zdravím mam problém moje pc se začalo vypínat pomalu (10 minut) poradíte co s tím přikladám log z 3d mark
Benchmark
Version 1.2.0
Width 1920
Height 1080
Anti-Aliasing None
Anti-Aliasing Quality 0
Texture Filtering Optimal
Anisotropic Level 1
VS Profile 3_0
PS Profile 3_0
Force full precision No
Disable HW shadow mapping No
Disable post-processing No
Force software vertex shader No
Color mipmaps No
Force software FP filtering No
Repeat tests Off
Fixed framerate Off
Comment
3DMark Score 17631 3DMarks
SM2.0 Score 7 K
HDR/SM3.0 Score 9 K
CPU Score 4305
Game Score N/A N/A
GT1 - Return To Proxycon 54,521 FPS SM2.0 Graphics Tests
GT2 - Firefly Forest 56,514 FPS SM2.0 Graphics Tests
CPU1 - Red Valley 1,436 FPS CPU Tests
CPU2 - Red Valley 2,064 FPS CPU Tests
HDR1 - Canyon Flight 110,648 FPS HDR/SM3.0 Graphics Tests
HDR2 - Deep Freeze 74,015 FPS HDR/SM3.0 Graphics Tests
Fill Rate - Single-Texturing 17602,748 Mtexels/s Feature Tests
Fill Rate - Multi-Texturing 59561,102 Mtexels/s Feature Tests
Pixel Shader 904,500 FPS Feature Tests
Vertex Shader - Simple 858,534 Mvertices/s Feature Tests
Vertex Shader - Complex 566,288 Mvertices/s Feature Tests
Shader Particles (SM3.0) 347,222 FPS Feature Tests
Perlin Noise (SM3.0) 423,063 FPS Feature Tests
8 Triangles 10,444 Mtriangles/s Batch Size Tests
32 Triangles 42,201 Mtriangles/s Batch Size Tests
128 Triangles 161,690 Mtriangles/s Batch Size Tests
512 Triangles 656,401 Mtriangles/s Batch Size Tests
2048 Triangles 978,461 Mtriangles/s Batch Size Tests
32768 Triangles 976,463 Mtriangles/s Batch Size Tests
System Info
Version 3,21
File Version Infos File ID File Name File Version Product Version
FMSIDLL C:\Program Files (x86)\Common Files\Futuremark Shared\Futuremark SystemInfo\FMSI.dll 3, 21, 2, 1 3, 21, 2, 1
FMSIXDLL C:\Program Files (x86)\Common Files\Futuremark Shared\Futuremark SystemInfo\FMSIX.dll 3, 21, 2, 1 3, 21, 2, 1
FMSIX64DLL C:\Program Files (x86)\Common Files\Futuremark Shared\Futuremark SystemInfo\FMSIX64.dll 3, 21, 2, 1 3, 21, 2, 1
CPUIDSDKDLL C:\Program Files (x86)\Common Files\Futuremark Shared\Futuremark SystemInfo\cpuidsdk.dll 1, 0, 5, 3 1, 0, 5, 3
Statistics
Components ID Enabled Notes Begin Time End Time
CPU 1 Finished OK.
DirectX 1 Finished OK.
Memory 1 Finished OK.
Motherboard 1 Finished OK.
Monitor 1 Finished OK.
Power Supply 1 Finished OK.
Windows 1 Finished OK.
Storage Device 1 Finished OK.
CPUID 1 Finished OK.
NVAPI 1 Finished OK.
ADL 1 Finished OK.
WMI 1 Finished OK.
CPU Info
Physical Processors 1
Logical Processors 4
Central Processing Units
Manufacturer AMD
Family AMD Phenom(tm) II X4 960T Processor
Architecture 64-bit
Internal Clock 3000 MHz
Internal Clock Maximum 3000 MHz
External Clock 200 MHz
Socket Designation CPU1
Type
Upgrade
MultiCore 4 Processor Cores
HyperThreadingTechnology N/A
Capabilities MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, PAE, NX, SSE4A
Version AMD Phenom(tm) II X4 960T Processor
Caches Level Capacity Type Type Details Error Correction Type Associativity
1 512 KB Internal Pipeline Burst Single-bit ECC 4-way Set-Associative
2 2048 KB Internal Pipeline Burst Single-bit ECC 4-way Set-Associative
3 6 MB Internal Pipeline Burst Single-bit ECC 4-way Set-Associative
CPUIDs EAX EBX ECX EDX Order
0x00000006 0x68747541 0x444d4163 0x69746e65 0
0x00100fa0 0x01040800 0x00802009 0x178bfbff 1
0x00000000 0x00000000 0x00000000 0x00000000 2
0x00000000 0x00000000 0x00000000 0x00000000 3
0x00000000 0x00000000 0x00000000 0x00000000 4
0x00000040 0x00000040 0x00000003 0x00000000 5
0x00000000 0x00000000 0x00000001 0x00000000 6
Ext CPUIDs EAX EBX ECX EDX Order
0x8000001b 0x68747541 0x444d4163 0x69746e65 0
0x00100fa0 0x100093c4 0x000037ff 0xefd3fbff 1
0x20444d41 0x6e656850 0x74286d6f 0x4920296d 2
0x34582049 0x30363920 0x72502054 0x7365636f 3
0x00726f73 0x00000000 0x00000000 0x00000000 4
0xff30ff10 0xff30ff20 0x40020140 0x40020140 5
0x20800000 0x42004200 0x02008140 0x0030b140 6
0x00000000 0x00000000 0x00000000 0x000003f9 7
0x00003030 0x00000000 0x00003003 0x00000000 8
0x00000000 0x00000000 0x00000000 0x00000000 9
0x00000001 0x00000040 0x00000000 0x0000040f 10
0x00000000 0x00000000 0x00000000 0x00000000 11
0x00000000 0x00000000 0x00000000 0x00000000 12
0x00000000 0x00000000 0x00000000 0x00000000 13
0x00000000 0x00000000 0x00000000 0x00000000 14
0x00000000 0x00000000 0x00000000 0x00000000 15
DirectX Info
Version 11
Long Version 4.09.00.0904
DirectDraw Info
Version 6.1.7600.16385
Primary Device AMD Radeon HD 7800 Series
Linked Display Adapters 1
Display Devices
Display Device
Description AMD Radeon HD 7800 Series
Manufacturer Advanced Micro Devices, Inc.
Total Local Video Memory 2038 MB
Total Local Texture Memory 2038 MB
AGP Aperture Size 3842 MB
Driver File aticfx32.dll
Driver Version 15.300.1025.1001
Driver Details
Driver Date 4.12.2015
Driver WHQL Certified PRAVDA
Max Texture Width 16 Kpx
Max Texture Height 16 Kpx
Max User Clipping Planes 6
Max Active Hardware Lights 8
Max Texture Blending Stages 8
Fixed Function Textures In Single Pass 8
Vertex Shader Version 5
Pixel Shader Version 5
Max Vertex Blend Matrices 0
Max Texture Coordinates 8
PCI
Name AMD Radeon HD 7800 Series
Vendor ID 0x1002
Device ID 0x6819
SubSystem ID 0x043a1043
Revision ID 0x0000
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit A [8]
8-bit YUV [800]
16-bit AYUV [8800]
8-bit AYUV [4400]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Capabilities AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Texture Border Color, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
Multi GPU Devices
DirectShow Info
Version 6.6.7600.16385
Registered DirectShow Filters
AC3 Parser Filter
AC3Filter
ACM Wrapper
AVI Decompressor
AVI Draw
AVI Splitter
AVI/WAV File Source
BDA MPEG2 Transport Information Filter
Color Space Converter
DV Muxer
DV Splitter
DV Video Decoder
Decrypt/Tag
Default DirectSound Device
Default MidiOut Device
DirectVobSub (auto-loading version)
File Source (Async.)
File Source (URL)
File stream renderer
Haali Media Splitter
Haali Media Splitter (AR)
Internal Script Command Renderer
LAV Audio Decoder
LAV Splitter
LAV Splitter Source
LAV Video Decoder
Line 21 Decoder
Line 21 Decoder 2
MIDI Parser
MJPEG Decompressor
MP3 Decoder DMO
MPC - Avi Source
MPC - Avi Splitter
MPC - FLV Source (Gabest)
MPC - FLV Splitter (Gabest)
MPC - MP4 Source
MPC - MP4 Splitter
MPC - MPEG4 Video Source
MPC - MPEG4 Video Splitter
MPC - Matroska Source
MPC - Matroska Splitter
MPC - Mpeg Source (Gabest)
MPC - Mpeg Splitter (Gabest)
MPC - Video decoder
MPEG Audio Decoder
MPEG Video Decoder
MPEG-2 Demultiplexer
MPEG-2 Sections and Tables
MPEG-2 Splitter
MPEG-I Stream Splitter
Microsoft DTV-DVD Audio Decoder
Microsoft DTV-DVD Video Decoder
Mpeg4 Decoder DMO
Mpeg43 Decoder DMO
Mpeg4s Decoder DMO
Multi-file Parser
PBDA DTFilter
RDP DShow Redirection Filter
RealAudio Decoder
RealMedia Source
RealMedia Splitter
RealVideo Decoder
SAMI (CC) Parser
TechSmith File Source
Techsmith Quicktime MOV Source
VBI Codec
VBI Surface Allocator
VGA 16 Color Ditherer
Video Port Manager
Video Renderer
WM ASF Reader
WM ASF Writer
WMAPro over S/PDIF DMO
WMAudio Decoder DMO
WMSpeech Decoder DMO
WMV Screen decoder DMO
WMVideo Decoder DMO
Wave Parser
ffdshow Audio Decoder
ffdshow DXVA Video Decoder
ffdshow Video Decoder
iTV Data Capture filter
iTV Data Sink
DirectSound Info
Speaker Configuration Stereo
Speaker Geometry Wide
Primary Device Reproduktory (Realtek High Definition Audio)
Sound Devices
Memory Info
Total Physical Memory 8 GB
Free Physical Memory 6 GB
Total Pagefile Memory 16 GB
Free Pagefile Memory 14 GB
Memory Arrays
Memory Array
Max Module Capacity 8 MB
Location System Board
Use System
Supported Error DC
Supported Speeds
Supported Types
Supported Voltages
Memory Slots Installed Enabled Size Form Factor Frequency Slot Manufacturer Type Type Details Enabled Size Total Bit Width Data Bit Width
0 B DIMM 1333 MHz DIMM1 [BANK0] Manufacturer00 Synchronous 0 B 64 b 64 b
0 B DIMM 1333 MHz DIMM2 [BANK1] Manufacturer01 Synchronous 0 B 64 b 64 b
0 B 0 Hz DIMM3 [BANK2] Manufacturer02 0 B 0 b 64 b
0 B 0 Hz DIMM4 [BANK3] Manufacturer03 0 B 0 b 64 b
Motherboard Info
Supported Slot Types PCI, PCI Express
Manufacturer MSI
Model 890FXA-GD65 (MS-7640)
Version 3
BIOS Vendor American Megatrends Inc.
BIOS Version V18.1
BIOS Release Date 11.3.2011
BIOS Properties Plug and Play, Flash
Card Slots Order Designation Type Characteristics Data Bus Width Details
1 PCI1 PCI 3.3V, Shared, PME Signal 32 b In Use, Short
2 PCI2 PCI 3.3V, Shared, PME Signal 32 b Available, Short
3 PCIE1 PCI Express 3.3V, Shared, PME Signal 32 b Available, Short
4 PCIE2 PCI Express 3.3V, Shared, PME Signal 32 b Available, Short
PCI Devices Manufacturer Location Type Name Vendor ID Device ID SubSystem ID Revision ID
Microsoft Sbrnice PCI 0, zazen 20, funkce 2 adi High Definition Audio 0x1002 0x4383 0x76401462 0x0040
ATI Sbrnice PCI 0, zazen 20, funkce 4 adi sbrnice PCI procesoru ATI I/O Communications Processor 0x1002 0x4384 0x00000000 0x0040
ATI Sbrnice PCI 0, zazen 20, funkce 0 adi sbrnice SMBus procesoru ATI I/O Communications Processor 0x1002 0x4385 0x00000000 0x0042
(Standardn adie IDE ATA/ATAPI) Sbrnice PCI 0, zazen 17, funkce 0 PCI Standardn dvoukanlov adi IDE 0x1002 0x4390 0x76401462 0x0040
(Standardn hostitelsk adi USB) Sbrnice PCI 0, zazen 18, funkce 2 Standardn rozen hostitelsk adi z PCI na USB 0x1002 0x4396 0x76401462 0x0000
(Standardn hostitelsk adi USB) Sbrnice PCI 0, zazen 19, funkce 2 Standardn rozen hostitelsk adi z PCI na USB 0x1002 0x4396 0x76401462 0x0000
(Standardn hostitelsk adi USB) Sbrnice PCI 0, zazen 22, funkce 2 Standardn rozen hostitelsk adi z PCI na USB 0x1002 0x4396 0x76401462 0x0000
(Standardn hostitelsk adi USB) Sbrnice PCI 0, zazen 18, funkce 0 Standardn hostitelsk adi USB OpenHCD 0x1002 0x4397 0x76401462 0x0000
(Standardn hostitelsk adi USB) Sbrnice PCI 0, zazen 19, funkce 0 Standardn hostitelsk adi USB OpenHCD 0x1002 0x4397 0x76401462 0x0000
(Standardn hostitelsk adi USB) Sbrnice PCI 0, zazen 22, funkce 0 Standardn hostitelsk adi USB OpenHCD 0x1002 0x4397 0x76401462 0x0000
(Standardn hostitelsk adi USB) Sbrnice PCI 0, zazen 20, funkce 5 Standardn hostitelsk adi USB OpenHCD 0x1002 0x4399 0x76401462 0x0000
(Standardn adie IDE ATA/ATAPI) Sbrnice PCI 0, zazen 20, funkce 1 PCI Standardn dvoukanlov adi IDE 0x1002 0x439c 0x76401462 0x0040
(Standardn systmov zazen) Sbrnice PCI 0, zazen 20, funkce 3 Most mezi sbrnicemi PCI a ISA 0x1002 0x439d 0x76401462 0x0040
(Standardn systmov zazen) Sbrnice PCI 0, zazen 0, funkce 0 Most standardu PCI hostitelskho procesoru 0x1002 0x5a11 0x5a111002 0x0002
(Standardn systmov zazen) Sbrnice PCI 0, zazen 2, funkce 0 Most standardu PCI mezi sbrnicemi PCI 0x1002 0x5a16 0x5a111002 0x0000
(Standardn systmov zazen) Sbrnice PCI 0, zazen 5, funkce 0 Most standardu PCI mezi sbrnicemi PCI 0x1002 0x5a19 0x5a111002 0x0000
(Standardn systmov zazen) Sbrnice PCI 0, zazen 7, funkce 0 Most standardu PCI mezi sbrnicemi PCI 0x1002 0x5a1b 0x5a111002 0x0000
Advanced Micro Devices, Inc. Sbrnice PCI 4, zazen 0, funkce 0 AMD Radeon HD 7800 Series 0x1002 0x6819 0x043a1043 0x0000
Microsoft Sbrnice PCI 4, zazen 0, funkce 1 adi High Definition Audio 0x1002 0xaab0 0xaab01043 0x0000
(Standardn systmov zazen) Sbrnice PCI 0, zazen 24, funkce 0 Most standardu PCI hostitelskho procesoru 0x1022 0x1200 0x00000000 0x0000
(Standardn systmov zazen) Sbrnice PCI 0, zazen 24, funkce 1 Most standardu PCI hostitelskho procesoru 0x1022 0x1201 0x00000000 0x0000
(Standardn systmov zazen) Sbrnice PCI 0, zazen 24, funkce 2 Most standardu PCI hostitelskho procesoru 0x1022 0x1202 0x00000000 0x0000
(Standardn systmov zazen) Sbrnice PCI 0, zazen 24, funkce 3 Most standardu PCI hostitelskho procesoru 0x1022 0x1203 0x00000000 0x0000
(Standardn systmov zazen) Sbrnice PCI 0, zazen 24, funkce 4 Most standardu PCI hostitelskho procesoru 0x1022 0x1204 0x00000000 0x0000
Renesas Electronics Sbrnice PCI 2, zazen 0, funkce 0 Renesas Electronics USB 3.0 Host Controller 0x1033 0x0194 0x76401462 0x0003
Realtek Sbrnice PCI 3, zazen 0, funkce 0 Realtek PCIe GBE Family Controller 0x10ec 0x8168 0x76401462 0x0006
System Devices Manufacturer Name Vendor ID Device ID SubSystem ID Revision ID
Microsoft adi High Definition Audio 0x1002 0x4383 0x76401462 0x0040
ATI adi sbrnice PCI procesoru ATI I/O Communications Processor 0x1002 0x4384 0x00000000 0x0040
ATI adi sbrnice SMBus procesoru ATI I/O Communications Processor 0x1002 0x4385 0x00000000 0x0042
(Standardn systmov zazen) Most mezi sbrnicemi PCI a ISA 0x1002 0x439d 0x76401462 0x0040
(Standardn systmov zazen) Most standardu PCI hostitelskho procesoru 0x1002 0x5a11 0x5a111002 0x0002
(Standardn systmov zazen) Most standardu PCI mezi sbrnicemi PCI 0x1002 0x5a16 0x5a111002 0x0000
(Standardn systmov zazen) Most standardu PCI mezi sbrnicemi PCI 0x1002 0x5a19 0x5a111002 0x0000
(Standardn systmov zazen) Most standardu PCI mezi sbrnicemi PCI 0x1002 0x5a1b 0x5a111002 0x0000
(Standardn systmov zazen) Most standardu PCI hostitelskho procesoru 0x1022 0x1200 0x00000000 0x0000
(Standardn systmov zazen) Most standardu PCI hostitelskho procesoru 0x1022 0x1201 0x00000000 0x0000
(Standardn systmov zazen) Most standardu PCI hostitelskho procesoru 0x1022 0x1202 0x00000000 0x0000
(Standardn systmov zazen) Most standardu PCI hostitelskho procesoru 0x1022 0x1203 0x00000000 0x0000
(Standardn systmov zazen) Most standardu PCI hostitelskho procesoru 0x1022 0x1204 0x00000000 0x0000
USB Devices Description Driver Date Driver Version Device Class Vendor ID Product ID Revision
Koenov rozboova USB 21.6.2006 6.1.7601.18328 Universal Serial Bus Controller 0x1002 0x4397 0x0000
Koenov rozboova USB 21.6.2006 6.1.7601.18328 Universal Serial Bus Controller 0x1002 0x4399 0x0000
Koenov rozboova USB 21.6.2006 6.1.7601.18328 Universal Serial Bus Controller 0x1002 0x4396 0x0000
Sloen zazen USB 21.6.2006 6.1.7601.18328 Universal Serial Bus Controller 0x0458 0x0138 0x0038
Vstupn zazen USB 21.6.2006 6.1.7601.18199 Human Interface Device 0x0458 0x0138 0x0038
Sloen zazen USB 21.6.2006 6.1.7601.18328 Universal Serial Bus Controller 0x045e 0x074a 0x0101
Zobrazovac zazen USB 21.6.2006 6.1.7601.18208 Imaging Device 0x045e 0x074a 0x0101
Vstupn zazen USB 21.6.2006 6.1.7601.18199 Human Interface Device 0x046d 0xc214 0x0205
IT9135 BDA Device 2.9.2011 11.9.2.1 Sound, Video or Game Controller 0x048d 0x9005 0x0200
Sloen zazen USB 21.6.2006 6.1.7601.18328 Universal Serial Bus Controller 0x1ea7 0x2001 0x0102
Vstupn zazen USB 21.6.2006 6.1.7601.18199 Human Interface Device 0x1ea7 0x2001 0x0102
FireWire Devices
Bluetooth Devices
Monitor Info
Monitors
Monitor
Name Obecn monitor PnP
Manufacturer (Standardn typy monitor)
Max Width 1600 px
Max Height 1200 px
Power Supply Info
Batteries
Operating System Info
Name Windows 7 Ultimate
Version 6.1.7601
PlatformId 2
Service Pack
Version 1
Name Service Pack 1
Suite 256
Product Type 1
Product Version 1
Media Center PRAVDA
Windows Environment 64-bit
DEP
Hardware Support PRAVDA
Applications Protected PRAVDA
Drivers Protected PRAVDA
User Option On for essential Windows programs and services only
Windows Experience Index
State 2
Description Index uivatelskch zkuenost se systmem Windows: Bez hodnocen
Rating 5,9
Date 2,01602E+13
Sub Indices Name Description Title Score
Memory 8,00 GB Pam (RAM): 7,4
Processor AMD Phenom(tm) II X4 960T Processor Procesor: 7,3
HDD 360GB volnch (931GB celkem) Primrn pevn disk: 5,9
Gaming Graphics 4116 MB grafick pamti k dispozici celkem Hern grafika: 7,9
Graphics AMD Radeon HD 7800 Series Grafika: 7,9
ReadyBoost Devices
Locale CZ
Desktop Width 1920 px
Desktop Height 1080 px
Desktop BPP 32 b
Internet Explorer Version 99600
Applications
Scanning your system configuration
3DMark06 - Professional Edition
Internet Explorer_Hidden
Processes Name PID Memory Usage
System Idle Process 0 24 KB
System 4 996 KB
smss.exe 280 1224 KB
csrss.exe 424 4852 KB
wininit.exe 492 4716 KB
csrss.exe 528 25 MB
services.exe 552 11 MB
lsass.exe 576 13 MB
lsm.exe 584 4560 KB
winlogon.exe 644 8 MB
svchost.exe 724 11 MB
svchost.exe 812 9 MB
atiesrxx.exe 872 5 MB
svchost.exe 948 18 MB
svchost.exe 984 215 MB
svchost.exe 120 14 MB
svchost.exe 304 43 MB
svchost.exe 896 7 MB
svchost.exe 1084 35 MB
atieclxx.exe 1176 7 MB
spoolsv.exe 1276 12 MB
svchost.exe 1340 13 MB
armsvc.exe 1456 4040 KB
Fuel.Service.exe 1476 12 MB
CLHNServiceForPowerDVD.exe 1564 4168 KB
taskhost.exe 1600 16 MB
dwm.exe 1660 9 MB
explorer.exe 1764 101 MB
CLMSMonitorService.exe 1840 3640 KB
CLMSServer.exe 1864 7 MB
svchost.exe 1912 14 MB
ekrn.exe 1944 133 MB
RAVCpl64.exe 1072 12 MB
egui.exe 1120 18 MB
cnext.exe 1172 39 MB
PnkBstrA.exe 2272 4372 KB
svchost.exe 2392 9 MB
TeamViewer_Service.exe 2432 18 MB
CCleaner64.exe 2572 1364 KB
nusb3mon.exe 2692 7 MB
GWX.exe 2788 560 KB
svchost.exe 2268 6 MB
TeamViewer.exe 2932 52 MB
tv_w32.exe 3156 5 MB
tv_x64.exe 3164 5 MB
TrustedInstaller.exe 3436 20 MB
svchost.exe 3524 29 MB
taskhost.exe 508 14 MB
svchost.exe 3652 10 MB
MediaDetector.exe 4128 9 MB
3DMark06.exe 2752 47 MB
dllhost.exe 3768 18 MB
WmiPrvSE.exe 4932 7 MB
WmiPrvSE.exe 4924 6 MB
Logical Drives Drive Letter Label Type Capacity Available
C: Hard Disk 931 GB 360 GB
D: CD-ROM 0 B 0 B
System Drive Letter C:
Storage Devices Device Drive Type Name Manufacturer Model Vendor ID String Product ID String Product Revision String Serial Number Interface Type Device Bus Type Capacity Drive Letters CD Max Read Speed CD Read Capabilities CD Write Capabilities DVD Read Capabilities DVD Write Capabilities SMART Acoustic Management Physical sector size
WDC WD10EZRX-00A8LB0 ATA Device (Standardn diskov jednotky) WDC WD10EZRX-00A8LB0 ATA Device IDE 932 GB 0 0 B
unknown unknown unknown unknown 0 B 0 0 B
CPUID Info
DLL Version 16778499.0.0.0
Processor Count 1
Bus Frequency 200
CPUID Processors
CPUID Processor
Core Count 4
Thread Count 4
Processor Name AMD K10
Processor Code Name
Processor Package Socket AM2+ (940)
Processor Specification AMD Phenom(tm) II X4 960T Processor
Processor Stepping
Manufacturing Process -1
Capabilities MMX, 3DNow!, Extended 3DNow!, SSE, SSE2, SSE3, NX, SSE4A, x86-64, VMX
Stock Clock Frequency 4096 MHz
Stock Bus Frequency 191 Hz
Rated Bus Frequency 1907 Hz
Max Cache Level 3
Hyper Threading Supported 0
Hyper Threading Enabled 0
Model Identifier 33570816
CPUID Cores Thread Count Core Clock Frequency Core Clock Multiplier Core Temperature
1 763 Hz 4 29
1 763 Hz 4 29
1 763 Hz 4 29
1 763 Hz 4 29
CPUID Caches Level Capacity Type Type Details Error Correction Type Associativity
1 256 KB Data, Internal
1 256 KB Instruction, Internal
2 2048 KB Instruction, Data, Internal
3 6 MB Instruction, Data, Internal
CPUID Memory
Memory Type DDR3
Memory Size 8192
Number Of Channels 2
Clock Frequency 635 Hz
CAS Latency 9
RAS To CAS Delay 9
RAS Precharge 9
TRAS 24
TRC 33
Command Rate 1
CPUID SPD Info
Number Of SPD Modules 0
CPUID SPD Modules
CPUID Motherboard
BIOS Version V18.1
BIOS Date 11.3.2011
Mainboard Vendor MSI
Mainboard Model 890FXA-GD65 (MS-7640)
System Manufacturer MSI
System Product Name MS-7640
System Version 3
System Serial Number To Be Filled By O.E.M.
System UUID 00000000-00000000-00006C62-6D3AA53B
North Bridge Vendor ATI
North Bridge Model ID5A11
North Bridge Revision 2
South Bridge Vendor ATI
South Bridge Model SB750
South Bridge Revision 40
NVAPI Info
ADL Info
ADL Adapters
ADL Adapter
Adapter Index 0
Bus Number 4
Device Number 0
Function Number 0
Adapter Name AMD Radeon HD 7800 Series
Adapter ID 15556672
Engine Clock 286 Hz
Memory Clock 143 Hz
Core Voltage 825
Activity Percent 0
PCIE Speed 2500
PCIE Lanes 16
Temperature 27000
Fan Speed Info Flags 15
Fan Speed Info Flags supports percent read, supports percent write, supports RPM read, supports RPM write
Fan Speed Min Percent 0
Fan Speed Max Percent 100
Fan Speed Min RPM 1000
Fan Speed Max RPM 4200
Fan Speed Flags
Fan Speed Type RPM
Fan Speed 1145
MVPU Status 0
MVPU Adapters
WMI Info
Win32VideoControllers
Caption AMD Radeon HD 7800 Series
PNPDeviceID PCI\VEN_1002&DEV_6819&SUBSYS_043A1043&REV_00\4&30701AFE&0&0010
AdapterRAM -2147483648 B
DriverVersion 15.300.1025.1001
Win32DiskDrives
Win32DiskDrive
Caption WDC WD10EZRX-00A8LB0 ATA Device
Manufacturer (Standardn diskov jednotky)
Model WDC WD10EZRX-00A8LB0 ATA Device
FirmwareRevision 01.01A01
SerialNumber 2020202057202d444d5731433555363432303038
InterfaceType IDE
PNPDeviceID IDE\DISKWDC_WD10EZRX-00A8LB0____________________01.01A01\5&19D8E1B3&0&0.0.0
DeviceID \\.\PHYSICALDRIVE0
MediaType Fixed hard disk media
Status OK
Size 932 GB
Signature 2166222938
BytesPerSector 512
Win32CDROMDrives
Win32CDROMDrive
Caption ASUS DRW-22B2ST ATA Device
Manufacturer (Standardn jednotky CD-ROM)
PNPDeviceID IDE\CDROMASUS_DRW-22B2ST_________________________1.00____\5&360A0425&0&0.0.0
MediaType DVD Writer
MfrAssignedRevisionLevel 1
Status OK
MediaLoaded NEPRAVDA
pomalé vypnutí pc
Re: pomalé vypnutí pc
Restart proběhne normálně?
Spusť příkazový řádek a v něm zadej příkaz "shutdown -s -t 00". Jak rychle se vypne?
restart trvá kračí dobu a po zadaní příkazu se vypne o maličko rychlejiITCrowd píše:Restart proběhne normálně?
- 10 Odpovědi
- 14383 Zobrazení
- 28 Odpovědi
- 28860 Zobrazení
Poslední příspěvek od Dejv28
- 8499 Zobrazení
- 10223 Zobrazení
- 4 Odpovědi
- 8186 Zobrazení
Poslední příspěvek od PARKR
