problem so sietou
kerubin
problem so sietou
Příspěvek od kerubin »
zdravim mam nasledovny problem internet mi v poslednej dobe pada aj 30x za den niekedy mozno aj viac ... ked mi spadne internet pozriem sa na router a vzdy mi prva kontrolka prestane blikat dsl linka ... myslim si ze je problem v linke ... volal som asi stokrat poskytovatelovi ale neuspesne nikoho na premeranie mi neposlal vzdy mi povedali ze mam to uplne v poriadku .. skusal som tri routre a na kazdom mi robi to iste ...asus niekedy ked vypadne internet uz potom nedokaze nabehnut tp link nabehne vzdy ale trva to zhruba pol minuty takze uz mam z toho strasne nervy ... tuto je log z asus routru ked mi vcera vypadol net bol by som rad keby z toho niekto nieco vedel vycitat dakujem
Kód: Vybrat vše
2018-01-01 22:20:11 WEB: Configuration changed: LogAccess_ClearLog
2018-01-01 22:23:56 WEB: User [user] logged in from [192.168.1.2] via WEB
2018-01-01 22:31:07 kernel: Link State: LAN_4 down.
2018-01-01 22:31:09 kernel: Link State: LAN_4 up.
2018-01-01 22:48:48 kernel: Link State: PVC_0 PPPoE down.
2018-01-01 22:48:48 kernel: Link State: DSL link down.
2018-01-01 22:48:48 WAN Connection: Fail to connect with some issues.
2018-01-01 22:48:48 stop_nat_rules: apply the redirect_rules!
2018-01-01 22:48:53 WAN Connection: Wan link down.
2018-01-01 22:49:02 syslog: Serial link appears to be disconnected.
2018-01-01 22:49:02 syslog: Connect time 39.4 minutes.
2018-01-01 22:49:02 syslog: Sent 16510016 bytes, received 84498263 bytes.
2018-01-01 22:49:02 syslog: LCP down.
2018-01-01 22:49:03 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 22:49:08 syslog: Connection terminated.
2018-01-01 22:49:08 syslog: Modem hangup
2018-01-01 22:49:08 syslog: LCP down.
2018-01-01 22:49:12 syslog: LCP is allowed to come up.
2018-01-01 22:49:20 WEB: User [user] logged in from [192.168.1.3] via WEB
2018-01-01 22:49:23 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 22:49:29 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 22:49:41 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 22:50:00 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 22:50:13 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 22:50:32 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 22:50:45 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 22:51:03 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 22:51:23 kernel: Detect DSL status:0x20 into INT mode!!
2018-01-01 22:51:23 kernel: Link State: DSL link up.
2018-01-01 22:51:23 WAN Connection: Wan link up.
2018-01-01 22:51:27 RFC1483/2684 bridge: Interface "nas0" created sucessfully
2018-01-01 22:51:27 RFC1483/2684 bridge: Communicating over ATM 0.1.32, encapsulation: LLC
2018-01-01 22:51:27 RFC1483/2684 bridge: Interface configured
2018-01-01 22:51:27 RFC1483/2684 bridge: RFC 1483/2684 bridge daemon started
2018-01-01 22:51:28 syslog: Initialize LCP.
2018-01-01 22:51:30 syslog: Plugin libpppoe.so loaded.
2018-01-01 22:51:30 syslog: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.5
2018-01-01 22:51:30 syslog: pppd 2.4.5 started by user, uid 0
2018-01-01 22:51:30 syslog: LCP is allowed to come up.
2018-01-01 22:51:30 syslog: PPP session is 9236
2018-01-01 22:51:30 syslog: Connected to 02:03:45:04:a3:c4 via interface nas0
2018-01-01 22:51:30 syslog: Using interface ppp0
2018-01-01 22:51:30 syslog: Connect: ppp0 <--> nas0
2018-01-01 22:51:30 syslog: PAP authentication succeeded
2018-01-01 22:51:30 dnsmasq[2805]: reading /etc/resolv.conf
2018-01-01 22:51:30 dnsmasq[2805]: using nameserver 85.237.225.250#53
2018-01-01 22:51:30 dnsmasq[2805]: using nameserver 213.151.222.34#53
2018-01-01 22:51:30 dnsmasq[2805]: ignoring nameserver 127.0.0.1 - local interface
2018-01-01 22:51:30 dnsmasq[2805]: exiting on receipt of SIGTERM
2018-01-01 22:51:30 kernel: Link State: PVC_0 logistic interface up.
2018-01-01 22:51:30 dnsmasq[28147]: started, version 2.75 cachesize 150
2018-01-01 22:51:30 dnsmasq[28147]: using nameserver 85.237.225.250#53
2018-01-01 22:51:30 dnsmasq[28147]: using nameserver 213.151.222.34#53
2018-01-01 22:51:30 dnsmasq[28147]: reading /etc/resolv.conf
2018-01-01 22:51:30 dnsmasq[28147]: ignoring nameserver 127.0.0.1 - local interface
2018-01-01 22:51:30 dnsmasq[28147]: bad address at /etc/hosts line 2
2018-01-01 22:51:30 dnsmasq[28147]: read /etc/hosts - 3 addresses
2018-01-01 22:51:32 WAN Connection: WAN was restored.
2018-01-01 22:51:32 start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
2018-01-01 22:51:32 kernel: [qos_execute(8435)]:Force Turn Off Bandwidth Limiter on Guest Network.
2018-01-01 22:51:33 kernel:
2018-01-01 22:51:33 kernel: #### wan_primary: [90.64.56.79]
2018-01-01 22:51:33 ddns update: ez-ipupdate: starting...
2018-01-01 22:51:36 ddns update: connected to ns1.asuscomm.com (103.10.4.108) on port 80.
2018-01-01 22:51:36 ddns update: asusddns_update: 0
2018-01-01 22:51:36 ddns: ddns update ok
2018-01-01 22:59:48 kernel: SRAON
2018-01-01 22:59:48 kernel: US bitswap on,DS bitswap on
2018-01-01 22:59:48 kernel: OlrON
2018-01-01 22:59:48 kernel: Set SNRM OFFSET = 2.0 db
2018-01-01 22:59:48 kernel: offset = -1024/512 / -1024/512 Set Agc Vref1 = 352 ; Vref2 = 352 ; Vref3 = 352
2018-01-01 22:59:48 kernel: AGC Vref1 = 352 ; Vref2 = 352 ; Vref3 = 352 ; Vref4 = 352
2018-01-01 22:59:48 kernel: Please reset DSL to use default setting!!!
2018-01-01 22:59:50 kernel: ANNEXBJ
2018-01-01 22:59:51 kernel: Link State: PVC_0 PPPoE down.
2018-01-01 22:59:51 kernel: Link State: DSL link down.
2018-01-01 22:59:52 WAN Connection: Wan link down.
2018-01-01 22:59:52 stop_nat_rules: apply the redirect_rules!
2018-01-01 23:00:03 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:00:23 syslog: No response to 10 echo-requests
2018-01-01 23:00:23 syslog: Serial link appears to be disconnected.
2018-01-01 23:00:23 syslog: Connect time 8.9 minutes.
2018-01-01 23:00:23 syslog: Sent 2381746 bytes, received 21847354 bytes.
2018-01-01 23:00:23 syslog: LCP down.
2018-01-01 23:00:23 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:00:29 syslog: Connection terminated.
2018-01-01 23:00:29 syslog: Modem hangup
2018-01-01 23:00:29 syslog: LCP down.
2018-01-01 23:00:29 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:00:33 syslog: LCP is allowed to come up.
2018-01-01 23:00:43 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:01:00 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:01:12 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:01:31 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:01:44 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:02:03 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:02:17 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:02:34 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:02:48 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:03:05 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:03:17 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:03:36 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:03:50 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:04:08 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:04:22 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:04:39 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:04:53 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:05:10 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:05:23 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:05:42 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:05:55 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:06:13 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:06:26 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:06:45 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:07:01 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:07:14 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:07:29 kernel: Detect DSL status:0x00 into INT mode!!
2018-01-01 23:07:40 kernel: Link State: LAN_4 down.
2018-01-01 23:07:43 kernel: Link State: LAN_4 up.
2018-01-01 23:07:43 kernel: Detect DSL status:0x08 into polling mode!!
2018-01-01 23:08:00 kernel: Detect DSL status:0x00 into INT mode!!
tu este prikladam log z ipconfig
Kód: Vybrat vše
Konfigurace protokolu IP systému Windows
Název hostitele . . . . . . . . . : kerubin-PC
Primární přípona DNS. . . . . . . :
Typ uzlu . . . . . . . . . . . . : hybridní
Povoleno směrování IP . . . . . . : Ne
WINS Proxy povoleno . . . . . . . : Ne
Adaptér sítě Ethernet Připojení k místní síti:
Přípona DNS podle připojení . . . :
Popis . . . . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Fyzická Adresa. . . . . . . . . . : 00-1B-FC-9A-2D-2A
Protokol DHCP povolen . . . . . . : Ano
Automatická konfigurace povolena : Ano
Místní IPv6 adresa v rámci propojení . . . : fe80::2558:395:2d95:595a%10(Pref
erované)
Adresa IPv4 . . . . . . . . . . . : 192.168.1.103(Preferované)
Maska podsítě . . . . . . . . . . : 255.255.255.0
Zapůjčeno . . . . . . . . . . . . : 2. ledna 2018 16:45:59
Zápůjčka vyprší . . . . . . . . . : 5. ledna 2018 18:06:18
Výchozí brána . . . . . . . . . . : 192.168.1.1
Server DHCP . . . . . . . . . . . : 192.168.1.1
IAID DHCPv6 . . . . . . . . . . : 246161931
DUID klienta DHCPv6. . . . . . . : 00-01-00-01-1E-40-8A-10-00-1B-FC-9A-2D-2A
Servery DNS . . . . . . . . . . . : 192.168.1.1
Rozhraní NetBios nad protokolem TCP/IP. . . . . . . . : Povoleno
Adaptér pro tunelové připojení isatap.{E38CACCB-1D98-4236-8F60-BEB97A500C1A}:
Stav média . . . . . . . . . . . : odpojeno
Popis . . . . . . . . . . . . . . : Microsoft ISATAP Adapter
Fyzická Adresa. . . . . . . . . . : 00-00-00-00-00-00-00-E0
Protokol DHCP povolen . . . . . . : Ne
CPUAMD RYZEN 3600 XT
GKGTX 1660
RAM32 Gb Kingston Fury 3600 Mhz RGB
MBTOMAHAWK B550 RGB
SSDSamsung 850 EVO 250GB‎
HDD1TB SEGEATE 7200 RPM
HDD 22 TB WD 7200 RPM
ZDROJCorsair AX 1200i Platinium
SKRINAMSI LIQUID 360R
Re: problem so sietou
DSL linka nemá blikať ale trvalo svietiť.Bliká iba pri výpadku alebo kým nenaviaže spojenie.Skúsil si vymeniť káblik od modemu k zásuvke DSL.Ak maš zapojený aj splitter , tak to môže robiť aj on.
kerubin
ano dsl linka neblika ale svieti len potom proste svietit prestane a uz to nefunguje klasika ... niekedy ten internet ide tri dni bez toho aby vypadol a niekedy pada tolkokrat ako som spominal vyssie... kablik som uz skusal davat druhy ale nepomohlo to vobec
GKGTX 1660
MBTOMAHAWK B550 RGB
lump1
Příspěvek od lump1 »
Pozrieť zásuvku ak je ,alebo ju aj dať vymeniť ,ale môže byť aj niekde zalomený káblik,skontrolovať všetky spoje po trase ,stáva sa to ked je zlý spoj-kontakt....
kerubin
keby bol zalomeny kablik alebo nieco take mylsim si ze by to nefungovalo vobec ale proste ako som pisal mne ten internet niekedy ide par dni uplne bez problemov a potom zrazu baaac a je problem pada to kazdu chvilu ako blbe ... mam take podozrenie ze by to mohla byt pretazena linka ... ale kazdy sused ktory ma dsl tak im to funguje uplne pez problemov... som z toho vol
GKGTX 1660
MBTOMAHAWK B550 RGB
A čo splitter ?
kerubin
splitter nepouzivam mam to len z krabicky priamo kabel do routru
GKGTX 1660
MBTOMAHAWK B550 RGB
Pokud nesvítí kontrolka DSL, pak je chyba ve spojení mezi tvým routerem a providerem. Obrať se na něj.
  • problem s ventilátorem
    33563 Zobrazení
    Poslední příspěvek od Sambala
  • Problém s internetem
    19735 Zobrazení
  • Problém s mikrofonem
    10927 Zobrazení
    13777 Zobrazení
  • Problém se spuštěním PC
    8135 Zobrazení
