Modrá smrt a nefunkční vstup mikrofonu přes USB, zřejmě SW chyba
Pravidla fóra
BSOD návod
strangereu
Příspěvek od strangereu »
Ahoj, dnes mi záhadně přestal jít vstup pro mikrofon přes USB.
Mám mikrofon od Audio Technica AT2020 s externí zvukovkou Steinberg UR12 zapojenou přes USB.
Zvukovka i mikrofon na jiném PC fungují, ale na mém to dnes přestalo jít. A následně mi vyskočila modrá smrt.
V C:// se objevil Dump s tímto textem:
DLOGFILE00010000DUMPX
Dump stack initialized at UTC: 2023/04/22 17:59:15, local time: 2023/04/22 19:59:15.
Progress 0x00000042
Elapsed BugCheck duration 00002399ms
Starting get secondary dump callbacks size.
Finish get secondary dump callbacks size.
Dump Type: 4, Total Dump Size: 1431030, Secondary Dump Size: 1298422.
Starting write of dump header.
Finish write of dump header.
Starting write of minidump data.
Finish write of minidump data.
Progress 0x00000044
Elapsed BugCheck duration 00012221ms
Starting invoking secondary dump callbacks.
Calling Win32kWPP secondary callback.
Return from Win32kWPP secondary callback.
Writing Win32kWPP secondary callback data.
Writing Win32kWPP secondary callback data done.
Calling nvlddmkm.sys secondary callback.
Return from nvlddmkm.sys secondary callback.
Writing nvlddmkm.sys secondary callback data.
Writing nvlddmkm.sys secondary callback data done.
Calling HDAudBus secondary callback.
Return from HDAudBus secondary callback.
Writing HDAudBus secondary callback data.
Writing HDAudBus secondary callback data done.
Calling \Device\DxgKrnl secondary callback.
Return from \Device\DxgKrnl secondary callback.
Writing \Device\DxgKrnl secondary callback data.
Writing \Device\DxgKrnl secondary callback data done.
Calling PortDriverStandard secondary callback.
Return from PortDriverStandard secondary callback.
Writing PortDriverStandard secondary callback data.
Writing PortDriverStandard secondary callback data done.
Calling Wdf01000 secondary callback.
Return from Wdf01000 secondary callback.
Writing Wdf01000 secondary callback data.
Writing Wdf01000 secondary callback data done.
Calling blackbox - CI secondary callback.
Return from blackbox - CI secondary callback.
Writing blackbox - CI secondary callback data.
Writing blackbox - CI secondary callback data done.
Calling blackbox - Winlogon secondary callback.
Return from blackbox - Winlogon secondary callback.
Writing blackbox - Winlogon secondary callback data.
Writing blackbox - Winlogon secondary callback data done.
Calling blackbox - NTFS secondary callback.
Return from blackbox - NTFS secondary callback.
Writing blackbox - NTFS secondary callback data.
Writing blackbox - NTFS secondary callback data done.
Calling blackbox - PNP secondary callback.
Return from blackbox - PNP secondary callback.
Writing blackbox - PNP secondary callback data.
Writing blackbox - PNP secondary callback data done.
Calling blackbox - BSD secondary callback.
Return from blackbox - BSD secondary callback.
Writing blackbox - BSD secondary callback data.
Writing blackbox - BSD secondary callback data done.
Calling secondary multi-part dump callbacks.
Starting SMBiosData multi-part secondary callback.
Finish SMBiosData multi-part secondary callback.
Starting SMBiosRegistry multi-part secondary callback.
Finish SMBiosRegistry multi-part secondary callback.
Starting SMBiosRegisters multi-part secondary callback.
Finish SMBiosRegisters multi-part secondary callback.
Starting SMBiosDataACPI multi-part secondary callback.
Finish SMBiosDataACPI multi-part secondary callback.
Starting PCI multi-part secondary callback.
Finish PCI multi-part secondary callback.
Starting Etw multi-part secondary callback.
Finish Etw multi-part secondary callback.
Finish calling secondary multi-part dump callbacks.
Progress 0x00000045
Finish invoking secondary dump callbacks.
Starting invoking dump complete callbacks.
Progress 0x00000046
Finish invoking dump complete callbacks.
Dump ended at UTC: 2023/04/22 17:59:15, local time: 2023/04/22 19:59:15.
Elapsed BugCheck duration 00012485ms
Dump completed successfully.
mmmartin
Moderátor
Re: Modrá smrt a nefunkční vstup mikrofonu přes USB, zřejmě SW chyba
Příspěvek od mmmartin »
Pokračuj podle návodu.
strangereu
1.
https://www.uschovna.cz/zasilka/JJHAYJ22PYPKVSIK-9AY/
2.
https://www.uschovna.cz/zasilka/JK5WSJI27AY6XFKN-EGU/
3.
Xeon E3 1230 3.20GHz
Kingston HyperX Beast DDR3 1600MHz (2x 8GB)
MSI - B75A-G43
GIGABYTE GeForce GTX 1050 Ti Windforce OC 4GB
Kingston A400 120GB (+1TB HDD)
SilverStone Strider Essential 80Plus ST50F-ES230 500W
4.
Nic nepřetaktováno.
5.
CrystalDiskInfo 8.17.12 (C) 2008-2022 hiyohiyo
OS : Windows 11 [10.0 Build 22000] (x64)
Date : 2023/04/23 7:38:25
+ Standardní řadič SATA AHCI [ATA]
- KINGSTON SA400S37120G
- ST1000LM024 HN-M101MBB
+ Řadič Standard NVM Express [SCSI]
- Samsung SSD 980 500GB
- Xvdd SCSI Miniport [SCSI]
(01) KINGSTON SA400S37120G : 120,0 GB [0/0/0, pd1] - ki
(02) ST1000LM024 HN-M101MBB : 1000,2 GB [1/0/0, pd1]
(03) Samsung SSD 980 500GB : 500,1 GB [2/1/0, sq] - nv
Model : KINGSTON SA400S37120G
Firmware : 03090004
Serial Number : 50026B768349196F
Disk Size : 120,0 GB (8,4/120,0/120,0/120,0)
Buffer Size : Neznámy údaj
Queue Depth : 32
# of Sectors : 234441648
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ACS-3
Minor Version : ACS-3 Revision 4
Power On Hours : 6456 hodin
Power On Count : 1506 krát
Host Reads : 9409 GB
Host Writes : 10459 GB
NAND Writes : 15495 GB
Temperature : 24 C (75 F)
Health Status : Dobrý (90 %)
Features : S.M.A.R.T., APM, NCQ, TRIM, GPL
APM Level : 0000h [OFF]
AAM Level : ----
Drive Letter : C:
01 100 100 __0 000000000000 Uncorrectable Errors
09 100 100 __0 000000001938 Power On Hours
0C 100 100 __0 0000000005E2 Power Cycles
94 100 100 __0 000000000000 Vendor Unique
95 100 100 __0 000000000000 Vendor Unique
A7 100 100 __0 000000000000 Vendor Unique
A8 100 100 __0 000000000000 SATA PHY Error Count
A9 100 100 __0 000000000092 Vendor Unique
AA 100 100 _10 00000000003B Bad Block Count
AC 100 100 __0 000000000000 Vendor Unique
AD 100 100 __0 000000000000 Erase Count
B5 100 100 __0 000000000000 Vendor Unique
B6 100 100 __0 000000000000 Vendor Unique
BB 100 100 __0 000000000000 Uncorrectable ECC Errors
C0 100 100 __0 000000000043 Specifický pro výrobce
C2 _24 _26 __0 001A00160018 Temperature
C4 100 100 __0 000000000000 Reallocation Events
C7 100 100 __0 000000000000 SATA CRC Error
DA 100 100 __0 000000000000 CRC Error Count
E7 _90 _90 __0 00000000005A SSD Wear Indicator
E9 100 100 __0 000000003C87 Lifetime Nand Writes
F1 100 100 __0 0000000028DB Lifetime Writes from Host
F2 100 100 __0 0000000024C1 Lifetime Read from Host
F4 100 100 __0 00000000006B Average Erase Count
F5 100 100 __0 000000000083 Max Erase Count
F6 100 100 __0 00000000B23C Total Erase Count
0 1 2 3 4 5 6 7 8 9
000: 0040 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 3530 3032 3642 3736 3833 3439 3139 3646 2020 2020
020: 0000 0000 0000 3033 3039 3030 3034 4B49 4E47 5354
030: 4F4E 2053 4134 3030 5333 3731 3230 4720 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8001 4000 2F00
050: 4000 0000 0000 0007 3FFF 0010 003F FC10 00FB 0101
060: 4BB0 0DF9 0000 0007 0003 0078 0078 0078 0078 0D00
070: 0000 0000 0000 0000 0000 001F 850E 0006 004C 0040
080: 07F8 011B 746B 7409 4160 7469 B401 4160 207F 0003
090: 0003 0000 FFFE 0000 0000 0000 0000 0000 0000 0000
100: 4BB0 0DF9 0000 0000 0000 0008 4000 0000 502B 2A20
110: 1D1C 1B1A 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0309
130: 0004 7041 2072 3731 3220 3130 0038 3031 323A 3A37
140: 3334 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0001
170: 6D61 766C 7361 7461 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 0000 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 0001 0000 0000
220: 0000 0000 10FF 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0001 0400 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 1CA5
000: 05 00 01 32 00 64 64 00 00 00 00 00 00 00 09 32
010: 00 64 64 38 19 00 00 00 00 00 0C 32 00 64 64 E2
020: 05 00 00 00 00 00 94 00 00 64 64 00 00 00 00 00
030: 00 00 95 00 00 64 64 00 00 00 00 00 00 00 A7 00
040: 00 64 64 00 00 00 00 00 00 00 A8 12 00 64 64 00
050: 00 00 00 00 00 00 A9 00 00 64 64 92 00 00 00 00
060: 00 00 AA 00 00 64 64 3B 00 00 00 00 00 00 AC 32
070: 00 64 64 00 00 00 00 00 00 00 AD 00 00 64 64 00
080: 00 00 00 00 00 00 B5 32 00 64 64 00 00 00 00 00
090: 00 00 B6 00 00 64 64 00 00 00 00 00 00 00 BB 32
0A0: 00 64 64 00 00 00 00 00 00 00 C0 12 00 64 64 43
0B0: 00 00 00 00 00 00 C2 22 00 18 1A 18 00 16 00 1A
0C0: 00 00 C4 32 00 64 64 00 00 00 00 00 00 00 C7 32
0D0: 00 64 64 00 00 00 00 00 00 00 DA 32 00 64 64 00
0E0: 00 00 00 00 00 00 E7 00 00 5A 5A 5A 00 00 00 00
0F0: 00 00 E9 32 00 64 64 87 3C 00 00 00 00 00 F1 32
100: 00 64 64 DB 28 00 00 00 00 00 F2 32 00 64 64 C1
110: 24 00 00 00 00 00 F4 00 00 64 64 6B 00 00 00 00
120: 00 00 F5 00 00 64 64 83 00 00 00 00 00 00 F6 00
130: 00 64 64 3C B2 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 35
170: 02 00 00 00 01 01 01 00 00 00 00 00 00 00 00 00
180: 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2F
000: 05 00 01 00 00 00 00 00 00 00 00 00 00 00 09 00
010: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
020: 00 00 00 00 00 00 94 00 00 00 00 00 00 00 00 00
030: 00 00 95 00 00 00 00 00 00 00 00 00 00 00 A7 00
040: 00 00 00 00 00 00 00 00 00 00 A8 00 00 00 00 00
050: 00 00 00 00 00 00 A9 00 00 00 00 00 00 00 00 00
060: 00 00 AA 0A 00 00 00 00 00 00 00 00 00 00 AC 00
070: 00 00 00 00 00 00 00 00 00 00 AD 00 00 00 00 00
080: 00 00 00 00 00 00 B5 00 00 00 00 00 00 00 00 00
090: 00 00 B6 00 00 00 00 00 00 00 00 00 00 00 BB 00
0A0: 00 00 00 00 00 00 00 00 00 00 C0 00 00 00 00 00
0B0: 00 00 00 00 00 00 C2 00 00 00 00 00 00 00 00 00
0C0: 00 00 C4 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 DA 00 00 00 00 00
0E0: 00 00 00 00 00 00 E7 00 00 00 00 00 00 00 00 00
0F0: 00 00 E9 00 00 00 00 00 00 00 00 00 00 00 F1 00
100: 00 00 00 00 00 00 00 00 00 00 F2 00 00 00 00 00
110: 00 00 00 00 00 00 F4 00 00 00 00 00 00 00 00 00
120: 00 00 F5 00 00 00 00 00 00 00 00 00 00 00 F6 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 18
Model : ST1000LM024 HN-M101MBB
Firmware : 2AR10001
Serial Number : S2S6J9BC902197
Disk Size : 1000,2 GB (8,4/137,4/1000,2/1000,2)
Buffer Size : 8192 KB
Queue Depth : 32
# of Sectors : 1953525168
Rotation Rate : 5400 RPM
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 6
Transfer Mode : SATA/300 | SATA/300
Power On Hours : 21617 hodin
Power On Count : 3706 krát
Temperature : 25 C (77 F)
Features : S.M.A.R.T., APM, AAM, NCQ, GPL
APM Level : 0080h [OFF]
AAM Level : FE00h [OFF]
Drive Letter : D:
01 100 100 _51 000000000002 Počet chyb čtení
02 252 252 __0 000000000000 Průchodnost disku
03 _86 _86 _25 000000001168 Čas na roztočení ploten
04 _68 _68 __0 000000007F99 Počet spuštění/zastavení
05 252 252 _10 000000000000 Počet přemapovaných sektorů
07 252 252 _51 000000000000 Počet chybných hledání
08 252 252 _15 000000000000 Čas potřebný na vyhledání
09 100 100 __0 000000005471 Hodin v činnosti
0A 252 252 _51 000000000000 Počet opakovaných pokusů o roztočení ploten
0B 100 100 __0 0000000001EB Počet pokusů o překalibrování
0C _97 _97 __0 000000000E7A Počet cyklů zapnutí zařízení
BF 100 100 __0 000000000062 Počet udalostí zaznamenaných otřesovým senzorem
C0 252 252 __0 000000000000 Počet vypnutí disku
C2 _64 _54 __0 003500110019 Teplota
C3 100 100 __0 000000000000 Počet oprav chybného čtení
C4 252 252 __0 000000000000 Počet udalostí s číslem realokování sektorů
C5 252 252 __0 000000000000 Počet podezřelých sektorů
C6 252 252 __0 000000000000 Počet neopravitelných sektorů
C8 __1 __1 __0 000000017D05 Počet chyb při zápisu sektorů
DF 100 100 __0 0000000001EB Zatížení budiče magnetických hlav způsobené opakovanými úkony
E1 _32 _32 __0 0000000A84C3 Počet cyklů načítání/vymazání
0 1 2 3 4 5 6 7 8 9
010: 5332 5336 4A39 4243 3930 3231 3937 2020 2020 2020
020: 0000 4000 0004 3241 5231 3030 3031 5354 3130 3030
030: 4C4D 3032 3420 484E 2D4D 3130 314D 4242 2020 2020
070: 0000 0000 0000 0000 0000 001F 1D06 0004 004C 0040
080: 01FF 0028 746B 7F69 6123 7469 BC41 6123 207F 0069
090: 0069 0080 FFFE 0000 FE00 0000 0000 0000 0000 0000
100: 6DB0 7470 0000 0000 0000 0000 6003 0000 5000 4CF2
110: 085D C941 0000 0000 0000 0000 0000 0000 0000 401C
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 0000
130: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
160: 0000 0000 0000 0000 0000 0000 0000 0000 0003 0000
200: 0000 0000 0000 0000 0000 0000 003F 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1518 0000 0000
220: 0000 0000 103F 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 5FA5
000: 10 00 01 2F 00 64 64 02 00 00 00 00 00 00 02 26
010: 00 FC FC 00 00 00 00 00 00 00 03 23 00 56 56 68
020: 11 00 00 00 00 00 04 32 00 44 44 99 7F 00 00 00
030: 00 00 05 33 00 FC FC 00 00 00 00 00 00 00 07 2E
040: 00 FC FC 00 00 00 00 00 00 00 08 24 00 FC FC 00
050: 00 00 00 00 00 00 09 32 00 64 64 71 54 00 00 00
060: 00 00 0A 32 00 FC FC 00 00 00 00 00 00 00 0B 32
070: 00 64 64 EB 01 00 00 00 00 00 0C 32 00 61 61 7A
080: 0E 00 00 00 00 00 BF 22 00 64 64 62 00 00 00 00
090: 00 00 C0 22 00 FC FC 00 00 00 00 00 00 00 C2 02
0A0: 00 40 36 19 00 11 00 35 00 00 C3 3A 00 64 64 00
0B0: 00 00 00 00 00 00 C4 32 00 FC FC 00 00 00 00 00
0C0: 00 00 C5 32 00 FC FC 00 00 00 00 00 00 00 C6 30
0D0: 00 FC FC 00 00 00 00 00 00 00 C7 36 00 C8 C8 00
0E0: 00 00 00 00 00 00 C8 2A 00 01 01 05 7D 01 00 00
0F0: 00 00 DF 32 00 64 64 EB 01 00 00 00 00 00 E1 32
100: 00 20 20 C3 84 0A 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 54 33 00 5B
170: 03 00 01 00 02 DB 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 81
000: 10 00 01 33 00 00 00 00 00 00 00 00 00 00 02 00
010: 00 00 00 00 00 00 00 00 00 00 03 19 00 00 00 00
020: 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00
030: 00 00 05 0A 00 00 00 00 00 00 00 00 00 00 07 33
040: 00 00 00 00 00 00 00 00 00 00 08 0F 00 00 00 00
050: 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
060: 00 00 0A 33 00 00 00 00 00 00 00 00 00 00 0B 00
070: 00 00 00 00 00 00 00 00 00 00 0C 00 00 00 00 00
080: 00 00 00 00 00 00 BF 00 00 00 00 00 00 00 00 00
090: 00 00 C0 00 00 00 00 00 00 00 00 00 00 00 C2 00
0A0: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00
0B0: 00 00 00 00 00 00 C4 00 00 00 00 00 00 00 00 00
0C0: 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 C6 00
0D0: 00 00 00 00 00 00 00 00 00 00 C7 00 00 00 00 00
0E0: 00 00 00 00 00 00 C8 00 00 00 00 00 00 00 00 00
0F0: 00 00 DF 00 00 00 00 00 00 00 00 00 00 00 E1 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 3B
Model : Samsung SSD 980 500GB
Firmware : 1B4QFXO7
Serial Number : S64DNF0R986315K
Disk Size : 500,1 GB
Interface : NVM Express
Standard : NVM Express 1.4
Transfer Mode : PCIe 2.0 x4 | PCIe 3.0 x4
Power On Hours : 2062 hodin
Power On Count : 498 krát
Host Reads : 890 GB
Host Writes : 1159 GB
Temperature : 27 C (80 F)
Health Status : Dobrý (100 %)
Features : S.M.A.R.T., TRIM, VolatileWriteCache
Drive Letter : F:
ID RawValues(6) Attribute Name
01 000000000000 Kritické varování
02 00000000012C Složená teplota
03 000000000064 Rezerva k dispozici
04 00000000000A Dostupná náhradní prahová hodnota
05 000000000000 Použité procento
06 0000001C7D58 Čtení datových jednotek
07 000000251889 Zapsané datové jednotky
08 000000D4BBF6 Příkazy pro hostitelské čtení
09 000000982D22 Příkazy pro zápis hostitele
0A 00000000002E Čas obsazení řadiče
0B 0000000001F2 Napájecí cykly
0C 00000000080E Hodiny napájení
0D 00000000000F Nebezpečné vypnutí
0E 000000000000 Chyby v médiích a integritě dat
0F 000000000000 Počet položek protokolu chybových informací
0 1 2 3 4 5 6 7 8 9
000: 144D 144D 3653 4434 464E 5230 3839 3336 3531 204B
010: 2020 2020 6153 736D 6E75 2067 5353 2044 3839 2030
020: 3035 4730 2042 2020 2020 2020 2020 2020 2020 2020
030: 2020 2020 4231 5134 5846 374F 3802 0025 0900 0005
040: 0400 0001 A120 0007 1200 007A 0200 0000 0010 0000
050: 0000 0000 0000 0000 0000 0100 0000 0000 0000 0000
060: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
070: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
080: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
090: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
100: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
110: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
120: 0000 0000 0000 0000 0000 0000 0000 0000 0017 0307
130: 0F16 043F 0101 0163 0166 0000 4000 0000 1000 0000
140: 6000 70C0 0074 0000 0000 0000 0000 0000 0000 0000
150: 0000 0000 0000 0000 0000 0000 0000 0000 0023 0400
160: 0000 0001 013E 0165 0003 6000 0010 0000 0400 0000
170: 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
220: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 0000
-- SMART_NVME --------------------------------------------------------------
000: 00 2C 01 64 0A 00 00 00 00 00 00 00 00 00 00 00
010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
020: 58 7D 1C 00 00 00 00 00 00 00 00 00 00 00 00 00
030: 89 18 25 00 00 00 00 00 00 00 00 00 00 00 00 00
040: F6 BB D4 00 00 00 00 00 00 00 00 00 00 00 00 00
050: 22 2D 98 00 00 00 00 00 00 00 00 00 00 00 00 00
060: 2E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070: F2 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080: 0E 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00
090: 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0: 00 00 00 00 00 00 00 00 2C 01 33 01 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6.
Doplním...
7.
Doplním...
  • Nefunkční 4NEC2 na WIN10
    16163 Zobrazení
    Poslední příspěvek od XmuX
    13270 Zobrazení
    17 Odpovědi
    102881 Zobrazení
  • Chyba CPU na desce
    16 Odpovědi
    16762 Zobrazení
  • Chyba příkazový řádek
    6916 Zobrazení
    Poslední příspěvek od zik9
