DLOUHE VYPINANI PC A PRI CINNOSTI KOUSANI XP (vyřešeno)
Zdravim
mam dva problemy a prosim o pomoc:
1, pri ukoncovani xp at restartovani nebo vypnuti to trva asi pet minut (nabeh pc je pri tom velmi rychly otazka par sekund)
2, pri slozitejsich operacich nejcasteji pri prehravani videa se pc zasekne na cca deset sekund a pak zase par sekund video bezi a pak se zase sekne
prikladam vypis
Logfile of HijackThis v1.99.1
Scan saved at 12:26:28, on 21.5.2006
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
C:\WINDOWS\system32\wscntfy.exe
C:\Program Files\Mozilla Firefox\firefox.exe
E:\Programs\hijackthis\HijackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www1.warforum.cz/
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Odkazy
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0 CE\Reader\ActiveX\AcroIEHelper.dll
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupda ... 8069003465
O20 - Winlogon Notify: WgaLogon - C:\WINDOWS\SYSTEM32\WgaLogon.dll
O23 - Service: AVG7 Alert Manager Server (Avg7Alrt) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgamsvr.exe
O23 - Service: AVG7 Update Service (Avg7UpdSvc) - GRISOFT, s.r.o. - C:\PROGRA~1\Grisoft\AVG7\avgupsvc.exe
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
O23 - Service: TuneUp WinStyler Theme Service (TUWinStylerThemeSvc) - TuneUp Software GmbH - C:\Program Files\TuneUp Utilities 2006\WinStylerThemeSvc.exe
dekuji
prikladam vypis
Running processes:
dekuji
- mijaja
- Tvůrce článků
Proko, tohle máš novou instalaci na tom novém disku? Vždyť v tom kompu nic nemáš. Koukni se do nastavení AVG - nemáš nastavenu kontrolu disků či disketovky při vypínání? To bývá většinou příčinou zpožďování vypínání. Dále Automatické instalace mnohdy zdržují vypínání kompu - a po reinstalu se jich stahuje dost.
zkus taky na zkoušku přepnout služby Alcoholu a TuneUpu na ruční spouštění - to můžeš kdykoliv vrátit.
(jinak mě berou čerti, když vidím, že na nové instalaci ještě nemáš firewall a antispyware a už rajtuješ po netu!
To je nova instalace na novem disku.
nemuzu nikde najit:
Taky musim rict ze takhle presne spatne se choval ten disk po tech 380 tj, -sekani xp hlavne pri prehravani videa a dlouhe vypinani xp !!!
Takze mne napada jestli nemuze byt poskozen nejaky jiny hardware
nemuzu nikde najit:
Nastavení služeb najdeš v Ovládacích panelech/Nástroje pro správu/Služby.
S AVG ti asi nejlépe poradí mijaja, já používám Noda.
Edit: Zkusil jsi tu mojí předchozí radu - odpojit internet, ukončit AVG a pak vypnout PC? Projevil se nějaký rozdíl?
Znáte pravidla?
Tipy a triky ve Windows XP
- mijaja
- Tvůrce článků
Taky nemám AVG, ale mám ho v práci, tak bych ti napsal až zítra. Ale Jestli máš manuál, tak na stránce 20 se píše:
Tohle značí, že jakákoliv aplikace, která vykonala nějakou operaci a je ukládána z RAMky zpět na disk je před uložením a uzavřením zkontrolována. To samozřejmě zpomaluje systém za běhu celkem neznatelně(ale přece), protože fluktuace aplikací v RAMce a Virtuální paměti není tak velká a je časově rozložená (vyjma her, nebo jiných náročných programů). Při vypínání naopak všechny běžící soubory (koneckonců vidíš je v Taskmanageru - a to ještě zdaleka nejsou všechny) jsou ukončovány a kontrolovány najednou. Proto ta prodleva.
Zkus podle obrázku zrušit zatržení.
Pokud to ale zatrženo nemáš, bude problém v něčem jiném, než v AVG. Přece jen nevíme, jak se zachovala tvá deska nebo paměti po zásahu 380V.
5.2 Kontrola souborů při zavírání
Doporučujeme aktivovat funkci Kontrola souborů při zavírání v komponentě Rezidentní štít AVG.
Kontrola souborů při zavíraní zajišťuje, že Antivirový systém AVG testuje aktivní objekty (např. aplikace,
dokumenty, …) nejen při jejich spuštění/otevření, ale také při zavírání. Tato funkčnost pomáhá chránit Váš
počítač před sofistikovanými viry.
Kontrolu souborů při zavírání můžete aktivovat v rámci komponenty Rezidentní štít AVG v
aplikaci AVG Control Center.
Podrobné informace o Kontrole souborů při zavírání najdete v kapitole 9.6 – Komponenty ovládané z AVG
Control Center/ Rezidentní štít AVG.
to mikel: s avg jsem to zkusil jak jsi psal a zadny rozdil
to mijaja: v avg jsem vypnul volbu dle tveho navodu -
to mijaja: puvodne jsem myslel ze je problem s novym diskem ale podle mikela je v poradku ( obrazky jsou v tematu stav seagate)
Ale desim se toho ze to vypada na problem s deskou aliaz pameti !!!
- mijaja
- Tvůrce článků
Nejlepší by asi bylo vyzkoušet ten disk v jiném kompu. Jestli bude také tak hlučný - je to jasně na reklamačku. Jestli bude tichý, tak bude problém v tvém kompu. Sice netuším, jak by se mohla deska nebo paměti podílet na hlučnosti disku - snad jen, že by nějak přerušovala přívody napájení (jen teoretizuju) nebo by byl nějak narušený přenos dat a opakované požadavky systému by nutily disk neustále roztáčet. No abych nevypotil ještě více blbostí - zkus ten disk někde jinde.
Na co máš nainstalovaný Instant Messenger? Je to opravdu tak velký přínos? Ta knihovna, co ti žere systém patří k němu. Tady podle databáze existuje 7 variant tohoto souboru hkidle.dll. Teď záleží, kterou z nich máš v kompu. Možná se to liší zdrojem, ze kterého jsi stahoval IM.
POZOR !!!
vazeni panove mikel a mijaja - dekuji vam velmi za pomoc reseni problemu
problem vyresen - vse zpusobuje instant mesenger ktery totalne zahltil system - po nespusteni po startu xp probehlo nasledne vypnuti pc okamzite
Jeste bych na vas mel ale momentalne posledni dotaz a to kdyz v task manageru vypnu polozky:
alcohol 120
avg alert manager
avg update service
stane se neco duleziteho pro chod xp?
diky a pekny vecer
alcohol 120
avg alert manager
avg update service
diky a pekny vecer
- mijaja
- Tvůrce článků
Když vypneš v Taskmanageru Alcohol 120- tak systému jen prospěješ, protože pokud jej nepotřebuješ k momentální práci, tak nemusí být vůbec spuštěný. Stejně se ti při dalším restartu opět zapne - musel bys jej totiž ve Službách zastavit a v registrech vypnout jeho volání.
U AVGčka už raději nevypínej nic. Jestliže jsi to vyřešil uninstalem IM, tak by provoz AVG už neměl mít takový vliv na chod systému. Maximálně bys mohl vypnout AVG update service - ale vždy až poté, co update pro ten den proběhne. V tom případě si nastav jeho aktualizaci ihned po spuštění kompu. Pak jej můžeš v Taskmanageru stopnout. Ale nikde jinde - musí se ti na druhý den zase spustit se systémem.
Já bych ti doporučil Mirandu, kterou sám používám. Více se o ní můžeš dočíst tady.
Znáte pravidla?
- 8 Odpovědi
- 7975 Zobrazení
Poslední příspěvek od PARKR
- 9111 Zobrazení
- 8400 Zobrazení
- 19 Odpovědi
- 28110 Zobrazení
