90-100% využití procesoru, kde jiní mají 50-60%, už jsem bezradný, prosím pomoc
Azmir
Re: 90-100% využití procesoru, kde jiní mají 50-60%, už jsem bezradný, prosím pomoc
Příspěvek od Azmir »
petr22: takže kamarád se stejnou i5 a 1070 nepotřebuje jiný procesor, další se stejnou i5 a 1050 taky nepotřebuje jiný procesor ale já potřebuju?
behavioralista: procesor je od toho aby byl vytížen na 100% a hra jela na 10 fps a byla nehratelná, to jsem se zas dozvěděl novinku :D
takže zatím stále žádné rady, zkusím to znova, nějaké tipy čím to projet, program jaký zkusit, test jaký udělat, screen který by vám pomohl, co ještě zkusit změnit, nastavit, prosil bych konstruktivní řešení, řekněme že pubg za to nemůže, kde by jste hledali a co byste zkusili? ten můj wattman je v pořádku dle vás? děkuji za doufám konstruktivní odpovědi :)
Je to marny, je to marny, je to marny.
Oficialni forum:
"Upgrade your CPU. My I5 was struggling and it had similar stats."
"my I7-2600(old school) only go's to a maximum of around 40-50%, usually it sits around the high 30% and the in-game fps is great. it seems hyper threading really does help in this game as when i had an I5 it was also maxed out most of the time when playing PUBG. i dont understand how some people with more modern I7's get 100% usage, you would of thought that it would be the older I7's experiencing this but that is not the case for everyone it seems. "
"I have a problem with my cpu usage with PUBG.
He use between 70-90% of my cpu.
I have some very fps with all graphics in very low."
"If I was you, I would increase my total memory to 16 gigabytes. Best suggestion I can give at this time. And of course, remember to set your nvidia profile correctly for the game. -Make sure "Power managment mode" is set to Maximum, and not Optimal. This makes the GPU use full power ingame."
"I recently upgraded from a core i5 2500k to a core i7 7700k. My CPU usage on the Core i5 was around 90% in-game consistently. On the Core i7 it is around 30%. I upgraded the motherboard and RAM (but still have 16GB), but all my other components are the same. I don't lend much credence to the theory that your processor running at 90% is a 'good' thing. I can speak from experience here. My game runs much better with my CPU usage running at 30% then it did when it was running at 90%. Sure, there are a lot of other factors to consider, but this game is very CPU dependent, and being at 90% is a warning sign IMO. "
Problem neni tvuj pocitac, ale hra kterou programovala banda opic.
Jediny zpusob reseni, na ktery prisli na oficialnim foru, je vykonnejsi procesor, I5-7700 nebo nejakou I7.
Azmir
je to marný, protože jsem ti jasně napsal, že lidi s kterýma hraju mají stejný procesor, jeden 1050 což je slabší grafika a jeden 1070 což je mnohem výkonější grafika, oba mají stálé fps, žádné dropy, žádné lagy, žádné sekaní, CPU jim jede na 40-60%, oboum, ten s 1050 prý nejde pod 60 fps, ten s 1070 nejde pod 80-90 fps, já jsem výkonostně mezi nima ale na nové mapě mám 10 fps?
pc bylo skládáno v CZC a já v biosu nic nenastavoval, jenom nainstaloval winy, nemůže být něco nenastavené nebo špatně nastavené v biosu??
Tak je to jasny - pozvi si domu proutkare, at ti vybere vhodne umisteni pro PC.
Ale abys nerekl, dej sem screen z CPU-Z, at vidime, zda je CPU spravne detekovan.
Stalor
Příspěvek od Stalor »
Chtel jsem se te jen zeptat, kdyz mas vyuziti CPU 90-100%, jak mas zatizene GPU?
Mam rx 480 8G GPU a k tomu ryzen 1600x 4 GHz OC. Fps dropy nemam. Nicmene, CPU jede nejakych 70% a GPU na 100% (v mem pripade bude throttling na GPU).
Napada me mozna jen jedna vec, zkontrolovat jestli mas zaple turbo u CPU v biosu, pripade jestli neni manualne nastaveno aby opravdu mel CPU jen TDP 65W. Jsou to dve veci ktere by mohly mit vliv na vykon.
Zatizeni GPU je videt na tom prvnim screenshotu.
Ryzen 1600x je vice nez 2x vykonnejsi nez I5-7400 a ma 6 jader, ne jen 4.
A Ryzen 1600x je zatizeny na 70%.
Na kolik asi bude zatizeny procesor, ktery ma jen 50% vykonu toho Ryzenu ?
MRC
Příspěvek od MRC »
Mě spíš zaráží fakt v tom, že ti dva se stálými fps mají invidii, zatímco ty amd (nic proti tomu, problém zde být nemusí).
Windows jsi už reinstaloval ?
A zkusil jsi si komplet prohrabat nastavení ? Z jiných her mám zkušenosti, že tam byly možnosti omezující výkon, a to značným způsobem.
Taky bych navýšil ramku, ikdyž s PUBG nemám zkušenosti, myslím si že na neoptimalizovanou hru je 8GB málo, nehledě na fakt, že dualchanel by mohl pár fps přidat.
Karl8
Příspěvek od Karl8 »
MRC píše: Taky bych navýšil ramku, ikdyž s PUBG nemám zkušenosti, myslím si že na neoptimalizovanou hru je 8GB málo, nehledě na fakt, že dualchanel by mohl pár fps přidat.
asi tak, single channel a ta shit frekvence tomu rozhodně nepřídávaj, schválně si zkus pučit od jednoho z těch kamarádů RAM, asi 2x8 s nějakou normální frekvencí mít budou, tak zkus co ti to provede s FPS
casperdeluxe
Příspěvek od casperdeluxe »
Kamoš má 2 PC. Na jednom (Phenom II X4 965, 16RAM a GTX1060 6G) to jede v pohodě. Na druhým (Nějaký FX 4jádro, 8RAM a RX380X) se to chová tak jak píšeš. Zdá se, že problém je v RAMkách. Chce to 16
Phanteks Enthoo Evolv X, Intel i7 12700KF, G.Skill TridentZ 4x8 4000 CL18, Asus ROG STRIX Z690-A Asus TUF RTX 3070, Phanteks Revolt X 1200, EKWB Custom loop, Samsung 970 PRO 1TB, Gigabyte Aorus Gen4 500GB, DELL Alienware AW3420DW, Corsair K95 Platinum, Steelseries Rival 600, Sennheiser GSP600, Sennheiser GSX1000
To jsem rikal taky, ze 8 GB je malo.
Tazatel ale akceptuje jen nejake zazracne reseni bez zmeny hw stavajiciho PC.
S cimz bohuzel nemohu slouzit.
Azmir
Here are the PLAYERUNKNOWN'S BATTLEGROUNDS system requirements (minimum)
CPU: Intel Core i3 4340, AMD FX-6300
CPU SPEED: Info
RAM: 6 GB
OS: 64-Bit Windows 7, Windows 8.1, Windows 10
VIDEO CARD: nVidia GeForce GTX 660 2GB, AMD Radeon HD 7850 2GB
FREE DISK SPACE: 30 GB
jelikož bohatě splnuju minimální požadavky, tak myslím že bych měl jet více než na 10 fps, sekat se lagovat, střílet fullouto jako singl :)
proč upgradovat ram když si pc téměř nikdy nevezme víc jak 6,5/8 ? proš ostatním co jsem se bavil s 8 gb ram to jede v pohodě?
Nehledám zázračné řešení, jenom nikdo z vás tu hru nehrál, protože kdokoliv kdo jo, at už má jakoukoliv sestavu tak mi okamžitě řekne že to normální není.
SpaceExplo
Příspěvek od SpaceExplo »
Zkusim to jeste jednou, ale je to naposledy:
- 1. stahni a zkus chvili hrat Fortnite
- 2. stahni a pust Unigine Heaven https://benchmark.unigine.com/heaven
Podel se o vysledky a pripadne screenshoty.
Pozor: neumim cist myslenky (ani na dalku, ani po internetu) a nectu mezi radky.
  • Pomoc pri upgrade procesoru
    od filipo88 » » v Rady s výběrem hw a sestavením PC
    6843 Zobrazení
    15 Odpovědi
    60248 Zobrazení
    Poslední příspěvek od MoA285
  • Mají cenu IT kurzy ? Máte zkušenost ?
    od TeIkQ » » v Vše ostatní (z oblasti IT)
    20 Odpovědi
    39247 Zobrazení
    Poslední příspěvek od domitea
  • Staré routery značky Zyxel mají kritickou zranitelnost
    od postcd » » v Vše ostatní (bezp)
    14950 Zobrazení
    Poslední příspěvek od postcd
  • Prosím o pomoc - Sestava na hry do 20tis
    od jxdm97 » » v Rady s výběrem hw a sestavením PC
    3360 Zobrazení
