nevíte někdo kde je zakopanej pes? Nejde mi vypalovat na DVD+RW Verbatim 1-4x. NA DVD+/-R Imation je vše OK. Další info viz. text dole.
Díky všem za případné rady.
Nero hlásí toto:
1A20-920E-0012-2525-1282-4753*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26.10.2004 16:35:32
Nero Version: 6.6.0.15
Internal Version: 6, 6, 0, 15j
(Nero Express)
Recorder: <HL-DT-ST DVDRAM GSA-H12N>Version: UL02 - HA 4 TA 0 - 6.6.0.15
Adapter driver: <JRAID> HA 4
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <WE5810L QIO061Z >Version: 1.0 - HA 5 TA 0 - 6.6.0.15
Adapter driver: <au7dzqvp> HA 5
=== Scsi-Device-Map ===
DiskPeripheral : SAMSUNG HD300LJ atapi Port 0 ID 0 DMA: On
CdRomPeripheral : HL-DT-STDVDRAM GSA-H12N UL02 JRAID Port 4 ID 0 DMA: Off
CdRomPeripheral : WE5810L QIO061Z 1.0 au7dzqvp Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GSA-H12N D: CDRom0
WE5810L QIO061Z G: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1022MB (1046956kB)
Free physical memory: 563MB (576620kB)
Memory in use : 44 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.3.2007
ISO compilation
0:00:19 #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
0:00:19 #2 Text 0 File Reader.cpp, Line 127
Reader running
0:00:19 #3 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
0:00:19 #4 Text 0 File Burncd.cpp, Line 3231
Turn on Disc-At-Once, using DVD media
0:00:20 #5 Text 0 File DlgWaitCD.cpp, Line 269
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 30591 ( 6:47.66, 59MB)
0:00:20 #6 Text 0 File DlgWaitCD.cpp, Line 281
Write in overburning mode: NO
0:00:20 #7 Text 0 File DlgWaitCD.cpp, Line 2477
Recorder: HL-DT-ST DVDRAM GSA-H12N, Media type: DVD+RW
Disc Manufacturer ID: MKM, Media Type ID: A02, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
0:00:20 #8 Text 0 File DlgWaitCD.cpp, Line 447
>>> Protocol of DlgWaitCD activities: <<<
0:00:20 #9 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 30592 (30592) = #30592/6:47.67
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 30592 blocks [HL-DT-ST DVDRAM GSA-H12N]
0:00:20 #10 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [HL-DT-ST DVDRAM GSA-H12N] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 62652416, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
30592 | lead-out | 1 | 0x41 | 0x00
0:00:20 #11 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
0:00:20 #12 Text 0 File Burncd.cpp, Line 4116
Cache writing successful.
0:00:20 #13 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
0:00:20 #14 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5 540 KB/s)
0:00:20 #15 Text 0 File ThreadedTransferInterface.cpp, Line 2644
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
0:00:20 #16 Text 0 File Cdrdrv.cpp, Line 8823
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 2
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Disc Manufacturer ID: MKM.....
Media type ID: A02
Number of Physical format information bytes in use in ADIP up to byte 63: 57
Media Specific [16..63]:
00 00 01 4D 4B 4D 00 00 - 00 00 00 41 30 32 00 39 ...MKM.....A02.9
23 00 94 79 64 02 20 00 - 9C 7A 6C 02 20 00 9A 7B #..yd....zl....{
68 02 20 12 12 10 E0 00 - F0 00 00 00 00 00 00 00 h...............
0:00:20 #17 Phase 98 File dlgbrnst.cpp, Line 1832
Start formatting disc before burning
0:00:20 #18 SCSI -1065 File Cdrdrv.cpp, Line 1183
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x03E66000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x20
Sense Qual: 0x00
CDB Data: 0x04 0x11 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x24 0x00 0x00 0x0F 0x20 0x00
0:00:20 #19 Phase 101 File dlgbrnst.cpp, Line 1832
Formatting disc failed
0:00:20 #20 Text 0 File DVDPlusRW.cpp, Line 663
Start write address at LBA 0
DVD high compatibility mode: Yes
0:00:20 #21 CDR -1065 File ThreadedTransferInterface.cpp, Line 1763
Invalid command
0:00:20 #22 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1763
Could not perform start of Disc-at-once
0:00:20 #23 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5 540 KB/s)
Existing drivers:
File 'Drivers\jraid.sys': Ver=1.14.00.00 built by: WinDDK, size=41728 bytes, created 20.7.2006 14:39:24 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Burn process failed (vyřešeno)
René
- nováček
Naposledy upravil(a) René dne 03 bře 2007 11:40, celkem upraveno 1 x.
Nero se někdy splaší a pomůže jej odinstalovat a znovu nainstalovat. Nejlépe při odpojení od sítě a zastavení rezidentního štítu antiviru. Pak nezapomeň restartovat počítač a opět jej připojit k síti.
- James_Radlle
- Level 3.5
- El Diablo
- Elite Level 11.5
Vyzkoušej jinou verzi.
René
- nováček
Pes byl zakopanej pod ovladači základní desky. Různé nastavení a přeinstalace Nera až na verzi 7.7.5.1 nepomohlo. Potom jsem někde na netu našel totožný problém ale s jinou vypalovačkou a s deskou Gigabite( jako mám já) a radili tam že je třeba přeinstalovat stata2 raid ovladače.
Tak jsem si je stáhnul, přeinstaloval a vše je OK!
Tímto děkuji všem zúčastněným za snahu.
- 4 Odpovědi
- 6439 Zobrazení
Poslední příspěvek od byron
