Zoek.exe v5.0.0.2 Updated 03-May-2018(Online Version)
Tool run by jaros on 18.03.2024 at 17:59:34,39.
Microsoft Windows 10 Pro 10.0.19045 x64
Running in: Normal Mode Internet Access Detected
Launched: C:\Users\jaros\Desktop\zoek (1).exe [Scan all users] [Script inserted]
==== System Restore Info ======================
18.03.2024 18:01:15 Zoek.exe System Restore Point Created Successfully.
==== Reset Hosts File ======================
# Copyright (c) 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
# localhost name resolution is handled within DNS itself.
127.0.0.1 localhost
::1 localhost
==== Empty Folders Check ======================
C:\PROGRA~2\uTorrent deleted successfully
C:\PROGRA~3\regid.1986-12.com.adobe deleted successfully
C:\PROGRA~3\SoftwareDistribution deleted successfully
C:\PROGRA~3\ssh deleted successfully
C:\Users\jaros\AppData\Local\DBG deleted successfully
C:\Users\jaros\AppData\Local\PeerDistRepub deleted successfully
C:\Users\jaros\AppData\Local\VirtualStore deleted successfully
==== Deleting CLSID Registry Keys ======================
==== Deleting CLSID Registry Values ======================
==== Deleting Services ======================
==== Deleting Files \ Folders ======================
C:\PROGRA~2\uTorrent not found
C:\Users\jaros\AppData\Roaming\discord deleted
C:\Users\jaros\AppData\Roaming\TikTok LIVE Studio deleted
C:\Users\jaros\AppData\Roaming\TruckersMP deleted
C:\PROGRA~3\Package Cache deleted
C:\Users\jaros\AppData\Local\oobelibMkey.log deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\CM2476B.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\CM28E07.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\CM2A312.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\CM2AF57.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5ad6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5ad8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5ae9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5aeb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5aed.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5aef.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b01.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b03.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b05.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b17.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b19.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b1b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b1d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b2e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b30.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b32.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b44.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b75.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1074-55c-20d5b77.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145c4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145c6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145d8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145da.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145dc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145de.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145f0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145f2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145f4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a145f6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a14607.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a14609.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a1460b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a1460d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a1462f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a14825.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a149ec.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a14a6b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10a0-33d4-1a14b19.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d1872.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d1884.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d1886.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d1888.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d188a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d189c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d189e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18a0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18a2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18b3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18b5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18b7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18c9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18cb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18cd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18df.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18e1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d18e3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-10b4-1928-47d1c11.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f4f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f51.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f53.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f64.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f66.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f68.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f6a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f6c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f6e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f80.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f82.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f84.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f86.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f88.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f9a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f9c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311f9e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311fa0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1188-2b40-311fb1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb8d6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb8d8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb8da.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb8dc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb8ee.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb900.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb911.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb913.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb915.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb917.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb929.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb92b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb92d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb92f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb941.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb943.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb945.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb947.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1390-6e4-bdb958.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-98639.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-9864b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-9864d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-9865e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-98670.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-98672.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-98674.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-98695.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986a7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986a9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986ca.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986cc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986de.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986e0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986e2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986f3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986f5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-986f7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-157c-1c18-98709.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4f9317.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4f96e2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4f982c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4f9a80.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa54f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa67a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa747.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa769.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa7a9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa847.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa8c6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fa9e2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4faaed.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fac66.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fadb0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fafe5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fb0c2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fb1cd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-15a0-48-1d4fb1ee.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e5f6f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e604c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e607d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e60bd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e60fe.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e611f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e6150.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e61a0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e61e0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e6240.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e6290.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e62e0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e6311.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e6352.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e6392.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e63c3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e6413.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e64c1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1718-260c-e64f2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1ad.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1bf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1c1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1c3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1d5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1d7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1d9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1ea.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1ec.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac1ee.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac200.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac202.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac204.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac215.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac217.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac229.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac22b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac23d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1870-9d4-3ac23f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fd1e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fd5f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fd71.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fd92.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fdc3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fdd4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fdf6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fe26.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fe38.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fe59.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fe7b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9febb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fecd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fecf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9fef0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9ff11.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9ff13.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9ff25.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e4-d98-9ff27.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-3363879a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638b07.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638b77.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638b98.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638ca4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638cc5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638d25.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638d65.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638d86.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638d98.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638daa.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638dea.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638e2b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638ec9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33638fe4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-336394d8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-336398d1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33639ac7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1e90-35a8-33639d3a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf515.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf5a3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf5e4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf624.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf646.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf722.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf734.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf784.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf7d4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf844.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf884.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf8c5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf905.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf9b3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf9d4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcf9e6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcfa94.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcfd07.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-1eb4-36a8-1fdcfd57.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb32.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb34.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb36.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb38.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb4a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb4c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb4e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb50.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb52.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb63.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb65.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb67.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb69.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb7b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb7d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb7f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb81.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb83.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2014-904-efb94.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b67.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b78.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b7a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b7c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b8e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b90.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b92.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99b94.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99ba6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99ba8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99baa.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99bbb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99bbd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99bbf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99bd1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99bd3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99bd5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99bd7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-22f8-237c-99be9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36bea1f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36bf8a8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36bfd1e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36bfeb7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c0531.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c0a63.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c0b6f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c10b0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c12e5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c1604.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c179c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c1c70.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c22ac.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c22fc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c284e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c35cd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c3e5a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c4fa2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-23e8-29e4-36c6493.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98203.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98205.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98216.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98218.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-9821a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-9821c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-9822e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98230.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98232.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98263.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98265.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98277.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-98279.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-9827b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-9829c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-9829e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-982a0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-982a2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-25cc-2b44-982b3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdf7b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdf7d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdf8e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfa0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfa2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfa4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfb6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfb8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfc9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfcb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfdd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfdf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdfe1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdff3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-bdff5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-be006.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-be008.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-be01a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2814-1d7c-be02b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4b0ca.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4b1f5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4b264.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4b890.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bb9f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bbd0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bc11.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bc51.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bcd0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bd11.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bd80.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4be0f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bebd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bf4b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4bfca.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4c078.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4c0c8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4c157.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2874-29a4-14a4c1b7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f8115bf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f8116ca.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811768.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f8117c8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f8117f9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811878.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f8118e7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811938.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811ac0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811b7e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811cb8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811d66.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811e33.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811e64.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811e95.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811ef5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f811f64.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f812022.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2878-1bfc-f812081.tmp deleted
Kontrola logu - náhlé zpomalení PC Vyřešeno
Re: Kontrola logu - náhlé zpomalení PC
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa5b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa5d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa6f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa71.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa73.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa75.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa86.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa88.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa8a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa8c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aa9e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aaa0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aaa2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aaa4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aab5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aab7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aab9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aacb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2a04-2778-9aacd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9bfe7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9bff8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9bffa.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9bffc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9bffe.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c010.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c012.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c014.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c025.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c027.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c029.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c02b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c04d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c05e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c060.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c062.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c074.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c076.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2ae4-2b78-9c088.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e5d5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e5e6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e5e8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e5ea.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e5fc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e5fe.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e600.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e611.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e613.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e615.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e617.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e629.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e62b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e62d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e63f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e641.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e643.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e645.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2c8c-1480-18e656.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283004.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283064.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2830a4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2830b6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2830f6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283146.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283168.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2831a8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2831c9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283229.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2832b8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283385.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2833f4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283473.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283531.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-283581.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2835c1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-28367f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cb8-3908-2836ee.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b1a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b1c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b1e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b2f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b31.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b33.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b45.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b47.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b49.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b6a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b6c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b6e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b80.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8b82.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8ba3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8ba5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8ba7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8bb9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-2cec-1970-1d8bda.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176a7d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176a7f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176a91.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176a93.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176a95.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176a97.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176aa9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176aab.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176aad.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176aaf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176ac0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176ac2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176ac4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176ac6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176ad8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176ada.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176adc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176ade.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-350c-1d60-5176aef.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2232.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c230f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c235f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c23bf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c243e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c249e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c253c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c25cb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2734.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2811.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c293c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c29ca.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2a68.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2af7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2b57.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2be5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c2cc2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c32a0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3630-36dc-8c388e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9907.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9aee.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9b0f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9b9e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9bfd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9c3e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9cbd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9cfd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9d3e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9dad.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9dfd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9e3e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9efb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9f1d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9f9c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7f9fec.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7fa02c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7fa04e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3770-32a0-7fa12a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab3f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab51.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab63.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab65.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab67.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab69.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab7a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab7c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab7e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab90.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab92.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76ab94.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76aba6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76aba8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76abb9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76abbb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76abbd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76abcf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3954-3a98-a76abd1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246cd2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246cd4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246ce5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246ce7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d09.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d1a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d1c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d2e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d30.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d32.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d43.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d45.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d47.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d59.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d5b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d5d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d6f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d71.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-3b0-9b4-246d73.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddb98.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddbb9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddbdb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddbfc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddbfe.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc10.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc21.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc23.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc35.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc56.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc58.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc5a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc6c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc6e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc7f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc81.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc93.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddc95.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4c0-160c-7ddca7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef90da5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef919fb.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef92c9b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9321b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef93c2f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef94b83.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9578b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef95f6d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef965e7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef96945.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef975aa.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef97ca2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef983a9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef98c46.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef99773.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9a6f6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9b63a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9bec8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9cb8b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9d467.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9de6b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9dfd5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9e3fd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1ef9f545.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa0b50.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa0df2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa216c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa2ad4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa3e20.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa4872.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa58b1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa6267.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa7296.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa7bbf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa88c1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa8c7d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efa9de4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efaa940.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efaa971.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efaa9f0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efaaadc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efaad40.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efaaded.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efaafa5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efab1ba.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efab278.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efab2e7.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efab356.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efab54c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efab7b0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efabcf2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efac07e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efac0de.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efac18b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efac3c0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efacda5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-4d8-3340-1efad47d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6da5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6db6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6db8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6dca.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6dcc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6dde.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6def.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6df1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e03.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e05.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e26.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e38.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e3a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e3c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e3e.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e4f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e51.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e53.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-578-1d64-6e6e65.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9c7d6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9cb43.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9cf2d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9d0a6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9d607.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9d83b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9dd8d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9df35.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9e11b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9ee5c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9f449.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-9fdf0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-a02f3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-a0557.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-a0960.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-a0a6b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-a0de8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-a1405.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-6bc-7c0-a25e9.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-9654ea.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-9654fc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-96550d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-96550f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965511.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965513.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965525.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965527.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965529.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-96552b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-96553d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-96553f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965541.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965543.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965554.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965556.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-965558.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-96555a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-b38-3524-96557b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c588f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c58ef.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c58f1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c5902.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c5933.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c5955.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c5957.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c5978.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c597a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c598b.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c599d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c599f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c59b1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c59b3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c59c4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c59e6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c59e8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c5a09.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-c28-3414-a0c5a1a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51dd73.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51ddd3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51dde4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51de05.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51de36.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51de58.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51de69.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51de8a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51deac.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51debd.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51dedf.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51df0f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51df40.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51df52.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51dfc1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51dfe3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51e004.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51e025.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-cd4-29c-51e046.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-433f33.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-433f83.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-433f95.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-433fe5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434006.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434018.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-43402a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-43402c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-43403d.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-43403f.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434051.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434072.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434084.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434095.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434097.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-4340d8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-434109.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-43412a.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-e80-10a0-43413c.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118b1.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118b3.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118b5.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118c6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118c8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118ca.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118cc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118ce.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118e0.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118e2.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118e4.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118e6.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118e8.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118ea.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118fc.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-118fe.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-11900.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-11902.tmp deleted
C:\Windows\SysNative\config\systemprofile\AppData\Local\tw-f54-950-11904.tmp deleted
C:\Windows\sysWoW64\config\systemprofile\AppData\Local\oobelibMkey.log deleted
C:\Users\jaros\AppData\LocalLow\Unity deleted
"C:\DumpStack.log.tmp" not deleted
==== Orphaned Tasks deleted from Registry ======================
PostponeDeviceSetupToast_S-1-5-21-3048623533-1164617655-1404182790-1001_4 deleted
==== Chromium Look ======================
HKEY_CURRENT_USER\SOFTWARE\Google\Chrome\Extensions
efaidnbmnnnibpcajpcglclefindmkaj - No path found[]
Edge relevant text changes - jaros\AppData\Local\Microsoft\Edge\User Data\Default\Extensions\jmjflgjpcpepeafmmgdpfkogkghcpiha
==== Set IE to Default ======================
Old Values:
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
"Start Page"="http://go.microsoft.com/fwlink/p/?LinkId=255141"
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchScopes]
No DefaultScope Set For HKCU
New Values:
"DefaultScope"="{012E1000-F331-11DB-8314-0800200C9A66}"
==== All HKLM and HKCU SearchScopes ======================
HKLM\SearchScopes "DefaultScope"="{0633EE93-D776-472f-A0FF-E1416B8B2E3A}"
HKLM\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} - http://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
HKLM\Wow6432Node\SearchScopes "DefaultScope"="{0633EE93-D776-472f-A0FF-E1416B8B2E3A}"
HKLM\Wow6432Node\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} - http://www.bing.com/search?q={searchTerms}&FORM=IE8SRC
HKCU\SearchScopes "DefaultScope"="{012E1000-F331-11DB-8314-0800200C9A66}"
HKCU\SearchScopes\{012E1000-F331-11DB-8314-0800200C9A66} - http://www.google.com/search?q={searchTerms}
HKCU\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A} - http://www.bing.com/search?q={searchTerms}&src=IE-SearchBox&FORM=IE8SRC
==== Reset Google Chrome ======================
C:\Users\jaros\AppData\Local\Google\Chrome\User Data\Default\Preferences was reset successfully
C:\Users\jaros\AppData\Local\Google\Chrome\User Data\Default\Secure Preferences was reset successfully
C:\Users\jaros\AppData\Local\Google\Chrome\User Data\System Profile\Preferences was reset successfully
C:\Users\jaros\AppData\Local\Google\Chrome\User Data\System Profile\Secure Preferences was reset successfully
C:\Users\jaros\AppData\Local\Microsoft\Edge\User Data\Default\Preferences was reset successfully
C:\Users\jaros\AppData\Local\Microsoft\Edge\User Data\Default\Secure Preferences was reset successfully
C:\Users\jaros\AppData\Local\Google\Chrome\User Data\Default\Web Data was reset successfully
C:\Users\jaros\AppData\Local\Google\Chrome\User Data\Default\Web Data-journal was reset successfully
C:\Users\jaros\AppData\Local\Microsoft\Edge\User Data\Default\Web Data was reset successfully
C:\Users\jaros\AppData\Local\Microsoft\Edge\User Data\Default\Web Data-journal was reset successfully
==== Empty IE Cache ======================
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5 emptied successfully
C:\Users\jaros\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\Windows\sysWoW64\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\Windows\sysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\Content.IE5 emptied successfully
C:\Users\jaros\AppData\Local\Microsoft\Windows\INetCache\IE emptied successfully
C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\IE emptied successfully
C:\Windows\sysWoW64\config\systemprofile\AppData\Local\Microsoft\Windows\INetCache\IE emptied successfully
==== Empty FireFox Cache ======================
No FireFox Profiles found
==== Empty Chrome Cache ======================
C:\Users\jaros\AppData\Local\Google\Chrome\User Data\Default\Cache emptied successfully
C:\Users\jaros\AppData\Local\Microsoft\Edge\User Data\Default\Cache emptied successfully
==== Empty All Flash Cache ======================
No Flash Cache Found
==== Empty All Java Cache ======================
No Java Cache Found
==== C:\zoek_backup content ======================
C:\zoek_backup (files=1309 folders=1046 507146593 bytes)
==== Empty Temp Folders ======================
C:\Users\Default\AppData\Local\Temp emptied successfully
C:\Users\Default User\AppData\Local\Temp emptied successfully
C:\Users\jaros\AppData\Local\Temp will be emptied at reboot
C:\Windows\SysNative\config\systemprofile\AppData\Local\Temp emptied successfully
C:\Windows\serviceprofiles\networkservice\AppData\Local\Temp emptied successfully
C:\Windows\serviceprofiles\Localservice\AppData\Local\Temp emptied successfully
C:\Windows\Temp will be emptied at reboot
==== After Reboot ======================
C:\Windows\Temp successfully emptied
C:\Users\jaros\AppData\Local\Temp successfully emptied
==== Empty Recycle Bin ======================
C:\$RECYCLE.BIN successfully emptied
==== Deleting Files / Folders ======================
==== EOF on 18.03.2024 at 18:17:38,63 ======================
Old Values:
New Values:
No Java Cache Found
Informace o kontroly
Název produktu : Zemana AntiMalware
Stav kontroly : Dokončena
Datum kontroly : 18.03.2024 18:23:49
Typ kontroly : Inteligentní kontrola
Čas trvání : 00:00:26
Zkontrolované objekty : 2181
Zjištěné objekty : 1
Vyloučené objekty : 0
Automatické odesílání : Ano
Operační systém : Windows 10 x64
Procesor : 4X Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz
Režim systému BIOS : UEFI
Informace o doméně : WORKGROUP,False,NetSetupWorkgroupName
CUID : 12A2A88E8051884782AED2
Odhalení
MD5 :
Stav : Zkontrolováno
Objekt : c:\users\jaros\appdata\local\google\chrome\user data\profile 3\extensions\dacdinoicboceafielngnmjjplncljhj
Vydavatel :
Velikost : 0
Odhalení : HijackExt:ChromePlugin/buykers | slevové kupony a kódy
Akce : Vymazat
Odhalení
MD5 :
Vydavatel :
Velikost : 0
Akce : Vymazat
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 18:25:10, on 18.03.2024
MSIE: Internet Explorer v11.0 (11.00.19041.3636)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
C:\Windows\System32\PrintDisp.exe
C:\Program Files (x86)\Steam\steam.exe
C:\Program Files (x86)\Adobe\Adobe Creative Cloud Experience\CCXProcess.exe
C:\Program Files (x86)\Adobe\Adobe Creative Cloud Experience\libs\node.exe
C:\ProgramData\Wargaming.net\GameCenter\wgc.exe
C:\ProgramData\Wargaming.net\GameCenter\WargamingErrorMonitor.exe
C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\AdobeIPCBroker.exe
C:\ProgramData\Wargaming.net\GameCenter\dlls\wgc_renderer_host.exe
C:\Users\jaros\Desktop\kontrola pc\HijackThis.exe
F2 - REG:system.ini: UserInit=C:\Windows\system32\userinit.exe
O1 - Hosts: ::1 localhost
O2 - BHO: Lync Click to Call BHO - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\OCHelper.dll
O4 - HKCU\..\Run: [MicrosoftEdgeAutoLaunch_93532516BFAFC43A8D776AF74ECBD1B6] "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --no-startup-window --win-session-start
O4 - HKCU\..\Run: [Steam] "C:\Program Files (x86)\Steam\steam.exe" -silent
O4 - HKCU\..\Run: [CCXProcess] "C:\Program Files (x86)\Adobe\Adobe Creative Cloud Experience\CCXProcess.exe"
O4 - HKCU\..\Run: [Adobe Acrobat Synchronizer] "C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\AdobeCollabSync.exe"
O4 - HKCU\..\Run: [Wargaming.net Game Center] "C:\ProgramData\Wargaming.net\GameCenter\wgc.exe" --background
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\Program Files\Microsoft Office\Root\Office16\EXCEL.EXE/3000
O9 - Extra button: Lync Click to Call - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\OCHelper.dll
O9 - Extra 'Tools' menuitem: Lync Click to Call - {31D09BA0-12F5-4CCE-BE8A-2923E76605DA} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\OCHelper.dll
O18 - Protocol: mso-minsb-roaming.16 - {83C25742-A9F7-49FB-9138-434302C88D07} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL
O18 - Protocol: mso-minsb.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL
O18 - Protocol: osf-roaming.16 - {42089D2D-912D-4018-9087-2B87803E93FB} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL
O18 - Protocol: osf.16 - {5504BE45-A83B-4808-900A-3A5C36E7F77A} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesX86\Microsoft Office\Office16\MSOSB.DLL
O18 - Filter hijack: text/xml - {807583E5-5146-11D5-A672-00B0D022E945} - C:\Program Files\Microsoft Office\root\VFS\ProgramFilesCommonX86\Microsoft Shared\Office16\MSOXMLMF.DLL
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: @%SystemRoot%\system32\CredentialEnrollmentManager.exe,-100 (CredentialEnrollmentManagerUserSvc) - Unknown owner - C:\Windows\system32\CredentialEnrollmentManager.exe (file missing)
O23 - Service: CredentialEnrollmentManagerUserSvc_af837 - Unknown owner - C:\Windows\system32\CredentialEnrollmentManager.exe (file missing)
O23 - Service: @%SystemRoot%\system32\DiagSvcs\DiagnosticsHub.StandardCollector.ServiceRes.dll,-1000 (diagnosticshub.standardcollector.service) - Unknown owner - C:\Windows\system32\DiagSvcs\DiagnosticsHub.StandardCollector.Service.exe (file missing)
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: NVIDIA FrameView SDK service (FvSvc) - NVIDIA - C:\Program Files\NVIDIA Corporation\FrameViewSDK\nvfvsdksvc_x64.exe
O23 - Service: @%systemroot%\system32\GameInputSvc.exe,-101 (GameInputSvc) - Unknown owner - C:\Windows\System32\GameInputSvc.exe (file missing)
O23 - Service: Google Chrome Elevation Service (GoogleChromeElevationService) (GoogleChromeElevationService) - Google LLC - C:\Program Files\Google\Chrome\Application\122.0.6261.129\elevation_service.exe
O23 - Service: Služba Aktualizace Google (gupdate) (gupdate) - Google LLC - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Služba Aktualizace Google (gupdatem) (gupdatem) - Google LLC - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: HP Print Scan Doctor Service (HPPrintScanDoctorService) - HP Inc. - C:\Program Files\HPPrintScanDoctor\HPPrintScanDoctorService.exe
O23 - Service: @oem10.inf,%SocketHECIServiceName%;Intel(R) Capability Licensing Service TCP IP Interface (Intel(R) Capability Licensing Service TCP IP Interface) - Intel(R) Corporation - C:\Windows\System32\DriverStore\FileRepository\iclsclient.inf_amd64_76523213b78d9046\lib\SocketHeciServer.exe
O23 - Service: @oem10.inf,%TPMProvisioningServiceName%;Intel(R) TPM Provisioning Service (Intel(R) TPM Provisioning Service) - Intel(R) Corporation - C:\Windows\System32\DriverStore\FileRepository\iclsclient.inf_amd64_76523213b78d9046\lib\TPMProvisioningService.exe
O23 - Service: Intel(R) Dynamic Application Loader Host Interface Service (jhi_service) - Intel Corporation - C:\Windows\System32\DriverStore\FileRepository\dal.inf_amd64_b5484efd38adbe8d\jhi_service.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Logitech Gaming Registry Service (LogiRegistryService) - Logitech Inc. - C:\Program Files\Logitech Gaming Software\Drivers\APOService\LogiRegistryService.exe
O23 - Service: Malwarebytes Service (MBAMService) - Malwarebytes - C:\Program Files\Malwarebytes\Anti-Malware\MBAMService.exe
O23 - Service: MBVpnTunnelService - Malwarebytes - C:\Program Files\Malwarebytes\Anti-Malware\MBVpnTunnelService.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NVIDIA LocalSystem Container (NvContainerLocalSystem) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
O23 - Service: NVIDIA Display Container LS (NVDisplay.ContainerLocalSystem) - NVIDIA Corporation - C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_72a60bcfb646da4c\Display.NvContainer\NVDisplay.Container.exe
O23 - Service: @%systemroot%\system32\PerceptionSimulation\PerceptionSimulationService.exe,-101 (perceptionsimulation) - Unknown owner - C:\Windows\system32\PerceptionSimulation\PerceptionSimulationService.exe (file missing)
O23 - Service: Printer Control - Unknown owner - C:\Windows\system32\PrintCtrl.exe (file missing)
O23 - Service: RogueKiller RTP (rkrtservice) - Unknown owner - C:\Program Files\RogueKiller\RogueKillerSvc.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\SecurityHealthAgent.dll,-1002 (SecurityHealthService) - Unknown owner - C:\Windows\system32\SecurityHealthService.exe (file missing)
O23 - Service: @%ProgramFiles%\Windows Defender Advanced Threat Protection\MsSense.exe,-1001 (Sense) - Unknown owner - C:\Program Files (x86)\Windows Defender Advanced Threat Protection\MsSense.exe (file missing)
O23 - Service: @%SystemRoot%\system32\SensorDataService.exe,-101 (SensorDataService) - Unknown owner - C:\Windows\System32\SensorDataService.exe (file missing)
O23 - Service: @%SystemRoot%\System32\SgrmBroker.exe,-100 (SgrmBroker) - Unknown owner - C:\Windows\system32\SgrmBroker.exe (file missing)
O23 - Service: @firewallapi.dll,-50323 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spectrum.exe,-101 (spectrum) - Unknown owner - C:\Windows\system32\spectrum.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: Steam Client Service - Valve Corporation - C:\Program Files (x86)\Common Files\Steam\steamservice.exe
O23 - Service: @%SystemRoot%\system32\TieringEngineService.exe,-702 (TieringEngineService) - Unknown owner - C:\Windows\system32\TieringEngineService.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: Intel(R) Management Engine WMI Provider Registration (WMIRegistrationService) - Intel Corporation - C:\Windows\System32\DriverStore\FileRepository\mewmiprov.inf_amd64_cad1db73e8c782a6\WMIRegistrationService.exe
End of file - 11715 bytes
Boot mode: Normal
Running processes:
- jaro3
- člen Security týmu
- Pohlaví:
- Stav:
Offline
Co problémy?
Vypadá to, že je vše v pořádku. Děkuji.
- jaro3
- Pohlaví:
- Stav:
Offline
Stáhni si zde DelFix
https://www.bleepingcomputer.com/download/delfix/
ulož si soubor na plochu.
Poklepáním na ikonu spusť nástroj Delfix.exe
( Ve Windows Vista, Windows 7, 8 a10 musíš spustit soubor pravým tlačítkem myši -> Spustit jako správce .
V hlavním menu, zkontroluj tyto možnosti - Odstranění dezinfekce nástrojů (Remove desinfection tools) – Vyčistit body obnovy (Purge System Restore)
Poté klikněte na tlačítko Spustit (Run) a nech nástroj dělat svoji práci
Poté se zpráva se otevře (DelFix.txt). Vlož celý obsah zprávy sem.Jinak je zpráva zde:
v C: \ DelFix.txt
Pokud nejsou problémy , je to vše a můžeš dát vyřešeno , zelenou fajfku.
v C: \ DelFix.txt
Re: Kontrola logu - náhlé zpomalení PC Vyřešeno
# DelFix v1.010 - Logfile created 21/03/2024 at 13:33:59
# Updated 26/04/2015 by Xplode
# Username : jaros - DESKTOP-U7HA971
# Operating System : Windows 10 Enterprise (64 bits)
~ Removing disinfection tools ...
Deleted : C:\zoek_backup
Deleted : C:\AdwCleaner
Deleted : C:\zoek-results.log
Deleted : HKLM\SOFTWARE\OldTimer Tools
Deleted : HKLM\SOFTWARE\TrendMicro\Hijackthis
~ Cleaning system restore ...
Deleted : RP #66 [Naplánovaný kontrolní bod | 03/17/2024 07:50:52]
Deleted : RP #67 [zoek.exe restore point | 03/18/2024 17:01:07]
New restore point created !
########## - EOF - ##########
Kdo je online
Uživatelé prohlížející si toto fórum: Žádní registrovaní uživatelé a 12 hostů
