Nejde spustit Minecraft
A vše kolem nich…
JacobPlayzCZ
Příspěvek od JacobPlayzCZ »
nevím proč, ale po nějaké době mi přestala fungovat hra Minecraft.
Normálně mi to dlouho fungovalo, ale teď se najedenou objeví 'Crash Report', když dám tlačítko 'Play'.
Zde je ten 'Crash Report':
---- Minecraft Crash Report ----
// There are four lights!
Time: 10.7.17 12:44
Description: Initializing game
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:247)
at org.lwjgl.opengl.Display.createWindow(Display.java:306)
at org.lwjgl.opengl.Display.create(Display.java:848)
at org.lwjgl.opengl.Display.create(Display.java:757)
at org.lwjgl.opengl.Display.create(Display.java:739)
at beq.ap(SourceFile:597)
at beq.an(SourceFile:433)
at beq.a(SourceFile:380)
at net.minecraft.client.main.Main.main(SourceFile:124)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Client thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.11
Operating System: Windows XP (x86) version 5.1
Java Version: 1.8.0_25, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 73407408 bytes (70 MB) / 148123648 bytes (141 MB) up to 523501568 bytes (499 MB)
JVM Flags: 6 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.11
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: Yes
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
Nevím proč, ale Javu a takové věci mám.
Vím, že to 'org.lwjgl.LWJGLException: Pixel format not accelerated' bude znamenat něco s grafikou
a vím že už se to tu řešilo, každopádně já nevím jak aktualizovat grafické ovladače.
Sice mám Windows XP ale vždy mi to na tomto počítači šlo úplně perfektně.
Prosím poraďte mi :D
flowem
Re: Nejde spustit Minecraft
Příspěvek od flowem »
Když máš Win XP, zkus spustit starší verzi Minecraftu, pak dej vědět.
LupeCZ
Příspěvek od LupeCZ »
Ahoj, tahle chyba je běžná, pokud nemáš aktualizované ovladače grafické karty - aktualizuj a pak dej vědět.
JacobPlayzCZ
flowem píše:Když máš Win XP, zkus spustit starší verzi Minecraftu, pak dej vědět.
Zkusil jsem starší verze, ale nic. Jak říkám, dřív mi to šlo perfektně bez ohledu na verzi Minecraftu.
Jo a se strašími verzemi mi to hodilo jiný error:
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 11.7.17 14:18
Minecraft: Minecraft 1.0.0
OS: Windows XP (x86) version 5.1
Java: 1.8.0_25, Oracle Corporation
VM: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
LWJGL: 2.9.0
[failed to get system properties (java.lang.RuntimeException: No OpenGL context found in the current thread.)]
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:244)
at net.minecraft.client.Minecraft.a(SourceFile:237)
at net.minecraft.client.Minecraft.run(SourceFile:644)
at java.lang.Thread.run(Thread.java:745)
--- END ERROR REPORT 9b71fe53 ----------
Ale vypadá to, že to znamená pořád to samé.
flowem píše:Ahoj, tahle chyba je běžná, pokud nemáš aktualizované ovladače grafické karty - aktualizuj a pak dej vědět.
Jo, sice to vypadá že se to tím zpraví, ale já neumím aktualizovat ovladače :D
Vavřík
Příspěvek od Vavřík »
Co máš za grafickou kartu?
Dr. House
Příspěvek od Dr. House »
Máš nejspíš přetížený notebook. Skus notebook restartovat, popřípadě pročistit nepotřebné soubory. Když hraješ minecraft, zavři si nepotřebné soubory, například prohlížeč.
LupeCZ
Jak jsem již psala, v 99% je to problém grafické karty, která nemá aktualizované ovladače. Aktualizuj
Navíc to vidíš na první pohled
Stáhni si ovladače přímo ze stránek výrobce. NIC JINÉHO TI TADY NEPOMŮŽE.
JacobPlayzCZ
Ale jak ?
Dodatečně přidáno po 1 minutě 45 vteřinách:
Dr. House píše:Máš nejspíš přetížený notebook. Skus notebook restartovat, popřípadě pročistit nepotřebné soubory. Když hraješ minecraft, zavři si nepotřebné soubory, například prohlížeč.
Zaprvé notebook nemám, a zadruhé jediné co mám zapnuto je ten crash report který mi to vždy hodí :D
Vavřík
JacobPlayzCZ píše:Ale jak ?
Napiš přesný název grafické karty.
kellne
Příspěvek od kellne »
Bad video card drivers se dá obejít. Na ploše klikni pravym a dej vlastnosti, pak úplně tu kolonku vpravo. Tam se něco nabídne na to klikni a pak tam vyskočí nové okno kde bude možnost potíže.....
klikni na to a posuň ten obdélníček na třetí z leva.
Sorry, že to nevim přesně, ale Windows XP už nepoužívám :D
RomankaBrendova
Příspěvek od RomankaBrendova »
Smaž složku .minecraft znova loadni minecraft a chyba už se nebude vyskytovat :)
    od liborek » » v Hry
    11403 Zobrazení
    Poslední příspěvek od liborek
    15959 Zobrazení
    Poslední příspěvek od sim20
    9706 Zobrazení
Zpět na „Hry“
