Pomale otvirani souboru
Toto mi nasel MWAV:
Object "cydoor Spyware/Adware" found in File System! Action Taken: No Action Taken.
Object "media access Spyware/Adware" found in File System! Action Taken: No Action Taken.
Object "newdotnet Spyware/Adware" found in File System! Action Taken: No Action Taken.
Object "media tickets Spyware/Adware" found in File System! Action Taken: No Action Taken.
Object "coolwebsearch Spyware/Adware" found in File System! Action Taken: No Action Taken.
Object "tencent qq Spyware/Adware" found in File System! Action Taken: No Action Taken.
Object "peopleonpage Spyware/Adware" found in File System! Action Taken: No Action Taken.
Object "abetterinternet Spyware/Adware" found in File System! Action Taken: No Action Taken.
File C:\WINDOWS\system32\.pif infected by "Trojan-Downloader.BAT.Ftp.y" Virus! Action Taken: No Action Taken.
Offending Key found: HKLM\Software\cydoor !!!
Sat May 06 09:47:47 2006 => Object "cydoor Spyware/Adware" found in File System! Action Taken: No Action Taken.
Sat May 06 09:47:47 2006 => Offending Key found: HKCU\Software\cydoor !!!
Sat May 06 09:47:47 2006 => Offending Key found: HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\StartupReg\cydoor !!!
Sat May 06 09:47:47 2006 => Offending Key found: HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\StartupReg\media gateway !!!
Sat May 06 09:47:47 2006 => Object "media access Spyware/Adware" found in File System! Action Taken: No Action Taken.
Sat May 06 09:47:47 2006 => Offending Key found: HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\StartupReg\new.net startup !!!
Sat May 06 09:47:47 2006 => Object "newdotnet Spyware/Adware" found in File System! Action Taken: No Action Taken.
Sat May 06 09:47:48 2006 => Offending file found: C:\WINDOWS\mtu.bat
Sat May 06 09:47:48 2006 => System found infected with media tickets Spyware/Adware (mtu.bat)! Action taken: No Action Taken.
Sat May 06 09:47:49 2006 => Offending file found: C:\WINDOWS\system32\cd_clint.dll
Sat May 06 09:47:49 2006 => System found infected with cydoor Spyware/Adware (cd_clint.dll)! Action taken: No Action Taken.
Sat May 06 09:47:49 2006 => Offending file found: C:\DOCUME~1\VYKOVS~1\LOCALS~1\Temp\cd_clint.dll
Sat May 06 09:47:54 2006 => Offending file found: C:\Documents and Settings\Plocha\dan\et\docs\help\manual\html\top.html
Sat May 06 09:47:54 2006 => System found infected with whenu.sidefinder Spyware/Adware (top.html)! Action taken: No Action Taken.
Sat May 06 09:47:55 2006 => Offending Folder found: C:\Documents and Settings\Plocha\dan\programy\anydvd\manual\se
Sat May 06 09:47:55 2006 => Object "coolwebsearch Spyware/Adware" found in File System! Action Taken: No Action Taken.
Sat May 06 09:47:55 2006 => Offending file found: C:\Documents and Settings\Plocha\dan\programy\bsplayer\skins\base\skin.ini
Sat May 06 09:47:55 2006 => System found infected with tencent qq Spyware/Adware (skin.ini)! Action taken: No Action Taken.
Sat May 06 09:47:55 2006 => Offending file found: C:\Documents and Settings\Plocha\dan\programy\clonecd\graphics\skin.ini
Sat May 06 09:47:55 2006 => Offending file found: C:\Documents and Settings\Plocha\dan\programy\winavi video converter\skins\0\skin.ini
Sat May 06 09:47:55 2006 => Offending file found: C:\Documents and Settings\Plocha\dan\stunts\stunts\data\load.exe
Sat May 06 09:47:55 2006 => System found infected with peopleonpage Spyware/Adware (load.exe)! Action taken: No Action Taken.
Sat May 06 09:48:02 2006 => Offending file found: C:\Documents and Settings\Local Settings\temp\cd_clint.dll
Sat May 06 09:48:02 2006 => System found infected with cydoor Spyware/Adware (cd_clint.dll)! Action taken: No Action Taken.
Sat May 06 09:48:03 2006 => Offending file found: C:\Documents and Settings\Local Settings\temp\nsz2a8.tmp\banner.dll
Sat May 06 09:48:03 2006 => System found infected with abetterinternet Spyware/Adware (banner.dll)! Action taken: No Action Taken.
Sat May 06 09:48:03 2006 => Offending file found: C:\Documents and Settings\Local Settings\temp\_bspst$_\skin.ini
Sat May 06 09:48:03 2006 => System found infected with tencent qq Spyware/Adware (skin.ini)!
Sat May 06 09:53:41 2006 => File C:\WINDOWS\system32\smrss.exe infected by "Net-Worm.Win32.Dedler.o" Virus! Action Taken: No Action Taken.
- mijaja
- Tvůrce článků
No Dane, v první řadě si nainstaluj firewall - v linku Důležité ... mám dobrý výběr.
Ten výběr z logu MWAVu je celý? Jestli ano:
Takže tyhle soubory by měly z disku pryč:
C:\WINDOWS\mtu.bat
C:\Documents and Settings\Plocha\dan\programy\bsplayer\skins\base\skin.ini - šmejd provázející nejnovější verze BSPlayeru
C:\WINDOWS\system32\smrss.exe - Net-Worm.Win32.Dedler.o - to je ten nej...šmejd ze všech co máš v kompu.
Ty červené soubory musíš všechny smazat! Musíš mít nastaveno v Možnostech složky zobrazování skrytých a systémových souborů. Pokud některý nenajdeš, tak napiš který. Až to budeš mít, otevři si editor registrů a najdi tyhle klíče a smaž je taky ( jen ty klíče - ne celé větve!)
Až to budeš mít stáhni si Ccleaner - link s návodem mám v podpisu - a pořádně vyčisti celý komp i registry. Aspoň dvakrát po sobě, aby tam nezůstal jediný šmejdík.
C:\WINDOWS\mtu.bat
- 4 Odpovědi
- 8193 Zobrazení
Poslední příspěvek od PARKR
- 10 Odpovědi
- 12163 Zobrazení
- 9679 Zobrazení
Poslední příspěvek od L.L
