\security119\\
\\PrivacyInfo\\
\\MegaVaccine\\
\\WebVaccine\\
\\Smart Security\\
V3.8.2 27/01/2011
\\PC Security 2011\\
\\Best Spyware Scanner\\
\\AVP2009\\
\\RegGenie\\
- Ajout WhiteList
e_s$$**$.exe (Epson Driver)
V3.8.1 20/01/2011
- Modification de code
V3.8.0 19/01/2011
-Ajout module de d?tection des rogues dans program files
-Modif module DLL pour d?tection chemin sensibles/program files
-Ajout blacklist:
avsubengine.exe (VaccineClean)
uninst_$ (Rogue.multiple)
-Ajout rogues program files:
\\VaccineClean\\
\\easyvaccine\\
\\PCoptimizer 2010\\
\\PrivacyRight\\
\\wisevaccine\\
\\privacyguard 2010\\
\\v2accine2010\\
\\NewVC\\
\\ddosclean\\
\\vaccineprogram\\
\\SpyCare\\
\\pcclearplus\\
\\CleanV\\
\\uservaccine\\
\\powercare\\
\\protect_one\\
\\QScan\\
\\ScanZero\\
\\searchguard\\
\\safetyboan\\
\\BestBoan\\
\\DataProtect\\
\\adsafer\\
\\AntiProtect\\
\\cleanscan\\
\\New2Clean\\
\\IDBoan\\
\\Scan119\\
\\Vkiller\\
\\infosecret\\
\\VaccineLab\\
\\RegistryClever\\
\\VaccineData\\
\\infohold\\
\\Internetvaccine\\
\\keycop\\
\\k-security\\
\\eClean3.0\\
\\RealVaccine\\
V3.7.4 13/01/2011
- Modification module HOSTS -> affichage des 20 premi?res lignes seulement
(simplifie la lecture du rapport)
- Modification du module de detection du type d'user
- Ajout whitelist:
Smax4.exe
V3.7.3 09/01/2011
- Modification du module HOSTS (Ajout d'un fixACL et d'un fixAttributes, qui permettent la modif du fichier)
- Correction d'un bug g?n?rant des faux positifs dans le module HijackInitDLL
V3.7.2 08/01/2011
- Ajout module de surveillance des AppInitDLL (chargement de dll au d?marrage de windows dans explorer)
- Renseignement du mode de lancement de l'appli (Admin - NOT Admin)
- Ajout blacklist
SM***.exe
SM****.exe
SM****_$.exe
V3.7.1 07/01/2011
- Correction d'un bug cr?ant des faux positifs dans le module de masque
- Modification du module "inkillable" => meilleurs r?sultats, surtout sous Vista/seven
- Ajout blacklist:
sw2#.exe
Fullremove.exe
-Service Blacklist
sst#
V3.7.0 05/01/2011
- Ajout module de detection Hijack WBEM (famille Antivirus 2010)
V3.6.1 28/12/2010
- Ajout blacklist:
*****_##$.exe (Internet Security suite)
V3.6.0 28/12/2010
- Ajout d'un module de surveillance du fichier HOSTS
- Ajout d'un mode permettant de restaurer un HOSTS sain
V3.5.2 27/12/2010
HKEY_CURRENT_USER\\Software\\Microsoft\\Windows NT\\CurrentVersion\\Windows -> Load
- Ajout Blacklist:
!^!^!#####.exe (System tool)
V3.5.1 18/12/2010
- Correction d'un bug emp?chant la suppression de cl?s de registre poss?dant +2 niveaux de sous-cl?s
V3.5.0 13/12/2010
- Modification du module de modif des ACLs, prise en charge de Vista / Seven
(Merci ? Egwene et Eric_71)
V3.4.0 11/12/2010
- Ajout d'un module pour rendre le process inkillable! :)
(du moins hormis l'utilisateur, et les applis ayant SE_DEBUG)
V3.3.0 11/12/2010
- Ajout d'un module de suppression des LEGACY
(Ne marche que sous XP pour le moment)
- Ajout d'un module de modification des ACL, avec resatauration apr?s le scan/modif des cl?s (merci ? Egwene)
- Correction d'un bug de d?tection des chemins sensibles (Appli~1 = Appdata)
V3.2.1 01/12/2010
- Correction d'un bug qui faisait planter le module running services
- service blacklist:
vbma**** (Antivirus Action)
V3.2.0 20/11/2010
- Modification et activation du module des taches planifi?es.
Bas? sur la blacklist, et les r?sidus en m?moire.
V3.1.0 20/11/2010
- Ajout de module de scan 04
RunServices
RunOnceEx
- Blacklist
windowstmsystem.exe
microsoftspeech.exe
mbamzlib.exe
sshnas$
Zludo*.exe
Zjuje*.exe
- Service
SSHNAS
V3.0.1 14/11/2010
- Ajout de service Blacklist
Follower
- Ajout de cl?s Blacklist
netc.exe
nnmmnnsys.exe
V3.0.0 14/11/2010
- Hijack Policies
NoFolderOptions
- Correction d'un bug qui faisait planter le module de recherche RUN
V2.9.0 14/11/2010
- Ajout d'un module de Shell Spawning (Hijack du lancement des .Exe)
pezfile
.exe
V2.8.0 13/11/2010
- Ajout de module de d?tection des Hijack Policies
DisableTaskMgr
DisableRegistryTools
DisableCMD
V2.7.1 12/11/2010
- Correction d'un bug faisant planter le module IFEO
(d?bordement de tableau)
V2.7.0 11/11/2010
- Ajout module proxy Firefox
V2.6.0 05/11/2010
- Ajout module de reconnaissance des dll charg?es sous rundll32
- Ajout module de kill des dll trouv?es dans les r?sidus
- Services Blacklist:
kxtoykoc (smart defragmenter)
jvfrhmo (think point)
V2.5.0 05/11/2010
- Ajout module Image File Execution Options
- Ajout module taches planifi?es (? completer)
V2.4.0 05/11/2010
- Ajout description dans les propri?t?s.
V2.4.0 30/10/2010
- Ajout d'un module de scan des r?sidue
(process dont la cl? de registre ? ?t? supprim?e, mais qui n'ont pas ?t? tu?s,
car seul la valeur de la cl? de registre permet de les identifier)
- Ajout Date/Heure dans le rapport
- Correction d'un faux positif sur les noms de fichier contenant "temp"
V2.3.1 30/10/2010
- Ajout recherche Blacklist pour les valeurs de registre
- BlackList:
MK**.exe (Antimalware Doctor)
MK***.exe (Antimalware Doctor)
uPc+MV$.exe (Antimalware Doctor)
- WhiteList:
Chrome.exe (se lance dans Appdata)
- Ouverture automatique du rapport ? la fin
- Message invitant ? passer le mode 2 si des infections
ont ?t? trouv?es dans le registre
V2.3.0 22/10/2010
- refonte du module de scan svchost (?l?vation des privil?ges)
-> plus besoin des taskkill et tasklist
- Ajout d'un module de scan des services en cours d'ex?cution (autres
que svchost)
V2.2.0 21/10/2010
- Ajout currentcontrolset003
- remaniement du code
V2.1.0 20/10/2010
- Ajout d'un module de comparaison g?rant les masques
- Ajout de rogue
SM***_****.exe (Smart Engine)
V2.0.0 20/10/2010
- Ajout d'un module de scan des services svchost
-> on tue le service si celui ci est suspect
Ce module ne fonctionne pas nativement sous XP home.
il faut t?l?charger 2 ex?cutables et les placer ? la racine de RogueKiller
V1.8.0 19/10/2010
- Ajout d'un module de scan des services (CurrentControlSet, ControlSet001, 002)
- Ajout de services ? la liste noire:
userinit (Antivirus 2010)
V1.7.1 19/10/2010
- Ajout de quelques process en WhiteList
flux.exe
RtkBtMnt.exe
GoogleUpdate.exe
V1.7.0 18/10/2010
- Ajout d'un module de suppression des proxy
V1.6.0 18/10/2010
- refonte de la recherche de processus.
-> Purge des Blacklist / WhiteList
-> Scan bas? sur l'emplacement du process en priorit? pour une plus grande rapidit?
- Ajout? le repertoire "Bureau/Desktop" comme dossier sensible
- Ajout? chemin des fichiers tu?s (Sauf security Tools) dans le rapport
V1.5.0 18/10/2010
- Ajout d'un scan de la cl? Shell
rogue Thinkpoint pris en charge
BlackList
Hotfix.exe
Desktop Security 2010.exe
WhiteList:
GoogleUpdate.exe
chrome.exe
GoogleCrashHandler.exe
flux.exe
Ati2evxx.exe
spoolsv.exe
V1.4.0 14/10/2010
- Ajout d'un choix de mode pour le registre
mode scan: ne supprime pas les cl?s de registre trouv?es
mode remove: supprime les cl?s de registre trouv?es
Cela permet de voir d'?ventuels faux positifs et rassurer les personnes
qui ne veulent pas toucher au registre, et seulement tuer le processus infectieux
V1.3.0 14/10/2010
- Ramaniement du code, optimisations.
Arrangement modulaire
V1.2.0 12/10/2010
- Am?lioration du module de d?tection des cl?s RUN/RUNONCE infectieuse
d?tection des fichiers / chemin de mani?re plus pr?cise
moins de faux positifs, ciblage plus facile.
- Passage en "Append" du fichier RKreport.txt (au lieu de w+)
ce qui permet de ne pas ?craser les rapports pr?c?dents en cas de multiples
ex?cutions ? la suite
(le rapport est donc une superposition ant?-chronologique des diff?rents rapports)
V1.1.2 10/10/2010
- Ajout d?tection OS et affichage dans le rapport
flash_player_installer.exe
Whitelist:
rundll32.exe
V1.1.1 08/10/2010
avp32.exe (Peak Protection)
user.exe (Peak Protection)
system.exe (Peak Protection)
svc.exe
load.exe (Antivirus studio 2010)
securitycenter.exe (Antivirus studio 2010)
securityhelper.exe (Antivirus studio 2010)
AntiVirus Studio 2010.exe (Antivirus studio 2010)
V1.1.0 04/10/2010
- Ajout d'un module de suppression des cl?s RUN/RUNONCE en fonction
de la liste noire/liste blanche et des filtres dossiers habituels
- Optimisations
- Ajout d'un icone programme
- Ajout de quelques process Koobface:
ld15.exe
ld16.exe
andy133.exe
V1.0.3 01/10/2010
- Ajout d'un module tuant les applications tournant sous "\Application Data\"
ou un de ses sous-dossiers
- Ajout d'un module tuant les applications tournant sous "\Temp\"
V1.0.2 01/10/2010
- Passage en priorit? Haute au d?marrage du processus
(plus grande part CPU pour le scan, donc moins de chances de se faire killer)
V1.0.1 01/10/2010
- Ajout d'une whitelist minimaliste pour acc?l?rer la recherche
[System Process]
System
smss.exe
csrss.exe
wininit.exe
winlogon.exe
services.exe
lsass.exe
lsm.exe
svchost.exe
dwm.exe
explorer.exe
ctfmon.exe
dllhost.exe
alg.exe
conhost.exe
taskhost.exe
sched.exe
Locator.exe
jusched.exe
V1.0 30/09/2010
- Rogue Security Tools
module de d?tection des noms compos?s uniquement de chiffres
- Ajout de rogues plus anciens:
ccagent.exe (Control center)
ccmain.exe
richtx64.exe (Data Protection)
asr64_ldm.exe (Dr Guard)
diskperfxp.exe (User Protection)
davclnt.exe (Digital Protection)
avp.exe
digprot.exe
datprot.exe (Data Protection)
ave.exe
- Changelog SmitfraudFix jusqu'? November 06, 2008
winupdate.exe
AVR09.exe
msa.exe
ld09.exe
mediacodec.exe
pp10.exe
SYSDLL.exe
SYS32DLL.exe
DL32.exe
pcdefender.exe
svchost_32.exe
asasa.exe
syst.exe
msctrl.exe
msavsc.exe
msscan.exe
msiemon.exe
msfw.exe
msctrl.exe
msavsc.exe
msscan.exe
msiemon.exe
msfw.exe
setup2.exe
AntivirusXP.exe
ld03.exe
pp06.exe
userload.exe
rs32net.exe
renus2008.exe
sysrc32.exe
svchostw.exe
ld01.exe
ld02.exe
pp2.exe
dll32.exe
winagent.exe
systeminit.exe
sysguard.exe
avrlabs.exe
AnvTrgr.exe
msiconf.exe
VirTrigger.exe
VirusTriggerBin.exe
svhost.exe
reged.exe
spoolsystem.exe
syscert.exe
sysexplorer.exe
wsc32x.exe
- Fixed bugs
V8.6.0 14/06/2013
- Added signatures
V8.5.4 18/03/2013
V8.5.3 13/03/2013
V8.5.2 23/02/2013
V8.5.1 12/02/2013
V8.5.0 08/02/2013
V8.4.4 01/02/2013
- Langue Italien
- Langue Polonais
- Langue Cor?en
V8.4.3 08/01/2013
- Langue Russe
V8.4.2 31/12/2012
V8.4.1 23/12/2012
- Langue Spanish
- Dell MBR
V8.4.0 11/12/2012
V8.3.2 07/12/2012
V8.3.1 20/11/2012
V8.3.0 17/11/2012
- Bouton facebook
V8.2.3 07/11/2012
- WL dll
HPStatusBL.dll
- WL
Screenpresso.exe
V8.2.2 03/11/2012
- Window BL
- BL
MESP.exe
- driver WL
- WL
Windir/VPro500.exe
windir/*np325.exe
- BL particular
V8.2.1 29/10/2012
- DNS WL
24.222.0.95
- Driver WL
- Whitelist
cdloader2.exe
magicJack.exe
V0220Mon.exe
msnotif.exe
LGMLauncher.exe
Communicator.exe
V8.2.0 22/10/2012
- Truesight v0.7
- Fix langue German
- Whitelist
sys32/pcalua.exe
LogMeInSystray.exe
Dashlane.exe
- DNS Whitelist
86.64.145.14*
129.250.35.251
- Driver WL
- Window BL
V8.1.1 01/10/2012
- Window BL
XP Defender 2013
Vista Defender 2013
Win 7 Defender 2013
V8.1.0 28/09/2012
V8.0.5 23/09/2012
V8.0.4 19/09/2012
- Dll whitelist
adawarebp.dll
SkyDriveShell.dll
V8.0.3 13/09/2012
- Whitelist DLL
tv_w32.dll
- Whitelist
TeamViewer.exe
tv_w32.exe
ibsvc.exe
V8.0.2 31/08/2012
- Incproc HJ
- Blacklist
V8.0.1 30/08/2012
- Whitelist
c2c_service.exe
SkyDrive.exe
procexp.exe
- Driver WL
- Truesight v0.6
install_0_msi.exe
hleo32.exe
regsrv64.exe
msconfig.dat
hos32.exe
V8.0.0 26/08/2012
- Whitelist
StatBar.exe
%sys32%\iac25_32.ax
V7.6.6 10/08/2012
V7.6.5 03/08/2012
- Ajout signature
- Windows BL
V7.6.4 17/07/2012
- BlacklistValue
fest0r_ot.exe
Schnarch.exe
- Whitelist DLL
cleanup.dll (MBAM)
- Windows BL
File Recovery
V7.6.3 08/07/2012
roper0dun.exe
rasmxs.exe
SCardDlg.exe
TapiSysprep.exe
0_0u_l.exe
glom0_og.exe
V7.6.2 02/07/2012
- Blacklist
sys32 / n
V7.6.1 28/06/2012
- Ajout signature
er_00_0_l.exe
V7.6.0 26/06/2012
- Drivers WL
V7.5.4 07/06/2012
pkg0u.exe
pkg_0ll.exe
WinzipArchiver.exe
TarArchiver.exe
Smoerrebroe.exe
tpl_0_c.exe
RarArchiverWin.exe
V7.5.3 05/06/2012
krussel3.exe
AMD_cpx.exe
Apple_Store.exe
cs8v0k.exe
V7.5.2 30/05/2012
- Whitelist
SpotifyWebHelper
ArchiverforWin.exe
game_client.exe
WinArchiver.exe
V7.5.1 28/05/2012
k8h0pp.exe
temp##.exe
ServiceVBOX.exe
V7.5.0 24/05/2012
k8h00.exe
VboxServs.exe
V7.4.5 18/05/2012
ch8l0.exe
p0j99p.exe
spoolsrv.exe
FSnapshot_x86.exe
BSI.bund.exe
GboxService.exe
InfoServices_a.exe
ksprskylabs1.exe
V7.4.4 08/05/2012
ms.exe
#{1}.#{12+}.exe
wpbt#{1}.dl{2}
hnszs#{1}.exe
ms*****.bat
ram_reserver64.exe
syncservicex86.exe
EPUhelpers.exe
DNS_Servicex86.exe
kitre#{1}.exe
V7.4.3 04/05/2012
V7.4.2 03/05/2012
V7.4.1 02/05/2012
- Whitelist
E_FATIHJL.EXE
V7.4.0 01/05/2012
- Window BL
Allemand
V7.3.4 27/04/2012
V7.3.3 22/04/2012
Grec
Portugais
V7.3.2 20/03/2012
SMART HDD
System Shield
Security Shield
V7.3.1 10/03/2012
- Whitelist
Skype.exe
FixCamera.exe
firefox.exe
- Driver WL
V7.3.0 08/03/2012
- TrueSight v0.4
V7.2.1 29/02/2012
- TrueSight v0.3
- Driver WL
- Window BL
Smart Fortress 2012
Windows Shield Tool
Windows PRO Scanner
V7.2.0 27/02/2012
- Whitelist
Spotify.exe
- Window BL
V7.1.0 15/02/2012
Czech
Slovak
- Blacklist window
Security Scanner
Internet Security
- Rogue ProgFile
\\PCSpeed Service\\
\\everyclear\\
- Blacklist
gema.exe
V7.0.4 08/02/2012
V7.0.3 06/02/2012
- Blacklist
V7.0.2 30/01/2012
- Whitelist
adawarebp.exe
DropBox.exe
- Rogue ProgFiles
\\BoanCatch\\
\\pcupgrade\\
\\best-pc\\
\\InfoSeven\\
\\comdoumi\\
- Window BL
V7.0.1 28/01/2012
V7.0.0 26/01/2012
V6.2.4 12/01/2012
V6.2.3 09/01/2012
- Whitelist
smad.exe
- Whitelist Dll
BatInfEx.dll
BatLogEx.dll
- Driver Whitelist
- Window Blacklist
System Check
- Rogue ProgFiles
\\InfoSafe\\
\\CleanerCom\\
\\MicroVaccine\\
\\PC-Spider\\
\\CYAK\\
\\PcVirusDoctor\\
\\CheckSpeed\\
V6.2.2 31/12/2011
V6.2.1 28/12/2011
- Whitelist DLL
%sys32%/LogiLDA.dll
nsMouselib.dll
msconf.dll
- Whitelist
B2CNotiAgent.exe
HpSAUpgrade.exe
HPSFUpdater.exe
MpSigStub.exe
dplaysvr.exe
- rogue ProgFiles
\\info-manager\\
- Window BL
Security Monitor
V6.2.0 12/12/2011
- Rogue ProgFiles
\\datasave\\
\\sweeperlab\\
\\virussecurity\\
\\ProtectCop\\
\\HomeBoan\\
\\SmartSafer\\
- Whitelist
pccntupd.exe
pull.exe
RapportService.exe
HWDeviceService.exe
windir\v0330mon.exe
- Driver Whitelist
- WhitelistDLL
rooksbas.dll
- Blacklist
%sys32/sysrunc.exe
V6.1.12 02/12/2011
- Window Blacklist
XP Antispyware 2012
XP Antivirus 2012
XP Security 2012
XP Antispyware 2012
Vista Security 2012
Win 7 Security 2012
V6.1.11 30/11/2011
- Window Blacklist
BlueFlare Antivirus
Wolfram Antivirus
OpenCloud Security
Malware Protection
Spyware Protection
Cloud Protection
Guard Online
AV Guard Online
Cloud AV 2012
- Rogue ProgFiles
\\NDoctorCom\\
\\perfectcare\\
\\privacyup\\
\\PowerPC\\
\\CleanCatch\\
- blacklist
V6.1.10 18/11/2011
- Rogue ProgFiles
sweeperlab
VirusSecurity
- Blacklist
- Window Blacklist
AV Protection 2011
V6.1.9 16/11/2011
- Window Blacklist
System Fix
Privacy Protection
AV Security 2012
System Restore
- Driver WL
guard.sys /*AVG 7*/
- Whitelist
%windows%\*snpstd$
%windows\lclock.exe
MessageCheck.exe
%windows\UpdReg.EXE
uUACTokenSvc.exe
GameXNGO.exe
- Whitelist DLL
LC.dll
- Whitelist DNS
4.2.2.$
V6.1.8 14/11/2011
- Whitelist
netsession_win.exe
SetWallpaper.cmd
FacebookUpdate.exe
lsnfier.exe
mediaget.exe
%windows%\mixer.exe
- Driver WL
- Dll WL
mcdvd_32.dll
- Blacklist
V6.1.7 05/11/2011
- Rogue ProgFile
\\PatchUp_Plus\\
\\NVirusKorea\\
\\ProtectCode\\
\\CoreScan\\
\\AntiAvoid\\
\\IPRIVACY\\
\\ProtectKeep\\
\\AnyCop\\
\\windowpc\\
- Whitelist
arservice.exe
- Whitelist DLL
IadHide5.dll
V6.1.6 01/11/2011
- DNS whitelist:
8.8.4.$
- Whitelist :
windows\qmc.exe
rnupgagent.exe
googletalk.exe
E_FATICDL.EXE
- Drivers WL:
- Whitelist DLL
migrate.dll
OIExt.dll
V6.1.5 29/10/2011
- Drivers WL:
- Rogue ProgFiles
\\boankorea\\
\\FastScan\\
V6.1.4 22/10/2011
- Rogue ProgFiles
\\VirusScan\\
\\pcspeedup\\
- Drivers WL:
- Whitelist
AVGIDSMonitor.exe
V6.1.3 14/10/2011
- TrueSight v0.2
- Blacklist
sys32\lvvm.exe
- Rogue ProgFiles
\\realcleaner\\
V6.1.2 07/10/2011
- Drivers WL:
audiodg.exe
- Rogue ProgFiles
\\vaccinecom\\
\\PCPlusSecurity\\
- WellKnown WL
sys32\ctfmon.exe
sys32\lsm.exe
sys32\sppsvc.exe
sys32\mctadmin.exe
sys32\dllhost.exe
sys32\alg.exe
sys32\wscntfy.exe
sys32\notepad.exe
sys32\wuauclt.exe
sys32\userinit.exe
sys32\msdtc.exe
- Whitelist dll
nvsysrot.dll
V6.1.1 28/09/2011
- TrueSight v0.1
- Drivers WL:
unknown /*Unknown*/
aswSP.sys /*Avast*/
- Rogues progFiles
\\HelpPrivacy\\
\\InfoBoan\\
\\DrBoan\\
\\Privacyi\\
\\Micropop\\
- Service Blacklist
MPopService
V6.1.0 22/09/2011
V6.0.0 21/09/2011
V5.3.5 21/09/2011
- WhitelistDLL
LVPrcInj01.dll
- Whitelist
kmservice.exe
- Rogues ProgFiles
\\BoanCop\\
\\cleancert\\
\\VIHunter\\
V5.3.4 30/08/2011
- Rogues ProgFiles
\\PrivacyBoho\\
\\SafePrivacy\\
\\BoanClear\\
- Whitelist
BR040286.exe
V5.3.3 18/08/2011
- Dll Whitelist
rpchrome$
MSVC^71.dll
- Rogue ProgFile
\\errordoctor\\
- GUID
V5.3.2 18/08/2011
- WellKnownProcess:
- Whitelist:
nclaunch.exe
V5.3.1 06/08/2011
- Rogue ProgFile:
\\PrivacyCode\\
\\InfoGuard\\
\\DefenseVirus\\
\\PatchUp_Plus\\
- Whitelist dll:
btmshell.dll
mkil.dll
V5.3.0 01/08/2011
wxpdrivers
srvsysdriver32
srvbtcclient
srviecheck
- Rogue progFiles
\\MacroVirus\\
\\DualVaccine\\
\\CodeScan\\
V5.2.9 31/07/2011
Windows_Update
- Dll Whitelist
MSVCP71.dll
- Whitelist
alcwzrd.exe
PLFset^.exe
V5.2.8 23/07/2011
- Dll Whitelist
Dropbox$
PLFSet.dll
-Whitelist
vsnp2uvc.exe
- Rogue progFiles
\\Clear2PC\\
\\PCMedic\\
\\boanking\\
- ajout BlackList
V5.2.7 30/06/2011
V5.2.6 23/06/2011
V5.2.5 23/06/2011
V5.2.4 22/06/2011
Rogue ProgFiles:
-\\privacyalpha\\
-\\basicprivacy\\
-\\MicroPC\\
-Whitelist
Bginfo.exe
PLFsetL.exe
V5.2.3 16/06/2011
- Blacklist
- Service blacklist
QTUpdate
- Rogue ProgFiles
V5.2.2 05/06/2011
V5.2.1 02/06/2011
V5.2.0 01/06/2011
- Blacklist service
cdfss
wcscd
V5.1.9 29/05/2011
- Rogue ProgFile:
\\vaccineu\\
- Whitelist
soundman.exe
- Blacklist
wuaucldt.exe
V5.1.8 27/05/2011
V5.1.7 26/05/2011
- Whitelist:
mhotkey.exe
mmkeybd.exe
dit.exe
LxrAutorun.exe
sw2#.exe
Screenpresso.exe
V5.1.6 21/05/2011
- Rogue ProgFile
\\\Error Fix\\
- Whitelist
OEM0#Mon.exe
vVx#000.exe
V5.1.5 20/05/2011
- Whitelist
RtHDVCpl.exe
V5.1.4 16/05/2011
- Whitelist:
RtHDVCpl.exe
megakeyupdater.exe
zHotkey.exe
ASScrProlog.exe
ASScrPro.exe
V5.1.3 13/05/2011
- Policy:
- Rogues PF:
\\Ifkpr\\
\\AntiDefend\\
- WhiteList:
vVX1000.exe
regedit.exe
V5.1.2 13/05/2011
- Rogue progFile
\\selfprivacy\\
\\PrivacyKey\\
V5.1.1 05/05/2011
V5.1.0 02/05/2011
- Rogue progFile
\\PrivacyView\\
V5.0.0 30/04/2011
- Migration d'IDE
V4.3.12 30/04/2011
- Whitelist
RockMeltUpdate.exe
V4.3.11 25/04/2011
- Whitelist
OctoshapeClient.exe
- Rogue progFile
\\PC2Safe\\
V4.3.10 24/04/2011
- Rogue progFile
\\Boan119\\
\\VaccineCore\\
- Ajout whitelist:
- Whitelist DNS:
62.251.229.237
- Blacklist
- Whitelist:
- DllWhitelist:
bthprops.cpl
-WellKnownProcess:
dwm.exe
wininit.exe
V4.3.9 16/04/2011
- DllWhitelist:
"csnp2uvc.dll"
"gcswf32.dll"
- Ajout whitelist:
OrangeInside.exe
- Rogue progFile
V4.3.8 09/04/2011
- Optimisations
- Rogue progFile
\\HomeClean\\
\\BoanSupport\\
- DllWhitelist:
- Ajout whitelist:
clavier.exe
V4.3.7 04/04/2011
- MD5 Blacklist:
V4.3.6 29/03/2011
\\ADSTOP\\
\\SystemDefender\\
- DNS Whitelist
90.0.0.38
V4.3.5 29/03/2011
\\vaccinescan\\
- Whitelist DNS
V4.3.4 26/03/2011
V4.3.3 24/03/2011
- DNS Whitelist
- Whitelist
Dropbox.exe
LBubble Dock.exe
V4.3.2 16/03/2011
- Rogue PF
\\ProPrivacy\\
\\antiguard\\
- Whitelist
rockmelt.exe
- WhitelistDNS
V4.3.1 14/03/2011
- Ajout whitelist:
V4.3.0 10/03/2011
V4.2.1 09/03/2011
- Ajout Whitelist:
V4.2.0 07/03/2011
V4.1.1 07/03/2011
\\ZeroVaccine\\
V4.1.0 04/03/2011
V4.0.1 28/02/2011
\\pcvaccine\\
V4.0.0 23/02/2011
- Ajout blacklist
sdra64.exe
\\specialguard\\
V3.10.3 21/02/2011
- Ajout blacklist
eksplorasi.exe
V3.10.2 17/02/2011
\\McAVG\\
\\AVGT\\
V3.10.1 16/02/2011
\\PrivacyHidden\\
\\SafeCare\\
V3.10.0 11/02/2011
"\\eoRezo\\"
"\\homevaccine\\"
"\\smartscan\\"
V3.9.0 01/02/2011
- Ajout BlackList:
V3.8.5 31/01/2011
\\MyPCCheck\\
- Ajout WhiteList:
autologin.exe
V3.8.4 29/01/2011
- Ajout Whtelist
SmpSys.exe
- Changement Icone
V3.8.3 27/01/2011
\\liveboan\\
\\security119\\
\\PrivacyInfo\\
\\MegaVaccine\\
\\WebVaccine\\
\\Smart Security\\
V3.8.2 27/01/2011
\\AVP2009\\
\\RegGenie\\
- Ajout WhiteList
V3.8.1 20/01/2011
V3.8.0 19/01/2011
-Ajout blacklist:
\\VaccineClean\\
\\easyvaccine\\
\\PrivacyRight\\
\\wisevaccine\\
\\v2accine2010\\
\\NewVC\\
\\ddosclean\\
\\vaccineprogram\\
\\SpyCare\\
\\pcclearplus\\
\\CleanV\\
\\uservaccine\\
\\powercare\\
\\protect_one\\
\\QScan\\
\\ScanZero\\
\\searchguard\\
\\safetyboan\\
\\BestBoan\\
\\DataProtect\\
\\adsafer\\
\\AntiProtect\\
\\cleanscan\\
\\New2Clean\\
\\IDBoan\\
\\Scan119\\
\\Vkiller\\
\\infosecret\\
\\VaccineLab\\
\\RegistryClever\\
\\VaccineData\\
\\infohold\\
\\Internetvaccine\\
\\keycop\\
\\k-security\\
\\eClean3.0\\
\\RealVaccine\\
V3.7.4 13/01/2011
- Ajout whitelist:
Smax4.exe
V3.7.3 09/01/2011
V3.7.2 08/01/2011
- Ajout blacklist
SM***.exe
SM****.exe
SM****_$.exe
V3.7.1 07/01/2011
- Ajout blacklist:
sw2#.exe
Fullremove.exe
-Service Blacklist
sst#
V3.7.0 05/01/2011
V3.6.1 28/12/2010
- Ajout blacklist:
V3.6.0 28/12/2010
V3.5.2 27/12/2010
- Ajout Blacklist:
V3.5.1 18/12/2010
V3.5.0 13/12/2010
V3.4.0 11/12/2010
V3.3.0 11/12/2010
V3.2.1 01/12/2010
V3.2.0 20/11/2010
V3.1.0 20/11/2010
RunServices
RunOnceEx
- Blacklist
windowstmsystem.exe
microsoftspeech.exe
mbamzlib.exe
sshnas$
Zludo*.exe
Zjuje*.exe
- Service
SSHNAS
V3.0.1 14/11/2010
Follower
netc.exe
nnmmnnsys.exe
V3.0.0 14/11/2010
- Hijack Policies
NoFolderOptions
V2.9.0 14/11/2010
pezfile
.exe
V2.8.0 13/11/2010
DisableTaskMgr
DisableCMD
V2.7.1 12/11/2010
V2.7.0 11/11/2010
V2.6.0 05/11/2010
V2.5.0 05/11/2010
V2.4.0 05/11/2010
V2.4.0 30/10/2010
V2.3.1 30/10/2010
- BlackList:
- WhiteList:
V2.3.0 22/10/2010
que svchost)
V2.2.0 21/10/2010
V2.1.0 20/10/2010
- Ajout de rogue
V2.0.0 20/10/2010
V1.8.0 19/10/2010
V1.7.1 19/10/2010
flux.exe
RtkBtMnt.exe
GoogleUpdate.exe
V1.7.0 18/10/2010
V1.6.0 18/10/2010
V1.5.0 18/10/2010
BlackList
Hotfix.exe
WhiteList:
GoogleUpdate.exe
chrome.exe
flux.exe
Ati2evxx.exe
spoolsv.exe
V1.4.0 14/10/2010
V1.3.0 14/10/2010
V1.2.0 12/10/2010
V1.1.2 10/10/2010
Whitelist:
rundll32.exe
V1.1.1 08/10/2010
svc.exe
V1.1.0 04/10/2010
- Optimisations
ld15.exe
ld16.exe
andy133.exe
V1.0.3 01/10/2010
V1.0.2 01/10/2010
V1.0.1 01/10/2010
[System Process]
System
smss.exe
csrss.exe
wininit.exe
winlogon.exe
services.exe
lsass.exe
lsm.exe
svchost.exe
dwm.exe
explorer.exe
ctfmon.exe
dllhost.exe
alg.exe
conhost.exe
taskhost.exe
sched.exe
Locator.exe
jusched.exe
V1.0 30/09/2010
ccmain.exe
avp.exe
digprot.exe
ave.exe
winupdate.exe
AVR09.exe
msa.exe
ld09.exe
mediacodec.exe
pp10.exe
SYSDLL.exe
SYS32DLL.exe
DL32.exe
pcdefender.exe
svchost_32.exe
asasa.exe
syst.exe
msctrl.exe
msavsc.exe
msscan.exe
msiemon.exe
msfw.exe
msctrl.exe
msavsc.exe
msscan.exe
msiemon.exe
msfw.exe
setup2.exe
AntivirusXP.exe
ld03.exe
pp06.exe
userload.exe
rs32net.exe
renus2008.exe
sysrc32.exe
svchostw.exe
ld01.exe
ld02.exe
pp2.exe
dll32.exe
winagent.exe
systeminit.exe
sysguard.exe
avrlabs.exe
AnvTrgr.exe
msiconf.exe
VirTrigger.exe
VirusTriggerBin.exe
svhost.exe
reged.exe
spoolsystem.exe
syscert.exe
sysexplorer.exe
wsc32x.exe
- jaro3
- člen Security týmu
- Pohlaví:
- Stav:
Offline
Re: Prosím o kontrolu Logu NTB
RogueKiller Changelog jsem nechtěl. Udělej log ještě jednou podle návodu.
Kdo je online
