lenovo vs. hp notebooky
mato37
Příspěvek od mato37 »
Zajimal by mne Vas nazor na tyto dve znacky notebooku, konkretne na tyto nasledujici dva typy.
Mezi nimi jse totiz rozhoduju, ktery z nich by ste si vybrali pokud by Vasim zamerem bylo pouzivani
Oracle - skratka pro praci s databazemi. Diky
Notebook Lenovo N100 T2250-1.73/15,4WXGA/1GB/80/DVDRW/WLAN/BT/CR/Vista H
40-32LV.TY0FGVJ cena ... 25.701+dph
Popis produktu:
Lenovo 3000 N100 CoreDuo, T2250 (1.73GHz) ,1GB (2x512), 80GB/5400rpm SATA, 15.4" WXGA TFT(1280x800) VibrantView , Intel Media Accelerator 950 up 128MB, DVD-RW Multiburner Dual Layer, Modem, Ethernet, Lenovo 11a/b/g, Bluetooth, IEEE 1394, S-video out, 4x USB, 4-in-1 Multi-card Reader (SD/MMC/MS/XD), Vista H32 (anglický SW , Sk klávesnica)
Architecture
Bus type/architecture: PCI/PCI Express
Bays: Fixed Media Bay
Indicator light: Yes
Form Factor: Notebook
Display
External display supported: Yes
Simultaneous external display: Yes
Screen type description: WXGA VibrantView TFT
Viewable image size (diagonal): 15.4inches
Screen illumination: Backlit
Max colors or grey shades: 16777216
Max resolution: 1280x800
Graphics Subsystem
Video RAM std/max: -- / --
Graphics chipset: Intel Graphics Media Accelerator 950
Graphics type: --
Video RAM type: DVMT
Max resolution (with max video RAM): 2048x1536 16777216 colors
Max colors (with max video RAM): 16777216
Graphics bus interface: PCI Express
Processor
BIOS type:
Processor manufacturer: Intel
Processor (CPU): Intel® Core Duo processor T2250
Processor internal clock speed2: 1.73GHz
Front Side Bus: 533MHz
Memory
Memory (RAM) std/max: 2x512MB / 2GB
RAM slots total: 2 SODIMM
RAM slots available: 0 SODIMM
RAM speed supported: 667MHz
RAM type: PC2-5300 DDR2 SDRAM
Hard Disk
Hard disk size1: 80GB
Hard disk type: Serial ATA
Optical device
Floppy diskette size: --
Optical device: DVD Recordable (Dual Layer)
Optical device speed8: 24X Max
Device interface: PATA
Audio
Integrated speakers: 2
Speaker power rating: 1 Watts
Volume control buttons:
Speaker Quantity: 2 (Internal Speaker)
Audio chipset: Realtek High Definition Audio
Audio data width: 24-bit
Communications
Fax/modem: 56K V.92 designed modem
Fax/modem speeds: 56Kbps data/14.4Kbps fax
Infrared port: No
Infrared port speed: --
Wireless standard: Intel 3945 a/b/g
Network card: 10/100 Ethernet
Network interface: Ethernet-Integrated
Accessories
A/C adapter:
Worldwide A/C compatibility: Yes
Port replicator: None
Standard Features
Pointing device type: Industry Standard Touchpad
Keyboard type: Full size
Keyboard light:
Power Management 5
Heat emissions: 65W
Sound emissions: 40dB
Battery life - min/max: --
Battery type(s): 6 Cell Lithium-Ion
Charge time - on/off: 4.0Hrs / 3.0Hrs
Expansion Options
Plug and play support: Yes
Slots total (free) and type: PCI/PCI Express
Parallel port type:
Ports: 4-in-1 Multi-card Reader (SD/MMC/MS/XD)
4 USB 2.0
S-Video out
RJ-45
RJ-11
IEEE 1394
Headphone / Line out
External Microphone/Line-In
External Display (VGA)
Weight & Dimensions 6
Weight: 2.8Kg
Height: 38.6mm
Width: 360.1mm
Depth: 266.7mm
Travel weight: 2.62Kgs
Security
Security features: Security Slot
Power on password
Norton Internet Security
Hard disk drive password
Limited warranty 3
Type of service: Customer Carry-in
Warranty period: One year parts and labor (system battery: one year)
Software
Supported operating systems: Genuine Windows XP Home Edition
Genuine Windows XP Professional
Windows Vista Business 32-bit
Windows Vista Home Basic 32-bit
Windows Vista Home Premium 32-bit
Communication/networking:
Device drivers/utilities: Norton Internet Security (OEM Edition) with 90 days of virus definition updates, PC-Doctor diagnostics, Sun JRE, ThinkVantage Access Connections, ThinkVantage Client Security Solution, ThinkVantage Rescue and Recovery
Multimedia applications: InterVideo WinDVD Creator, InterVideo WinDVD, Intervideo InstantON, Lenovo 3000 System Update, Lenovo Care, Lenovo Password Manager, Lotus Notes Stand-alone Client (license), Lotus Smartsuite millennium edition (license), Roxio Digital Media Basic Edition
Productivity applications: Adobe Acrobat Reader, Corel Small Business Center featuring WordPerfect Office 12, Diskeeper Lite from Diskeeper, Google Desktop, Google Toolbar, Picasa from Google
HP notebook - Pavilion dv6309eu/CM 440/15.4WXGABV/1G/160GB/DVD±RW/WL/VHPrem
40-32HP.GF704EA cena ... 22.655+dph
Popis produktu:
HP Pavilion dv6309eu Intel Celeron M 440, 2x512MB DDR2 667MHz FSB, 160GB 5400ot/min SATA, 15.4"WXGA high definition BrightView (1280x800), Intel GMA950, DVD+/-RW SuperMulti, 1 express card/54, 3x USB 2.0, 1394, RJ-45, RJ-11, Web cam 1.3, HP Imprint Finish laminace, 2x výstup pro sluchátka, dálkové ovládání, 5-in-1, S-Video výstup, VGA výstup, mikrofon integrovaný Altec Lansing, 56K modem, 10/100 LAN, 802.11 b/g MOW, 6-buňková baterie, MS Vista Premium CZ, 35.7 x 25.7 x 2.54min/4.3max; 2.65kg, MS Works, 65W zdroj, 2 roky
petr.s
Příspěvek od petr.s »
ber HP, sám mam už třetí notes od HP a jejich kvalita je nepřekonatelná, jinak pokud ti záleží trošku i na designu tak lenovo nemá šanci, prostě HP Pavilion = Konečně osobní počítač :wink:
Notebook : HP Pavilion dv6000 2x512MB DDR2, Procesor Intel Celeron M420 1,61 GHZ, 100 GB HDD, Mobile Intel(R) 945GM Express Chipset, Windows MC Edition SP2
:alian:
Weslo
Příspěvek od Weslo »
no vzhledem k tomu že mám v práci možnost porovnávat tak bych ti doporučil spíš to IBM(lenovo)
cybernovi
ibm
Příspěvek od cybernovi »
ja se te tez priklanim k IBM, ta masivni konstrukce je lepsi nez HP
  • Laptop Lenovo LOG
    19 Odpovědi
    12784 Zobrazení
    21 Odpovědi
    19193 Zobrazení
    Poslední příspěvek od mk7605
    8784 Zobrazení
    Poslední příspěvek od SGvagon
Zpět na „Vše ostatní (hw)“
